BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Steptronic gear display
Extreme Powerhouse
      09-14-2014, 08:46 AM   #1
dad2b
General 435i Msport
Puerto Rico
10
Drives: 2014 435i MSport
Hello,
New to F32, in my traded E82 I was able to see the shift change from the automatic transmission, the display showed D1 thru D7 based on the gear that the car was running. In my new F32 I can't see that, the only thing that I see in the display is D, I went thru the owners manual with out having any luck on finding if this can be change, any one that can help?
Thanks
2023 X5e AW/M Sport/Premium/Amber interiors
Gone 2014 435i AW/Black/MSport/Tech package/Premium/M Performance Brake Kit
Gone but won't be forgoten: 2012 135 JB/Coral/Msport/Premium/DCT/HK/Scopione CF diffuser
      09-14-2014, 04:30 PM   #2
Ganxxta
Germany
85
Drives: F32 4er Coupé
Good question, would be interested to see if this can be done with coding on the F32.
Don't know why BMW removed such information...
      09-14-2014, 07:19 PM   #3
KevinO
Warrior-Poet
KevinO's Avatar
Drives: 2015 BMW 335i
For the record, it does show you in sport mode. Perhaps it wasn't deemed as desirable in the general comfort mode?
      09-14-2014, 09:25 PM   #4
Professor///M
Professor///M's Avatar
820
Drives: 2022 M3, 2022 X5 40i;
The only way to display is in sport or manual. I don't find it of very much value in standard drive to know the gear. Then again, I don't find myself in drive all that often
      09-15-2014, 11:27 AM   #5
carzaddict
Drives: 2015 Cadillac Escalade ESV
The only way to display the gear is in Manual.
However you can code the car to display the gear in DS....but no one has found for D
2015i Cadillac Escalade ESV
      09-15-2014, 12:43 PM   #6
botho
France
16
Drives: 2014 F31 330d xDrive Luxury
Hy,
Could you please tell me which code to enable gear number in DS mode ?
I can't have it to work.
I have SAT on my 330d F31 and when i coded in KOMBI the SPA_SPORT_ENABLE and SPA_ENABLE to aktiv then Kombi cluster doesn't work anymore for gear display : nothing is display anymore nor DS nor D ... display stay black
Thanks
      09-16-2014, 10:14 AM   #7
MyFastM3
65
Drives: m3
Originally Posted by botho View Post
Hy,
Thanks
Remove - SPA_ENABLE
For some reason it disables the notification.
      09-16-2014, 11:48 AM   #8
botho
France
16
Thanks. Will try this and give you feed-back
      09-16-2014, 04:23 PM   #9
KevinO
Warrior-Poet
KevinO's Avatar
On my 2015 model 335i, this is the default behavior when engaging sport transmission by flipping the gear shifter to the left, but not when using the button to engage sport mode.
      10-05-2014, 02:27 AM   #10
botho
France
16
Originally Posted by MyFastM3 View Post
Remove - SPA_ENABLE
It works fine, many thanks MyFastM3.
So just set aktiv SPA_SPORT_ENABLE in KOMBI/3000 to have S1-8 instead of DS
Regards
      10-06-2014, 04:31 AM   #11
Z_Victor1
Z_Victor1's Avatar
64
Drives: 2022 G22 M440i 👍
Trouble is, even assuming you could get it to display in "D", the size of the figure shown is too minuscule to be of any real use.
      10-06-2014, 05:48 AM   #12
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
Your old car probably had an Alpina flash then
      10-20-2023, 11:27 PM   #13
Lehan
Drives: BMW E90 323i BMW F25 xdrive28i
Regards
Hi what other code did you do? I set aktiv to SPA_SPORT_ENABLE, but still getting DS, even after retrofitting 2tb
      10-20-2023, 11:28 PM   #14
Lehan
Hi I have 205 but vo coded to 2tb, how do I code it to display gear in DS?
      05-02-2024, 06:41 PM   #15
marko1906
Drives: F30 340i
I hope that someone can help me with my problem. When i start my car there is never any gear displayed, not in eco, comfort or sport.
I would like to code it but i dont know where to look for it and i dont want to mess things up.
Hope someone knows what option i have to choose.
