BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Drag Times Compilation
      09-10-2019, 07:27 AM   #617
mslam02
83
Drives: 2020 330i M sport
Anyone on here running the MHD E40 (v7) tunes try the newer E30 v8? Which one feels like the stronger map? I'm headed to the track saturday and currently running E30 map. It feels very strong but wondering if I run a touch more e85 and the E40 map would be worth it? Thanks.
      09-10-2019, 08:15 AM   #618
NoGuru
NoGuru's Avatar
772
Drives: 335is
2021 Chevy Silverad ...  [0.00]
2002 Jeep Cherokee  [0.00]
2014 CTS  [0.00]
2011 335is  [0.00]
I am only running V8 because they are flex fuel maps. Not that you can't run them though, I am not sure about power differences.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
      09-10-2019, 12:12 PM   #619
Silent9n54
574
Drives: 2007 E92 335i
Originally Posted by flipmode View Post
Can I ask you how much your time improved going from v5 E40 OTS tune to your custom E50 tune? Also at what point did you add inlets? When you went with a custom tune? What was your best time running the V5 E40 OTS tune? I would like to hit an 11.6 run at 118-119MPH with just an E40 custom tune, but I think that maybe pushing it.
i ran a 11.95 @ 116 with a custom E40 tune, no downpipes , stock fuel pump
i added stg 2 fuel pump, inlets, and e50 custom tune ( same psi, same timing ) and i ran 11.5 @ 119
it is possible to run 11s with a OTS tune as my friend just did in his e90 2 weeks after buying it bone stock, fmic, downpipes, 275s street tires and stock 18s. He used a V5 E40 ots map as that one targets 21 psi and is by far the strongest e40 ots map. He ran 11.8 @ 117
he just did a custom tune with wedge that targets 22psi and 15 degrees of timing, and we are hitting the track tomorrow, so i will report the times we get.
2007 E92 335i / VRSF 5" FMIC-Charge Pipe-DCI-Inlets/ TurboSmart Plumb Back DV / XHP / E50 Custom Tune by WedgePerformance / APEX ARC8 / MT ET Street / 11.5 @ 119 / Instagram @silent11n54
      09-10-2019, 12:14 PM   #620
Silent9n54
574
try V5 E40 map, it targets 21 psi and its stronger than any v7 or v8 map, with the perfect setup and run its a 11.5 map
      09-10-2019, 01:31 PM   #621
flipmode
flipmode's Avatar
63
Drives: 2009 BMW 335i
For sure, keep me posted! I was averaging 11.5 degrees of timing during my 11.8@117MPH run, curious to see how 15 will be.
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
      09-10-2019, 02:19 PM   #622
mslam02
83
Not sure i want to mess with the desensitized knock tables, any thoughts/experiences on that? I do have inlets/outlets/DPs so the turbos would breathe nicely at 21 psi...
      09-10-2019, 03:27 PM   #623
Silent9n54
574
it was recommended by wedge as the strongest of the OTS maps, i dont think if would be accessible if it was a dangerous tune that could harm your engine.
mslam0282.50
      09-10-2019, 09:09 PM   #624
mslam02
83
fair point, i'll throw some more E85 in and try it out. Thanks!
      09-11-2019, 08:25 AM   #625
type-dRew
type-dRew's Avatar
641
Drives: 2009 335i xDrive
I run the v5 e40 map daily 105 miles a day, without all the recommended mods and beat the snot out of this car. Its fine.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50
11.61 @ 117.5
New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets
mslam0282.50
      09-12-2019, 12:37 PM   #626
Silent9n54
574
fun night at the drap strip even though track prep was pretty bad as everyone was spinning off the line
my best pass out of 3 is below
      09-12-2019, 12:48 PM   #627
flipmode
flipmode's Avatar
63
How did your friend do with his car? Did he run?
      09-12-2019, 12:58 PM   #628
Silent9n54
574
he did run but he was spinning every pass off the line so his best was a 12.1, the track prep just wasnt there and on the street tires was pretty much impossible to hook up.
      09-12-2019, 01:13 PM   #629
flipmode
flipmode's Avatar
63
Ok, I will be heading back to the track Sunday. I may lower my shift points from 6000 to 5800. As well add more E85 to my tank as I had my calculation wrong last time I went. I was more closer to an E30 mixture then E40........my bad
      09-12-2019, 01:32 PM   #630
type-dRew
type-dRew's Avatar
641
http://www.georgebelton.com/E85Calculator.php
11.61 @ 117.5
      09-12-2019, 01:44 PM   #631
Silent9n54
574
my best times are when i shift at 5700-5800
      09-12-2019, 01:51 PM   #632
type-dRew
type-dRew's Avatar
641
do you run 1st any higher or every gear about that?
11.61 @ 117.5
      09-13-2019, 05:22 AM   #633
flipmode
flipmode's Avatar
63
When I had my xDrive car, it was every gear including 1st and let 4th ride it out threw the end
      09-13-2019, 06:08 AM   #634
NoGuru
NoGuru's Avatar
772
Drives: 335is
2014 CTS  [0.00]
2011 335is  [0.00]
Mine is a DCT car with 2.56 final gear but these shift points or close to them started getting me faster down the track.
      09-13-2019, 06:22 AM   #635
type-dRew
type-dRew's Avatar
641
I do, just curious where everybody stops the fun in first.
I usually ride it to 6500 or more just because the gear is so short I like to make use of it.
Every other gear I shift at 6000 or before
11.61 @ 117.5
      09-13-2019, 01:21 PM   #636
Silent9n54
574
i launch in 2nd since mine is auto, i tried launching in 1st but that 1-2 shift is making the ET worse, i would probably need to cut a 1.4 or a 1.5 60 foot for it to be worth launching in first ( that wont happen with rwd ), plus the added stress on the tranny and axles with the 1-2 shift wont help... i stick with 5700-5800 for all gears but i stay in 4th, pass the finish line around 6300rpm
      09-14-2019, 08:00 PM   #637
mslam02
83
Hit the strip tonight...
E90 N54 XI AT Full weight plus amp + 10" sub, 200 lb driver
Mods:
-DCI
-CP + tial BOV
-inlets
-outlets
-5" FMIC
-Catless DPs
-MHD E30 stage 2+ OTS map
-XHP Stage 2 tranny tune
best was 12.46 @111 mph
60 ft 1.8192
1/8th mile 7.9271
1/4 mile 12.4662
111.38 mph
Misc:
-127k miles with original turbos
-Temp 68 degrees, 64% humidity, ~700 ft. elevation
-1st gear launches, couldn't get good power out of second (maybe my torque converter is slipping?)
type-dRew641.00
      09-14-2019, 10:36 PM   #638
Silent9n54
574
Mods:
-DCI
-CP + tial BOV
-inlets
-outlets
-5" FMIC
-Catless DPs
60 ft 1.8192
1/8th mile 7.9271
1/4 mile 12.4662
111.38 mph
Misc:
not a bad ET but the mph is a little low, usually 60 foots are a constant 1.6 1.7 with Xi but since u have subs and all that extra weight, it might be slowing u down a little.
maybe try V7 E40 map or the V5 E40 that targets 21 psi
and since you are AWD always launch from first
