BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > MHD "take a look at my log" thread
      06-07-2016, 09:50 PM   #23
jwebb335xi
Drives: 2008 335 XI
Originally Posted by BeastMode335i View Post
Hmm good call, I don't remember if I had it on or off now that u mention it.. However I did notice one time when I had it turned completely off, it still hesitated a bit when I went WOT from a 2nd gear roll.. I was under the influence that once it was turned completely off, there was no traction guidance at all from the car, was I wrong.. ??
my only thoughts are (and take them with a grain of salt) that (1) your load nearly matches load request very quickly, (2) boost matches target quickly, (3) load request and boost are a bit more conservative than some tunes, but (4) your AIT are climbing quickly.... roughly 115f to 160f. That may be why your machine isn't as crazy fast as you might like??
Still, from what little i have read, timing doesn't seem to be a problem and your turbos don't seem to be over stressed.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
      06-09-2016, 10:30 PM   #24
BayArea510
Drives: Stock 2008 535i 50k miles
2008 535i sport 48k miles completely bone stock.
I just replaced sparks and coils, I plan on flashing soon.
Can someone take a look at my log and let me know if it looks healthy enough to flash? thanks.
http://www.datazap.me/u/bayarea510/l...og=0&data=4-21
      06-09-2016, 10:51 PM   #25
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
What type of gas you using? Assuming 91 but will help the folks that read this. I only see some small timing pulls but wait for someone more knowledgeable.
If you dont mind me asking, where you at in the Bay?
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      06-09-2016, 11:12 PM   #26
BayArea510
I'm using 91 with a few gallons of e85.
I'm originally from Hayward, now I stay in Tracy.
      06-09-2016, 11:17 PM   #27
Banana Clipper
Jewel Runner
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      06-10-2016, 11:56 AM   #28
FIFTW
25
Drives: 2008 335i Coupe 6-speed
2008 BMW 335i  [0.00]
So, I've gotten these codes a couple of times so far, but only after I put in about 3gal of e85 (not sure what the actual percentage is, waiting on the gas co to get back to me but won't be using it again). 2c7e and 2c6a with 30ff code at 5k
My boost isn't hitting target either, but I haven't checked for leaks/solenoids, etc.
Stage 2 93oct v6.1 MHD OTS, 3rd gear pull.
http://datazap.me/u/335iguy/3rd-pull...7-19&zoom=7-94
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
      06-10-2016, 04:11 PM   #29
MHD Tuning
Germany
1978
Drives: M3F80#M5F90#340iF31#SupraA90
Originally Posted by E90Crack View Post
Please see my MHD E60 Wedge Custom tune below, mods in sig:
http://datazap.me/u/jsapudar/e60-wed...og=0&data=4-21
watch out for leaky injectors on bank1, AFR 1 seems lazy getting to 235 when backing off the pedal.
      06-12-2016, 07:18 PM   #30
dreyo27
92
Drives: 2007 335i e92
Originally Posted by cochran View Post
Could someone take a look at these two logs. I've gotten a misfire now twice on cylinder 6. I'm full bolt-on running MHD stage 2 v5
http://www.datazap.me/u/cochran/log-...og=0&data=4-22
DME codes that appeared when i scanned were: 29D2
Shadow codes were: 2AD0, 29F4, 29F5, 2AAF
on the first log your LPFP is barely holding on.
on the 2nd log you have RPM jumps. Also your bank 2 AFR is rich.. and differs too much compared to bank 1
      06-12-2016, 09:27 PM   #31
cochran
38
Drives: 09 335i (E90)
what is the solution?
2009 E90 335i
MHD Stage 2 | BMW PE | X-Pipe/Resonator Delete| K&N Drop-In |VRSF CP | VRSF 7" FMIC | VRSF DP's | Apex Arc-8
      06-14-2016, 07:15 PM   #32
JustDriveIt
Drives: 2007 BMW 335i Coupe E92 Black
http://www.datazap.me/u/justdriveit/...og=0&data=4-23
Anyone mind taking a look at this?
2007 Stock 93oct E20-25ish mixture
MHD V6.1 Stage 1 93oct Map
      06-14-2016, 08:54 PM   #33
rosullivan04
rosullivan04's Avatar
Drives: 2008 335i
A bit ago I was having problems with 30FF firing off on my car. This past weekend we did a boost leak test and it tested great with no leaks. All the vacuum lines are changed out on it and in good shape. It's running a charge pipe with a SSQV and DCI; I had to return it to stock for warranty work a bit ago and haven't added anything additional. It's also running MHD v6.1 Stage 1 95oct w/ E35. All the lines were taken off and tightened back up; the 30FF hasn't fired since.
I was able to get a good 2nd gear pull and most of a 3rd gear pull before someone pulled out in front of me. It definitely appears that I'm not going to where I'd expect boost wise. Does anything look odd in this log?
http://datazap.me/u/rosullivan04/tro...og=0&data=4-23
2008 335I 6MT
Tune by Wedge Performance
      06-14-2016, 09:14 PM   #34
rgfinn76
47
Drives: 2008 335i Sport Coupe
Finally loaded v6.1 Stage 1 and its a lot smoother than v5. I used to get a surge around 4k to 5k and now the power is felt throughout the entire RPM range..
Check it out and let me know your thoughts.
http://datazap.me/u/rgfinn76/335i-v61?log=0&data=4-24
      06-15-2016, 09:54 AM   #35
FastXTC
FastXTC's Avatar
Drives: 2022 G20 M340i
New plugs and coils from Bosch were just installed. Cyl 2 correction is zero with new and old plug/coil set (also Bosch). Corrections are present on other cylinders. No misfire, no code. Running Mobil 93 octane fuel. Fuel should be good, since Cyl 2 has zero correction?
Datazap log: 535i 6MT running 93 oct, stage 1, no FBO. ambient air 78F
I look forward to your comments.
      06-15-2016, 12:52 PM   #36
aohus
aohus's Avatar
163
Drives: 2010 Monaco Blue 335i
Just posting here. I'm a complete newb when it comes to cars.
My background is flashing android phones lmao.
Flashed to Stage 1 v6.1 91ACN. Stock everything. K&N air filter <-- aww jeah
http://datazap.me/u/aoh83/stage-one?....45&tmax=14.40
Any issues with the data log provided?
This car is a friggin beast. I don't see a need to go Stage 2.
Overall I am happy.
2010 E92 Monaco Blue 335i / Gray Dakota Leather / Steptronic / Sport / Premium / Navi / L7 / 18" Performance Wheels / HPFP fail @ 8400 miles (replaced with #933 pump) // MODS: Mishimoto OCC | VRSF CP + Turbosmart Dual Port BOV | RB PCV Valve // Maintenance: Walnut Blast @ 56k | Spark Plugs Replaced @ 56k | Addons: BN2000 Combox // Andream Carplay // Rear Camera // Spark Plugs (.022 gap) and Coils Replaced 73.1k
2019 G01 Carbon Black X3 M40i / Premium / Driver Assist / 21" on Bridgestone Alienza RFT
      06-15-2016, 01:07 PM   #37
89mustaine
Stuff and Things
89mustaine's Avatar
Drives: E60 535i Sport W/SAT MHD
MHD stage 1 91oct
DCI, muffler delete, no other performance mods
I've been getting 30ff during long pulls, get the half engine light and reduced power message. On one log it happened around 4500rpm, on the other log it didn't pop up but the car felt slow. Seems obvious Im not making as much boost as I should but I'd like some insight as I'm not an expert at reading these logs
http://www.datazap.me/u/89mustaine/l...og=0&data=4-23
http://www.datazap.me/u/89mustaine/l...og=1&data=4-23
Last edited by 89mustaine; 06-15-2016 at 01:17 PM.. Reason: attachments didnt work
      06-15-2016, 01:07 PM   #38
gxmac
35
Drives: 2011 335is coupe
First time posting but long time lurker. I am pretty new to logging and would like some feedback on my log. I am FBO + inlets running 93 oct.
Flashed Stage 2+
http://www.datazap.me/u/gxmac/log-14...data=1-4-16-21
Car seems to be running fine other than the occasional rough idle on startup.
Much appreciated.
      06-15-2016, 03:14 PM   #39
JustDriveIt
7 logs posted, 0 read. Ha, I thought there were more people who knew what to look for. It's an art!
      06-16-2016, 08:34 AM   #40
davidwarren
davidwarren's Avatar
187
Drives: 328,325, 325, 335, X5, 640 GC
I have a third and a fourth gear log. I had a 30FF at the track, but seems to have resolved itself after a couple days. I have new solenoids on order to rule those out. Replaced solenoids and vacuum lines last summer after same issue on the track.
3rd- http://datazap.me/u/davidwarren/log-...=0&data=4-6-23
4th- http://datazap.me/u/davidwarren/log-...=0&data=4-6-23
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
      06-16-2016, 12:26 PM   #41
aohus
aohus's Avatar
163
Does anyone on this thread with expertise look at these logs? Would be great if someone with knowledge contributed
      06-16-2016, 01:17 PM   #42
Turducken82
Drives: 10' E90 335i AT
335i E90 10' AT
91 OCT
61880 Miles
Michlien PSS AS
STOCK
oil changed every 10k
plugs, coils changed at 30k and 60k
Please take a look
http://datazap.me/u/turducken/single...og=0&data=4-21
When accelerating between 2k-3k RPM the car has a little "jutter" in low and high gears.
Other than that she's a dream to drive.
      06-17-2016, 06:38 PM   #43
dreyo27
92
Originally Posted by Turducken82 View Post
335i E90 10' AT
91 OCT
61880 Miles
Michlien PSS AS
STOCK
Please take a look
I think that is normal on a tuned car... in lower RPMS. just timing drops
      06-17-2016, 06:43 PM   #44
dreyo27
92
Flashed Stage 2+
Much appreciated.
It looks perfect. you had a minor correction on cyl 6. But yeh very good for an OTS map especially since your IAT got into the 120s and it was a gas map.
