steering phantom play/pulling randomly
06-29-2023, 01:45 PM | #1 |
Rep 5
Drives: BMW 323ci e46 TopasBlau, BMW 3
Hi fans!
I have a phantom failure with the car.. The car is bringing me to hell….. Synthomps: Steering playing 2mm left to right back and forth. When i steer to the right, it keeps pulling to the right and the wheel not coming back to straight. Also the same when i steer to the left.. VIDEO: https://youtube.com/shorts/6j8IK2YEngk?feature=share When i caught these problem: Every suspension part changed fully few days ago Sachs suspension M sport springs Lemforder meyle parts Brand new Ate brake set 8months old Rear Ate brake set 2months old Wheel aligment on hunter machine with double check. I drive on 19 inch and ive also tried another 18 inch set. Is it a steering rack problem? On highway speed the brake slightly shaking( 140kmh ) Thanks! Bruno🔵 |
09-08-2023, 09:30 AM | #3 |
Rep 5
-Brand new tires
-new steering rack -new engine mounts 2x aligment And the car still pulls to the right steering wheel keeping left… Any advise. This car is a freekin demon…😅 |
09-09-2023, 05:53 PM | #4 |
81
Rep 242
Lower steering shaft u-joint might be stiff, which would keep it from returning to center properly. Can spray with lubricant to see if this helps, but usually that's only a temporary solution. The lower steering shaft bolt has been reported to be loose in some cars, although if you just had the rack replaced, this should have been tightened properly during that. Maybe the upper bolt in that case?
12-01-2023, 01:36 PM | #5 |
Rep 5
Still struggling with the problem.
Still tramlining on wavy surface, wandering on the motorway 120kmh+ 2023.10 -new winter tyres -new steering rack -new front right HUB - 2 new rear front arm Aligment details: left-right Front Camber -00.41 -00.32 Toe 00.05 00.05 Caster 06.50 07.00 Rear Camber -01.42 -01.38 Toe 00.08 00.09 The suspension diagonist/aligment pro said maybe a damper problem no other clues Any ideas? 😄 |
