TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Permanently wired K+Dcan cable Install doesn't seem to need 12v from OBDII?
      03-19-2024, 01:40 PM   #1
rbryantaz
Drives: 2007 E70 4.8i, 2008 E90 335i
2008 BMW 335i  [7.67]
2007 BMW X5 4.8i  [10.00]
My car has a 10" android screen installed so I want to monitor MHD on that unit. I can use the MHD wifi adapter but then I don't have internet. The unit isn't android 12+ so it doesn't have the option to be on two different wifi networks at the same time.
So for now I added an OBDII Y connector which was $10 on Amazon where one end is installed in place of the factory connector and the other is under the dash connected to a K+Dcan cable.
Note that the Y cable I got just uses random colored wires to connect all pins of the OBDII connectors so don't rely on any color coding with it. I cut the 12v wire that feeds the K+Dcan cable and connected it to a switched 12v supply so that it is not powered on unless the ignition is. I then realized that the K+Dcan can work on USB power and doesn't seem even need the 12v supply.... (but I haven't done any coding that way)
The setup is working well, the K+Dcan powers up with the car and connects as soon as I load the MHD app for monitoring and worked for an xhp flash.
Has anyone ran a K+Dcan from just USB power without the 12v from OBDII connected regularly? I may try it given that I added a switch to turn off the 12v already incase I connect to an ICOM (but it turns out I also have to unplug the cable or it just works on USB power). It would is less work to install it with the 12v disconnected given that I had to run a 12v wire from my fusebox area and splice it into the K+Dcan cable's OBDII connection to add the switched 12v.
-Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller.
coding, k+dcan usb interface, k_dcan, mhd, monitoring
