      06-10-2014, 02:54 PM   #45
3002 tii
3002 tii's Avatar
2289
Drives: Z4 M, X5, GX460
Originally Posted by MightyMouseTech View Post
Hmm, is the trim on the 1M different so it does not do this?
Could be difference between N54 and N55
Follow for latest mods
      06-10-2014, 04:41 PM   #46
DietTab
DietTab's Avatar
Drives: 08 135i
205 is a lot to pay for convenience. Looks nice though
LSXOCET - 404rwhp @ 1600 lbs curb weight... bonkers fast
      06-12-2014, 03:00 AM   #47
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
Has anyone tried to fit a front strut brace like the cusco/turner etc under these new strut rings? Curious to know if it would fit.
      06-14-2014, 03:05 PM   #48
3002 tii
3002 tii's Avatar
2289
But what's the alternative for someone who needs to open up the area if they have adjuster knobs coming out? Other strut bars are even more expensive.
      06-15-2014, 06:50 AM   #49
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Plus these have dust covers.
      06-15-2014, 11:03 AM   #50
3002 tii
3002 tii's Avatar
2289
The M plastic covers alone justify the entire cost
In all seriousness, total brain fart. When I installed the bar I forgot to pull the pins out so I tried loosening the strut nuts today to remove the bar. In doing so I somehow broke the stud off the strut mount. Rather than order a new one figured good reason to switch to Dinan plates but man, talk about royally screwing up head should've been a 5 min mod.
      06-16-2014, 08:46 AM   #51
TheSt|G
TheSt|G's Avatar
I was actually being serious about the dust covers. Most shocks are open at the top and you will have premature failure if you are feeding dirt into them.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      06-16-2014, 08:49 AM   #52
3002 tii
3002 tii's Avatar
2289
I was half serious too, yes mine are exposed in the Z4 but I have to keep them open since I'm running coilovers with adjusters sticking out. But I find myself always wiping them down, making sure no dust/dirt get inside the threaded portion of the knobs and what not.
I was fully serious about my studs snapping, wtf.
      06-16-2014, 09:28 AM   #53
TheSt|G
TheSt|G's Avatar
Yeah that really sucks.
Frankly, I'm none too impressed with the hardware in that region. My brother's wife's e91 2009 wagon already has those studs rusting. The hell is that about? My fiance's ZHP's still look factory new.
      07-17-2014, 02:25 PM   #54
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
How did you guys order these?
1 / 51618051973 / SPRING DOME STRUT, LEFT (unique to 1M)
1 / 51618051974 / SPRING DOME STRUT, RIGHT (unique to 1M)
Everywhere I've tried has come up empty on having these.
      07-17-2014, 09:59 PM   #55
vivanapoli806
Drives: 2012 535i Xdrive Msport
I did a quick google search and was able to find them just look them up
      07-17-2014, 10:43 PM   #56
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
I ordered them through Schiedmann but ECS also carry them....not sure where your searching
      07-18-2014, 08:44 AM   #57
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I like ECS and Turner for parts like this. Looks like this mod will be in my future, thanks for posting.
      07-21-2014, 04:49 AM   #58
flinchy
Drives: E82 135i
Wow cheaper than i expected
On one hand i like the cheapness+added convenience and the look
But i'd kinda prefer the functionality of the m3 one, being it's probably somewhat stiffer :/... But for like double the price...
      07-21-2014, 07:04 PM   #59
E82MSport
E82MSport's Avatar
Drives: 08' Crimson 135i
This is definitely on my list. I hate that every time I clean the engine bay there's debris inside the strut towers. They should have made a simple cap to close out the opening from the factory.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
      07-22-2014, 08:12 AM   #60
TheSt|G
TheSt|G's Avatar
Yeah, and depending on the design of the strut, that can fail them super early.
      08-11-2014, 03:15 AM   #61
Sfvalley135i
53
Drives: 135i
Bump
If anyone is looking for the M3 strut brace that HPautoworks sells for the e82, I have one for sale, $350.
I cant speak for the 1M brace but with the M3 brace from HPautoworks it made a noticeable difference, mostly in initial input/turn in.
      08-17-2014, 09:17 AM   #62
Zombie1
Drives: BMW 135i 2010
Question guys.. I saw a member sellin the M3 brace for cheap, but I already have a DINAN strut bar. I havent installed yet but i believe I cant use the DINAN bar if I use the m3 brace? Which one would benifit me more?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
      03-28-2015, 11:54 PM   #63
_Ryan_
59
Drives: E87 130i
2005 BMW 130i  [5.24]
Heads up- if you have Vorshlag plates, you may require an extra set of hands to fit these as the studding piece of the plate can drop.
-Ryan
      03-29-2015, 07:28 PM   #64
totti84
Australia
112
Drives: N54 135i 6MT
Does anyone run a BMS Oil Catch Can with this brace with no fitment issues?
Is this brace the same thickness and shape as the stock 135i brace?
      03-29-2015, 09:02 PM   #65
_Ryan_
59
Drives: E87 130i
few mm difference around the join from the ring to the brace.
      03-29-2015, 10:10 PM   #66
totti84
Australia
112
So does it fit safely?
