BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Vanos cold start fail after timing chain
proTUNING Freaks
      02-29-2024, 04:40 PM   #1
Timf91
Drives: BMW 328i, VW CC, Evo 8,
I recently purchased a 328i and after some research, i opted for a timing chain replacement. I finished up last weekend and everything on the car worked fine, except that I immediately got codes 131501 and 131401 with limp mode. I doubt both actuators failed while I was swapping the chain, so what other issues can I look for to determine the cause.
I replaced the chain and all the components and used the special tools. I checked timing multiple times during reassembly by cranking the motor and checking with the camshaft tools. I am going to pull the valve cover again tomorrow and check again.
Car otherwise starts runs and drivers fine. RPM idle in target range
      03-02-2024, 10:04 AM   #2
Timf91
Took off the valve cover, double checked timing and everything is still in spec. Removed and cleaned solenoids, bench tested actuators. They are all working. Still failing cold start test
      03-03-2024, 01:19 PM   #3
rhenier99
9
Drives: BMW 328i
I doubt this would work but you could try resetting the adaptation values and specifically the vanos adaptation, they might be off since you replaced the timing chain. The way I do it is through ista, and I think bm3 also allows you to do it.
fe7565552.50
      03-03-2024, 08:19 PM   #4
Timf91
I would need to go to a dealer for that I'm assuming? I don't have either software
      03-05-2024, 08:23 PM   #5
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
You can use either Esys (more difficult) or ISTA+ ($10 ENET cable for both) to reset the adaptation values. Some transmission and engine (DME) adaptation values can be reset by a combination of gas pedal, brake pedal, ignition, etc....do a google search.
If you go that deep into your engine, you should have ESys and ISTA+ anyways. The sub-forums have threads where you get access to the download links. Get ISTA+ "standalone" version and follow carefully the install steps. For ESys you do not need tokens as long as you do not FDL code. ENET cable is on eBay and Amazon.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
