The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Combox Retrofit coding
      12-22-2016, 05:48 PM   #23
Gangsta
Drives: F10 LCI MY0314
Originally Posted by Josh_G View Post
i have a really good PDF guide on how to code a combox if you want it, shoot me a PM of your email and i will send it over ;
Would you be able to send me you pdf guide? It will stop me asking too many questions on the forum that have already been answered.
I'm coding a 11/09 E90 LCI with Bluetooth with Assist and CIC Professional.
I have managed to do all physical parts such as all the wiring from the original TCU and MULF using a custom made harness, have the USB to the armrest etc.
I have my car updated to Software V42 which should mean I will not nead the FSC code, but I heard some where id you are programming with Daten version newer than V43 then it may enable the FSC codes, is this true?
I can use NCS Expert to code the modules (CIC and Combox), just need to know what I need to do.
I will happy to post here once I have successful completed the work.
      12-27-2016, 02:55 AM   #24
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
here u go mate
https://dl.dropboxusercontent.com/u/...0photos%29.pdf
cheers
      12-27-2016, 06:54 AM   #25
Gangsta
Originally Posted by Levanime View Post
that's brilliant, cheers for helping me with the install.
      12-27-2016, 08:14 AM   #26
david in germany
Drives: 118i, 335i and 328i
In for later.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      01-06-2017, 05:58 PM   #27
Gangsta
Originally Posted by tvalentine4223 View Post
Thanks for the reply. They found i had a bad frm module and replace under warranty. Everything is good again.
I was wondering about your FRM ECU, mine is a 0909 build LCI although FRM is listed when I do a CAS, but its not listed when I am choosing a module to write to, I have a NFRM, any idea what the difference is?
      04-25-2017, 04:11 PM   #28
Impac
21
Drives: Bmw
Can someone please send me the PDF foe coding the ComBox Thank you
      05-01-2017, 02:03 AM   #29
funglenn
Drives: 530i
i got my system fully working but one thing annoys me. When i was playing a song on my iphone it used to sit at the list of songs, now it defaults to the album cover and i have to click to go to the playlist list or current list of songs playing.
anyone know what needs to be coded to have it default to the list of songs? On the dual screen option, it still shows the album cover on the right side (under entertainment). I just hate staring at two album covers, one on left and one on right side of the screen--make sense? I want to disable one, but not the other. I know it is possible. it worked that way before i recoded the system to default to fix some other issues. now they are fixed but this is the result.
thanks.
      07-05-2017, 05:07 PM   #30
MattyD44
England
Drives: BMW F36 435D M Sport
Are you able to provide a new link please?
      07-06-2017, 02:40 AM   #31
kaputme
Germany
17
Drives: E90 2009
2009 BMW E90  [8.00]
check this
      07-08-2017, 06:45 AM   #32
Len_Beach
Drives: 435d
In for a new link
      11-07-2017, 04:07 AM   #33
onel
Drives: F32 435i
could you send me the pdf please...
thanks
onel
      11-07-2017, 05:21 AM   #34
Josh_G
Josh_G's Avatar
48
Drives: BMW M2 Competition
http://www.e90post.com/forums/showth...ght=combox+pdf
      11-28-2017, 12:20 PM   #35
marckusk
Drives: E92 335d 2011
i have a question.
i've got a 335d 2011. It has 6VC (got the combox in the trunk) , but i got no audio streaming. What am i supposed to do? I have the bluetooth antenna output, but without any antenna plugged in.
I have the navi professional and H&K.
The antenna itself is pretty simple to install, but what do i need to activate the bluetooth streaming? I got NCS expert and i compatible cable.
      11-28-2017, 12:35 PM   #36
stylez1989
Drives: E90 328I N52
I did my CIC and Combox media retrofit done could never get the bluetooth part on the combox to work it just sits at connecting but shows connected on my phone. The usb/Aux is working from the retrofit from MULF2 to Combox and i see it's coded properly (at least i think so) It's been about 8 months since the retrofit and kinda gave up since i feel like its a software version on the cic is old.
C08 is what is shows any ideas?
      11-29-2017, 09:00 AM   #37
Joe@TopGearSolutions
Joe@TopGearSolutions's Avatar
263
Drives: BMW
I would find someone with an ICOM and update your CIC to latest firmware (C1A).
      11-29-2017, 01:42 PM   #38
stylez1989
yeah that's what i figured. only one person where I'm at has one but don't want to install the 3rd party software.
send me a pm if i can send u my cic to update
      11-29-2017, 04:02 PM   #39
E60525d
E60525d's Avatar
281
Drives: 330d M Sport LCI
You need to do a reset on the combox and cic using NCS expert.
I had exactly this problem and solved by doing a reset.
      11-29-2017, 05:34 PM   #40
stylez1989
I believe I did the SG_reset on the MEDIA and CIC, I may go try it again.
My cic version doesn't have "Connected drive" its a 2009 version
Update
I SG reset media and CIC, it sees my phone, it ask me to enter a password on the CIC and iPhone, IPhone shows connected but CIC just gets stuck on Pairing completed.Connecting...
      11-30-2017, 02:46 PM   #41
E60525d
E60525d's Avatar
281
Update
Thats not how to do default setting, you need to do SG_CODIEREN.
Details here http://blog.obdii365.com/2015/05/18/...pert-software/
      11-30-2017, 04:12 PM   #42
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Poking around I found a few people who have Combox working with C08. Have you updated the media software? Put your donor car vin in the page below.
https://www.bmw.com/content/bmw/mark...e-updates.html
      12-01-2017, 10:41 AM   #43
stylez1989
yeah before i did default using a blank man file for SG_codieren when i installed the combox media. let me go check out this other post and i will report back later.
Edit: Although i said i did that 6 months ago when i did the Media retrofit, I may try it again but save my current man files for the CIC due to the fact i said the same thing when i was having outer tail light issues and found out it was a coding issue just a few days ago even though i did the blank man file the last time lol
Edit again. I really starting to think I never did a blank man file on the combox it self.. this could be the problem the whole time. Pretty stoked to try it when I get home tonight I will do the cic and combox. I did set my VO with the new combox but what are the codes for NA just in case?
      12-01-2017, 10:44 AM   #44
stylez1989
I will pull from the MEDIA combox Donor vin when i get home today and check.
MULF2 worked with C08 but people kept saying combox wouldn't work on C08 other than USB/AUX. bluetooth connects (showing connected on my phone) but will get stuck at connecting on the idrive screen and they were saying it was because combox wasn't in the 2009 and was the old MULF2 till 2011 if i remember correctly.
I'm talking to someone about updating the CIC to CA1 very soon which will probably solve all my problems.. I may go ahead and install the original 2RAD to get my software from Progman to ISTA then update the cic to the latest I level including the media.
