BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
BPM
      01-13-2024, 06:08 PM   #1
JamesT335I
Drives: M3 2009 E92
Idrive issues. PLEASE HELP
Hey everyone,
I am having an issue with my Idrive, the car is a 2009 E92, 168xxx miles (I know it's a lot, but I maintain the car like any other obsessed M driver). My idrive will change sources randomly while I'm driving. I'll be playing music through the aux input, but it will randomly change back and forth between aux and radio, changing randomly and rapidly, until it settles down between one of the two. I've checked my alternator, it's charging as usual, the battery is showing discharge warnings recently, but besides that, the car is running fine. I have recently changed the subs for SWS8s, but no other changes to the audio. The issue was happening prior to the speaker change and discharge warnings. Any help is greatly appreciated
      01-13-2024, 06:31 PM   #2
OmairK
Engineer
Drives: 1995 M3 - 2011 E90 M3 6M ZCP
Change the battery, program the car for the new battery, and get back to us.
      01-13-2024, 07:13 PM   #3
drwankel
drwankel's Avatar
1068
Drives: 2012 E92 M3 ZCP, 2021 M340i
This- these cars do weird things when the battery gets old even if it can still start the car.
If the date code on the battery is more than 5 years old, you should replace it.
      04-11-2024, 11:25 AM   #4
JamesT335I
Drives: M3 2009 E92
Replaced battery, gotta recode the AH to 95 vs the 90 it's currently at. Issue continues. I did use my foxwell to tell the car it is a new battery AND have it trickle charging to make up for the 5AH difference. The issue occurs right around the 25 minute mark of driving. Flips between aux/cd and the radio, usually 3 to 5 skips.
      04-12-2024, 10:40 AM   #5
PACarGuy
PACarGuy's Avatar
Drives: 2012 E92 M3 DCT ZCP
Sounds like maybe a head unit issue or a cable connection issue. Have you pulled the H/U and checked all the connections to the quad lock, etc.? If those are fine, then might try sourcing a used H/U on eBay and swapping it in.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
      04-12-2024, 08:41 PM   #6
JamesT335I
Drives: M3 2009 E92
I was thinking about doing that this weekend 🙏
      04-13-2024, 08:26 AM   #7
pbinmich
17
Drives: 2013 BMW M3 E93
Originally Posted by JamesT335I View Post
Hey everyone,
Try disconnecting the rotary haptic control unit. The headunit is receiving signals from something, if power is good (battery/alternator), it's possible one of the input devices has failed. There's also the dash/steering wheel but the haptic device is probably the most complex.
      04-13-2024, 12:15 PM   #8
Bmwdeven
Bmwdeven's Avatar
191
Drives: Bmw e92 m3
2008 BMW M3  [0.00]
I’ve got an audio shop here in Los Angeles. Just so happen to have a 4x4 shop Canada e92 head unit in stock. Let me know if you need one.
      04-13-2024, 04:11 PM   #9
JamesT335I
Drives: M3 2009 E92
What do you mean by rotary haptic device? Do you mean the Idrive controller? I've disassembled and cleaned the entire controller with IPA 91% and it didn't do anything to clear the issue
      04-13-2024, 04:13 PM   #10
JamesT335I
Drives: M3 2009 E92
I really appreciate the offer, fortunately, I owned a pair of 335s before and one got totalled out and I gutted it for everything useful and have a spare head. If that doesn't fix it or I have issues with that head, I'll be sure to keep you in mind 🙏🙌
      04-13-2024, 05:19 PM   #11
Bmwdeven
Bmwdeven's Avatar
191
Drives: Bmw e92 m3
2008 BMW M3  [0.00]
Sure thing 👍
      04-14-2024, 11:54 AM   #12
pbinmich
17
Yes, I mean the rotary haptic device/idrive controller. Have you tried just leaving it disconnected and monitor if the issue is gone?
These aren't analog signals - they're packets of digital data (likely on a CAN bus), so if the head unit is doing this it must be getting a command from something...anything you control that can do this is suspect. My guess would be the idrive controller has failed. It's sending commands on CAN because it thinks the user is doing something.
PACarGuy686.50
      04-14-2024, 12:56 PM   #13
JamesT335I
Drives: M3 2009 E92
Ahhh ok, I may swap the controller from my 535 to see if that fixes it 🤔
      04-15-2024, 05:08 AM   #14
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
unplug the controller if that doesnt fix it then unplug the cic faceplate.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
      04-17-2024, 08:24 PM   #15
JamesT335I
Drives: M3 2009 E92
I think you might be on to something. Unplugged the controller, went to work, only did the skip once, rather than 5 or 6 skips in quick succession. I'll see if it does it again on the drive home from work. For the CIC face plate, are you referring to the screen?
      04-18-2024, 05:11 AM   #16
amrazM
mTekMods
amrazM's Avatar
the cic faceplate is the cover for the idrive unit, the cd drive with the buttons. theres a ribbon cable, sometimes when these go bad it causes volume spikes, so its def a localized issue to one of these idrive components.
      04-18-2024, 07:04 AM   #17
JamesT335I
Drives: M3 2009 E92
Ahhh I'll give that a shot. Thanks boss!!!
      04-25-2024, 09:07 AM   #18
JamesT335I
Drives: M3 2009 E92
So I think it's the head itself. Had it do the skips again and it wouldn't swap nor volume down from any of the control inputs, including the volume knob on the radio, even pushing to mute. Is there anything I need to know before I swap the head? I.e. coding the radio to the car. Thanks again for all your help guys, very much appreciated
      04-25-2024, 11:35 PM   #19
JamesT335I
Drives: M3 2009 E92
Update: swapped the faceplate as advised, initial test has it working as normal. I originally intended to swap the entire head unit, but noticed a part number difference. The attached photos will show the discrepancy in the numbers, the 335 head comes back as an LCI head, but the M3 head doesn't show up on any part number searches, even on realoem. I'll let yall know what happens with the faceplate swap.
PS: I did notice the radio head got quite hot to the touch while I was testing the faceplate install. Is that normal, or could I be looking at a potential issue? Thanks again
      04-26-2024, 05:36 AM   #20
amrazM
mTekMods
amrazM's Avatar
theres like 10-12 different cic part numbers. not an issue.
      04-26-2024, 12:13 PM   #21
JamesT335I
Drives: M3 2009 E92
Ok cool, so if I run into that issue after swapping the faceplate, I'll swap the heads. Thanks for the info!
      04-26-2024, 12:43 PM   #22
RocketyMan
RocketyMan's Avatar
Drives: E53 X5, E83 X3, E93 M3
2008 BMW M3 E93  [10.00]
As long as its the C1A SW on the head unit, it shouldn't be a problem at all. You can code any of the missing features in/out.
2008 BMW M3 E93 MT
R135
..246
m3post
