09-25-2013, 09:56 PM | #1 |
Rep 4
(please) HELP! Big problem after M3 suspension bits install
Had the following installed on my 2010 135i convertible by my VERY cooperative BMW dealer (a highly rated & very large racing oriented dealership) who has always played along with whatever I want to do to my cars:
- 4 springs (Eibach ProKit) - 4 shocks (the Bilsteins that come in the ProKit) - Upper AND Lower front M3 arms - front M3 sway bar - rear M3 guide rods - rear M3 subframe bushings - alignment As so many have reported, the car felt transformed. However, running 235 tires up front - at first the front tires hit the fenders & BMW quickly wound up installing springs from a 335is convertible up front (& leaving the Eibach Pro-Kit rears) This drove fine - the rear end was loose (& I liked it) & no rubbing. BUT, once the car stopped rubbing in the front, I could brake harder & I then noticed a BIG PROBLEM On hard braking - at any speed above 15mph, the rear end kicks out severely to the left. At speed (50-60mph) I darn near can't keep control of the car. At high speed it would be potentially deadly. I think it's important to note I can make it happen with the handbrake too - or by engine braking, though you need to be in lower gears to get that much decelerating force. At first I thought they screwed up the alignment (& still kind of do) - maybe only adjusting one side & that really one side in the rear is toed out. But they claim they've had the alignment re-done - & double & triple-checked by all their best techs & that it's right. And certainly seem to have sophisticated alignment equipment. (though whether they're checking the rear suspension loaded & unloaded to see if toe is changing when the weight shifts forward - I doubt it. Anyway, could it be a bushing is softer in one of the guide rods or one of the suspension bits than the other? or maybe one of the rear springs is a different rate that the other? Is there is some kind of alignment adjustment possible for bump steer?, Something else? I unfortunately only know enough to be dangerous. BMW Dealer wants to put on the rear springs from 335is convertible as they figure springs could be the problem… That theory seems odd to me but absent another explanation I'm at their mercy. What COULD this be? ANY HELP / thoughts would be VERY much appreciated… THANK YOU!! |
09-26-2013, 07:41 AM | #3 |
Rep 3,547
I don't understand why the stability control is not kicking in to prevent this (is it on?). But I would have them bleed the brakes. It would seem you could have air in a line on the right (and thus reduced braking).
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
09-26-2013, 08:57 AM | #4 |
172
Rep 2,347
I don't like that they mismatched springs on the car. I have a bunch of M3 bits my self and when I slam on the brakes the car stops straight no problem. Like JimD said you may have air in the line preventing the brake from biting hard. Also does anyone know the OP rear spring rates to the front ones?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
09-26-2013, 12:54 PM | #5 | |
85
Rep 2,438
09-26-2013, 03:17 PM | #6 |
Rep 1,267
Drives: AW 135i
Go to a super flat road, let go of the steering wheel and tell us which direction the car drifts to and how severly.
Build thread: http://www.1addicts.com/forums/showthread.php?t=748935
09-26-2013, 09:14 PM | #7 | ||
Rep 4
AND - it seems to me anyway that even with 2x4's or cotton balls in the rear - as long as both sides were the same - that the effect shouldn't be laterally. Or at least not to the same side all the time - if it were the front/rear mismatch, I could see it manifesting itself in one direction when the road was cambered one way - and the opposite way when the road was pitched oppositely - but it's always to the one (left) side. Does anyone know - is there any adjustment for bump steer on these cars? PS: really appreciate any & all thoughts/ideas Last edited by wespar; 09-26-2013 at 09:36 PM.. |
09-27-2013, 04:49 AM | #9 |
European Editor
10640
Rep 22,992
Have a second alignment shop look at your car. Sounds like something is loose or maybe you have too much toe on your alignment.
Also in the rear... those stock upper arm links will go bad over time. That can cause weird toe problems under accel or decel.
09-27-2013, 05:39 AM | #10 |
172
Rep 2,347
I bought new axle bolts when I got my car aligned the shop said they get real lose and can cause problems on cars with decent amount of miles on them
09-27-2013, 11:52 AM | #11 | |
Rep 4
I'd agree possibly a bad bushing in one of the new M3 arms or one of the new m3 subframe bushings could be bad? Seems unusual, but possible. The "something loose" I'd go for as well. |
09-27-2013, 06:01 PM | #12 | |
European Editor
10640
Rep 22,992
BMW Rear Guide Rod Kit - Better traction and handling http://www.1addicts.com/forums/showthread.php?t=223464 When you had your alignment was it out of specs? You should have another alignment done, by someone who knows how to check for worn out stuff. All the suspension bolts are a ONE TIME use. So I hope you also replaces all those bolts for the M3 bits. Could be one of those bolts has cracked IF your mechanic reused them. ??? Dackel
09-28-2013, 10:34 AM | #13 |
Rep 1,267
Drives: AW 135i
I know Bmw says these are one time use bolts, but i don't believe that. They don't yield when torquing, so to me they are reusable.
09-29-2013, 05:37 AM | #15 |
Rep 741
Drives: E87 130i
09-29-2013, 08:42 AM | #16 |
Rep 1,267
Drives: AW 135i
If the bolts weren't reusable they'd damage the threads and stay tight. Likely you didn't torque yours properly.
10-01-2013, 09:56 AM | #18 |
57
Rep 2,251
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
10-04-2013, 06:56 AM | #19 |
Rep 741
Drives: E87 130i
10-04-2013, 07:34 AM | #20 |
European Editor
10640
Rep 22,992
Update ???
The reason why BMW says not to reuse the suspension bolts is bc they are STRETCH BOLTS. Meaning once they are torqued down... they will get longer. Use them more than once... and they can break or loosen. This is why you always need to use new bolts when a manufacturer(BMW) tells you too.
I would also use some anaerobic Blue Loctite on those bolt threads. OP - What is the update on your suspension problem?
