2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Vacuum leaks? Looking at my fuel trims here
      03-08-2024, 09:16 AM   #1
ooihe92
Drives: BMW F10 520i
Hi car, my car is a F10 N20 520i
Mods :
1) Stage 1 hybrid turbo
2) Bar, plate IC
3) Ftp charge pipe, boost and turbo inlet pipe
Flashed to stock with stock downpipe atm to aid diagnosis.
What's been replaced:
1) 4xCoils & Plugs
2) New HPFP (LPFP is still the old one)
3) 4 new injectors
5) Maf sensor
6) A new set of 02 sensors
Long story short, as you can see, my car is drinking petrol. It has a LTFT close to 27%. Fuel consumption is very high. After replacing all items listed above, problem persists. It's PITA.
I was convinced my car must be suffering from a vacuum leak. Had it smoke tested, no leak to be found.
Judging from my photos, I was informed by a member here and the internet if your LTFT decreases as rev goes up, it means you have a vacuum leak instead of fuel delivery issue (I can rule fuel delivery out as I don't seem to have difficulty starting the car at all)
From my understanding as well, a vacuum leak post maf - throttle body isn‘t severe enough to give a +26% ltft fuel trim. What am i missing here? Assuming there's no leak and with the parts I replaced, can it be a faulty ecu?
5post
