BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      03-23-2024, 01:19 PM   #1
Kev7274
Drives: 2009 335i
Are 5 of 6 injectors really bad?
Watched a video about using a voltmeter to check the injectors. I set the multimeter to 200k and tested them. Readings are below...
Injector...
1 176
2 1
3 1
4 1
5 1
6 1
How accurate is this? I am throwing no codes and the car just has a little miss. I assume that the 1 on injectors 2-6 means the coil is open?
https://www.youtube.com/watch?v=TT0jeucc8xc
      03-27-2024, 03:10 PM   #2
KawBoy
Drives: 2012 E92 M3
I don't know the answer, but either you have 83% failure rate or 16% failure rate. Either way, S65 motors have 8 injectors. Just my 2 cents.
      04-02-2024, 04:15 PM   #3
RocketyMan
RocketyMan's Avatar
Drives: E53 X5, E83 X3, E93 M3
2008 BMW M3 E93  [10.00]
It's because this is the wrong forum.
The OP needs to post to the e90 section of the forum--not M3. OP you'll get a better answer there.
2008 BMW M3 E93 MT
R135
..246
m3post
