08-22-2022, 04:14 PM | #991 |
41
Rep 224
It's powered by the led dash surround and the door strips, I have both classic and sport mode, so should be orange and blue, not connected to the footwell lights
Martin
08-22-2022, 04:17 PM | #992 |
41
Rep 224
So how do I switch the door LEDs to blue? They only show orange and are dark when switched to sport mode, they are plug and play, the y cable on the dash needs rewiring?
Martin
08-22-2022, 11:35 PM | #993 |
127
Rep 339
08-23-2022, 02:59 AM | #994 |
41
Rep 224
I will try that, but what has swapping the pins on the lcd dash surround have to do with the doors not switching to blue? My problem is the dash surround and the door card leds are not switching and remain one colour orange
Martin
08-24-2022, 10:08 PM | #995 |
127
Rep 339
Question, did you have to code, your car to even have ambient light? If it already had it and worked perfectly before, then it would be definetly whatever you changed.
08-25-2022, 04:02 AM | #996 |
41
Rep 224
No coding the car already had classic and sport ambient lighting, after connecting the led strip to the cars wiring it never did switch. The dash surround led is connected with a y cable for power. But I don't see how this would affect the door leds
Martin
09-06-2022, 04:25 PM | #997 | |
Rep 41
Hi guys, Who can help me with sorting out the brightness of the panel. It's too bright for me and doesn't match with the rest ot the ambient. I just wondering how to lower the brightness only on this Ac panel? |
09-07-2022, 03:18 AM | #998 |
Great Teacher
1118
Rep 1,314
Drives: 06 e91 325ix
Add a resistor
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
09-23-2022, 11:04 AM | #1001 |
Eh?
249
Rep 88
Managed to order the last trim panel in Canada & finally had time to build the cable yesterday. Love that there's a very OEM solution to making this work, I wasn't looking forward to hacking up wiring when I picked up my car last month.
Dante467.50 |
02-28-2023, 11:38 PM | #1002 |
M-Experienced
48
Rep 198
Drives: 2024 BMW X5 xDrive50e AWD SUV
I am faced with the same issue as the OP (Dante). Dante would you have this DIY Y-harness for sale?
03-22-2023, 08:24 AM | #1003 |
13
Rep 29
Super late to this party but I just did this the other day finally.
https://www.ebay.com/itm/314451800280 Link to Y cable for those not wanting to make their own. I had issues with the bottom trim piece when I did my retrofit. The bottom piece kept falling out and didnt clip back into the ac center piece properly. The solution was to give it a smack with my fist and heard it click in. Just a tip for those who have yet to do this.
BSM F80
Lurker of all threads |
mazen22227.50 |
01-03-2024, 04:42 PM | #1005 |
Rep 51
Drives: Bmw f31 pre lci Touring
If you have no led light above cup holder and no footwell lights, am I right in that the ac surround ambient lighting is not possible.
Thanks |
02-29-2024, 11:36 AM | #1006 |
98
Rep 278
F36 and many trim options, center cupholder light
I'm looking to do this retrofit in my 2017 430ix Gran Coupe, and I see not only options for OEM BMW LCI AC/Radio trims, but also see a bunch of options on Amazon and eBay of what seems to be Asian equivalents. Any real difference before I pull the trigger?
Also, has anyone made a hole for center cupholder light in the dash. My car came with a USB port on the panel on the right side, but it seems that from behind the panel, the center light assembly holder is there, and potentially I could mount the cupholder light assembly there and drill a hole for the light to pass through.
04-12-2024, 03:11 PM | #1007 | |
///M
183
Rep 676
Drives: '18 F80 M3 ZCP, '14 F30 328i
I did this install today into my pre-LCI 328i which had the light package so tied into the LED in the cupholder. The light at the middle setting is very dim so I bumped it up a couple ticks and really pops now. I had previously installed the hex trim interior with piano black accent which really ties nicely into the gloss black LCI radio trim retrofit.
A big note here, the radio connector is by far one of the worst BMW tabs I have ever had to deal with. It's resistance to removal took me substantially longer than any other part of the retrofit. Think trim tool, small electronics flathead screw driver, brute force. Luckily, I didn't snap that connector however, a circular motion with robust force brought it out... Other folks said that removing the radio faceplate and climate control plates were difficult however, mine popped pretty early with a nice Hazet wide, flat trim tool and some pressure towards release. There are 8 tabs per faceplate so that felt like overkill. I also opted not to disconnect the climate control unit from the radio unit given the difficulty of getting the radio away from the car. I found this wasn't necessary to get everything put into the new LCI trim. Quote:
The trim is pretty thin and the holding clip isn't that robust. I would just put painters tape and drill from the front (e.g., faux pebbled leather) to the back (of the panel) to avoid pushing through the leather any more than you would have to.
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI Last edited by wishbone; 04-12-2024 at 03:36 PM.. |
Arthurrs98.00 |
