06-29-2023, 01:00 PM | #1 |
35
Rep 47
Dynamic+ Sway Bar Kit for BMW F3X Now Available from 034Motorsport!
The 034Motorsport Dynamic+ Sway Bar Kit is available for BMW F2X and F3X Chassis. The 034Motorsport Dynamic+ Sway Bar Kit features perfectly-matched front and rear sway bars made from high-quality spring steel for maximum rigidity and durability. Designed to reduce body roll, improve turn-in, reduce understeer and enhance steering feel, 034Motorsport's Dynamic+ Sway Bar Kit is the ideal upgrade for those in search of confidence-inspiring handling on the street and track. Dynamic+ Sway Bars are available individually for those that are looking to upgrade in phases or match an existing customized suspension setup. TRACK-PROVEN HANDLING PERFORMANCE: The Dynamic+ Sway Bar Kit was thoroughly evaluated on the street and track with the 034Motorsport F30 BMW 340i before release to ensure they provided the most optimized handling experience possible.SWAY BAR BENEFITS: Dynamic+ Sway Bar Kit:The Dynamic+ Sway Bar Kit features perfectly-matched front and rear sway bars made from high-quality spring steel for maximum rigidity and durability. This kit contains perfectly-matched front and rear sway bars designed to reduce body roll, improve turn-in, reduce oversteer and enhance steering feel. 034Motorsport's Dynamic+ Sway Bar Kit is the ideal upgrade for those in search of confidence-inspiring handling on the street and track. By installing the Upgraded Front and Rear Sway Bars together, F2X and F3X BMWs will have the best balance of adjustability to dial in desired rotation and stiffness. Front Sway Bar: The front sway bar upgrade on the F2X/F3X BMW will dramatically improve the steering directness and reduce body roll. With three points of adjustment, dialing in your handling has never been easier. When installing the 034Motorsport Front Sway Bar with the Factory Rear Sway Bar, the increased stiffness in the front suspension will create more understeer and reduce oversteer tendencies in F2X/F3X BMWs, making the car more predictable and safe at the limit. Rear Sway Bar: The rear sway bar upgrade on the F2X/F3X BMW is designed to reduce body roll & understeer, while improving turn-in, rotation, and oversteer during cornering. Installing the 034Motorsport Rear Sway Bar with the Factory Front Sway Bar will provide the driver with an oversteer bias setup and would be great for those looking to have more rear-end rotation and “loose” handling! SWAY BAR FEATURES: Front:
Check It Out Here!
034Motorsport - Engineering and Manufacturing Performance Hardware & Software Upgrades for Audi, Volkswagen, & BMW Enthusiasts Since 2005.
YouTube // Instagram // Facebook |
06-30-2023, 10:38 AM | #2 |
24384
Rep 191,215
07-04-2023, 01:25 AM | #3 |
PdV Motorsports
121
Rep 165
Drives: 2014 335i xDrive sedan
What spring rates were used on the development car?
Ryan M. PdVMotorsports.com Owner https://www.youtube.com/@pdvmotorsports
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM |
mike082802115.00 |
07-05-2023, 10:18 AM | #4 |
204
Rep 383
Interesting option. Sort of in the range of the Dinan bar set it seems, with a slightly softer rear bar on it’s soft setting.
From my back of the napkin math it seems like it keeps roughly the same FR:RR bias as the OEM front bar + the 15mm rear bar(full stiff fr + full soft rr), and can be adjusted to have more rear stiffness bias. |
07-05-2023, 12:57 PM | #5 |
35
Rep 47
Our development F30 340i was on our Dynamic+ Lowering Springs, and spring rates are as follows:
-Justin@034
RbBugBitMe121.00 |
10-29-2023, 09:02 AM | #6 | |
204
Rep 383
11-02-2023, 05:18 PM | #7 |
Rep 3,541
They say compared to stock 340i rear sway bar, which is 12mm if base suspension or 13mm if M-Sport/Adaptive-M suspension.
11-03-2023, 02:52 PM | #8 | |
204
Rep 383
https://f30.bimmerpost.com/forums/sh....php?t=1418092 |
