BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > BMW CODING success
      11-08-2010, 11:33 PM   #67
wchoy
Drives: '08 AW e90 335i
Im excited. NO MORE CORNER PARKING LIGHTS!!!!
      11-09-2010, 06:44 PM   #68
heartpumper
Drives: 07 335i.. STI GONE :]
Well I have an 07 e90 and the CAN wire is not at the obd2 port from what I understand.. That is why BMS is having to make a specific CAN tool for with 07 support that plugs in at the ecu where the can wires are located... Now a good question would be could be run that wire down from the ecu like the 08's
      11-09-2010, 07:45 PM   #69
xxxjecxxx
xxxjecxxx's Avatar
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
Finally here we go!
This assumes that you are using an OBD port, to use other adapters you will have to edit ediabas.ini
LINK FOR CABLE http://www.carparts-sale.com/new-edi...face-p-34.html
all files needed are in ncsexpert.rar and DIY is a pdf as a separate file! enjoy!
http://rapidshare.com/files/429882289/NCSEXPER.rar all files needed
http://rapidshare.com/files/429875523/NCS_DIY.pdf DIY
http://forums.5series.net/topic/1060...g/page__st__15 coding examples
http://translate.google.com/#de|en| this will be your best friend
I was going to turn coding into a part time job because I could really use the extra cash but I am providing all my work free of charge, if you find it helpful in any way please donate to the following link.
https://www.paypal.com/cgi-bin/websc...if%3aNonHosted
      11-09-2010, 08:24 PM   #70
heartpumper
Awesome Man.. Just Donated.. I Will Be Ordering Cable Asap And Get To Work..
      11-09-2010, 08:27 PM   #71
xxxjecxxx
xxxjecxxx's Avatar
I've ran into many errors the way I setup the DIY you guys should be almost error free. Thank you for the donation
      11-09-2010, 08:40 PM   #72
heartpumper
Yep.. I am now going to try to have to figure out his recode of the headunit from logic 7 to hifi so I can install the JBL MS8.. I am may have to end up paying someone, but would definatly like to figure it out myself as that will give me great insight into this process...
      11-09-2010, 09:04 PM   #73
Amlethae
13
Drives: 2011 335ix M-Sport
2011 335xi  [0.00]
I don't even have a BMW yet and I just donated. I hope that others will donate as well and encourage you and others like you to share your intelligence and enthusiasm with the community. Thanks for your hard work!
      11-09-2010, 10:53 PM   #74
xxxjecxxx
xxxjecxxx's Avatar
the only part of coding that so far i've had zero interest in has been the audio system, but i'll take a look around see if I can be of any help
      11-10-2010, 03:40 AM   #75
vic18t
Drives: 2008 BSM E92
I guess this means that the BT tool cable won't work with recoding mods?
      11-10-2010, 05:46 AM   #76
scandluz22
Drives: 2006 330xi
2007 328XI  [0.00]
Thanks OP!! I will be donating soon. In case anyone needs the USB to RS232 adapter, here is a cheaper alternative ... USB to RS232 Cable
The one linked to earlier in the thread was a bit pricey I thought. Thanks again OP
"it remains the benchmark by which all competitors, including Lexus, must be measured."
      11-10-2010, 07:46 AM   #77
heartpumper
Thanks,
MORE DONATION COMING YOUR WAY IF YOU CAN FIGURE THAT OUT
I will get cable and start looking into it also..
THANKS
      11-10-2010, 11:21 AM   #78
mr.e90
Drives: E90
Anyone around Santa Barbara or near by areas near LA going to get this?? would love you hear how it goes and if you can code some stuff for me ill pay you some u.s green lol =)
      11-10-2010, 03:12 PM   #79
wpnx
Drives: 335xi
I'm going to try getting this cable. Hope I don't screw anything up.
      11-10-2010, 03:27 PM   #80
SaviorSelf
SaviorSelf's Avatar
Drives: 2007 BMW 335i
So this won't work with a 2007 335i Sedan?
      11-10-2010, 04:21 PM   #81
orangedawg
Drives: 328xi
I think it will work if you get a KCAN/DCAN cable, like the one posted above for about $110. KCAN cars are pre 03/07 build date. 3/07 and later are DCAN.
      11-10-2010, 05:43 PM   #82
SaviorSelf
SaviorSelf's Avatar
You think something like this would work?
http://www.dhgate.com/bmw-inpa-k-can...0445917d1.html
      11-10-2010, 05:58 PM   #83
Amlethae
13
2011 335xi  [0.00]
Hey OP, can you compile a list of parameters to change and what they do? I've got KOMFORTSCHLIESSUNG_FB for the windows up via remote... and the BC_DIGITAL_V for the digital speedometer... what other ones are there? Could be a sticky :-)
      11-10-2010, 07:48 PM   #84
Robben@ltbmw
Drives: E90 Space Grey
2007 328i  [0.00]
will the wire for bt tools work?
      11-10-2010, 08:21 PM   #85
wchoy
I think that would e a very good idea. Or like mini diy's for different things ie windows up and corner lights. Whenever someone figures one out share the wealth.
      11-10-2010, 09:35 PM   #86
xxxjecxxx
xxxjecxxx's Avatar
I will start the list this is everything i can remember at the moment. Don't remember the default values for all but it its aktiv change to nicht_aktiv or vise versa. I am pulling these values from my notes they may not be 100% accurate but should give you some guidance.
Disable dong when driver door open and key in slot
CC_ZUENDSCHLUESSEL
(will reset ecu including clock possibly service dates)
"corner delete mod"
sidemarker_US
Digital speed on cluster
BC_DIGITAL_V
Comfort folding mirrors
BEIKLAPPEN_B_KOMFORTSCHL
panic mode
SONDERTASTE_PANIKALARM
(must have alarm installed, hold trunk button)
rain close
regenscliessentilt
(may have been a second value also, sunroof will need to be taught all functions with INPA. only works when automatic wipers are on, it will remain close until the car is restarted" had to stop on the way to miami just to restart car
close windows and sun roof with fob holding lock button
I have a couple more laying around somewhere I just have to find the motivation to look for. if i remember correctly i can also code close convertible top with fob should be the value right under "KOMFORTSCHLIESSUNG_FB" and can code car to ignore all light errors.
      11-10-2010, 09:36 PM   #87
xxxjecxxx
xxxjecxxx's Avatar
also refer to the provided link in DIY post.. it's for 5 series but the most of values are the same.
There are not a lot of people out there sharing what they found, i figured out a lot of it translating pages on Google
      11-10-2010, 11:42 PM   #88
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Finally here we go!
Can someone please host these files somewhere other than RapidShare? The limit has been reached and I rather donate to xxxjecxxx than pay RapidShare! Thanks!!
