Comfort Access Retrofit Project
04-02-2016, 04:38 PM | #89 |
18
Rep 129
I been wanting to do this for the longest. so just to make sure.
I would need passive Go. CAS Module Key fob Antennas I'm I missing anything else? I'm just interested in keyless start! |
04-02-2016, 05:40 PM | #90 |
25
Rep 231
Dont the antenna fit here? There are 4 tabs have hold each corner of the antenna.
04-04-2016, 02:36 AM | #92 | |
20
Rep 105
04-04-2016, 02:55 AM | #93 | |
20
Rep 105
++ Take care of the USB wire and plug that is just under the antenna location when you reinstall the front center box, I crushed the USB wire going to the Mulf while screwing the left hex bolt (it's where the wire goes under the carpet on the left, then back, then to the left side of the rears seats). |
04-04-2016, 11:41 AM | #94 |
18
Rep 129
How does it go about getting the car with vin saying you got CA. Asked my parts advisor and he said that if I change everything then later down the line if I sell it and something happens to the next owner and they need a new key from the dealer it won't match because the vin won't show CA.
04-04-2016, 12:09 PM | #95 | |
20
Rep 105
http://www.e90post.com/forums/showpo...3&postcount=32 |
04-04-2016, 05:05 PM | #96 | ||
25
Rep 231
I just successfully retrofitted CA in a e87 thanks to information in this thread and the bmw coding forum. Not a very difficult retrofit but very time consuming and expensive. |
04-05-2016, 04:57 PM | #97 |
83
Rep 353
Pierre26 for the front CA antenna do I take out only the shifter trim to access it or I need to take also out the radio and center switch buttons, etc
Thanks
15 F06 640i xDrive Gran Coupe/Grey
04-05-2016, 09:04 PM | #98 | |
Where'd my VTEC go?
481
Rep 6,067
I don't know if the non-CA cars have it, but it just slips into a little plastic sleeve in the carpet between the two AC runners.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-06-2016, 12:11 AM | #99 | |
18
Rep 129
Very nice thanks! Found the guy. All that's holding me back from pulling the trigger is the wiring harness. Where could I find one? Making one is not an option as I'm not that good with electricity. |
04-06-2016, 01:26 PM | #100 | |
20
Rep 105
For 12 Euros I used 20 meters of this: http://fr.aliexpress.com/item/Hot-sa...221668328.html You can use the google.doc I provided before, I will update it for the pins to solder but I have a lot of work actually. You will have to connect also with the JBE on Fuse using 5 Amp. https://drive.google.com/file/d/0B8v...ew?usp=sharing Last edited by Pierre26; 04-23-2016 at 11:59 AM.. |
04-06-2016, 11:09 PM | #101 | |
18
Rep 129
04-07-2016, 11:40 AM | #102 |
83
Rep 353
I had someone make it for me and I paid him. I will ask how much he will charge and if he is willing to do it again.
04-07-2016, 11:24 PM | #103 |
18
Rep 129
04-07-2016, 11:46 PM | #104 |
91
Rep 254
I have Comfort Access but apparently the tinting of my windows messes with the electronics so its not sensitive at all. Takes 2 or three tries to get the doors to lock/unlock. I end up using my keyfob anyway. Wish it wasnt so.
04-08-2016, 09:20 AM | #105 |
30
Rep 124
Do you have mettalic tint? Many tints should be totally invisible to radio.
04-09-2016, 07:16 AM | #106 |
18
Rep 129
04-11-2016, 10:02 PM | #108 | |
295
Rep 2,203
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
04-12-2016, 08:03 PM | #109 |
18
Rep 129
