02-28-2024, 10:57 AM | #177 |
272
Rep 298
just wanted give closure to this thread. I sold the engine. The person i sold it to, confirmed that main bearing 1 failed cracking the saddle and causing rod bearing 1 to spin.
spammysammich1583.50 CSBM52721.00 Assimilator1593.00 Ajolives922.00 javarithms193.50 akkando5864.50 Robocop30512.00 |
02-28-2024, 11:11 AM | #178 |
Rep 1,104
Drives: 2009 E92 M3 Dakar Yellow II
Brutal, thanks for the follow up!
02-28-2024, 01:01 PM | #179 |
Rep 1,026
Drives: BMW M3 e92 08 & 330d e90 10
Ditto, thanks for updating us (and the excellent quality photos too).
I'll update the blown engine list. RIP the S65 .
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
02-29-2024, 08:55 AM | #181 |
62
Rep 145
I was looking this thread and realized that this might have been the same failure i experienced. My motor let go out of town in 2018, lucky me I had extended warranty, it was covered (new engine). My front 2 rod bearings spun, maybe from main bearing failure? That's in the past now, I'm on my first set of BE's on the new engine(140k now).
03-10-2024, 09:12 AM | #182 |
128
Rep 195
Went thru the entire thread..
There just seems to be no way to definitively prolong rod/main bearing life with these motors.. seems like a roll of the dice as some motors last over 200,000 on original rod/main bearings & others don’t even make it to a 100,000 inspite of taking proper care.. Wonder what the M division does differently that the bottom end of S65, S85 & S54 don’t last while you never hear such stories with AMG or RS or other marquees.. |
Robocop30512.00 |
03-13-2024, 02:51 PM | #183 |
Rep 1,026
I thought the S54 was fixed with the bearing update/revision by BMW?
S65 main bearing failure is much rarer than rod bearing failure, we can at least sort the the latter out relatively easy and cut the risk significantly of engine failure. See the 3rd link in my sig of mains vs rod bearing failure reported to this forum.
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 03-13-2024 at 03:08 PM.. |
Robocop30512.00 |
03-13-2024, 02:58 PM | #184 | |
Rep 1,104
03-13-2024, 03:08 PM | #185 |
Rep 1,026
Lol
I've read very little about the S54s problems, just seen a couple of people claim that the updated bearings fixed the S54s rod bearing problem. I already spend far too much time reading, discussing and arguing about S65 bearing issues, I don't want to go do another rabbit hole! lol Is there a single good experienced source here or elsewhere about the S54 bearing story?
03-13-2024, 03:23 PM | #186 | |
Rep 801
Today, S54s will spin rod bearings, but not *that* often. Considering the nature of the engine, the S54 has proven to be pretty incredibly reliable. It just has the reputation due to the early teething issues.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
Assimilator1593.00 |
03-13-2024, 03:34 PM | #187 |
Rep 1,026
Are todays S54s which have spun bearings due to bearing failure, or something else?
03-18-2024, 05:52 PM | #188 | |
Rep 801
Also, consider replacing / rebuilding the oil pump. It's absolutely a wear item.
03-19-2024, 04:17 PM | #189 |
Rep 1,026
To name just one other, the Honda S2000 has a high revving engine too (8.2-9k RPM depending on variant) and they don't have rod bearing problems (where it's not caused by something else). I hear the R8s also don't suffer RB problems either, but I've not looked into that one.
Anyway, my point is, just because it's a high revving engine doesn't mean it should wear out the bearings prematurely. Rod bearings are not meant to be a wear item! But for some reason they are on the S54,65 and 85s. Any idea why the S54s wear them out? Interesting to hear about the oil pumps on the S54s, perhaps that's why the bearings fail?
03-26-2024, 01:34 PM | #190 | |
Rep 801
And no, I don't attribute most failures to the pumps.
03-26-2024, 04:03 PM | #191 |
Rep 1,026
I didn't say the S2000s have no rod bearings failures, see the bit in brackets in my previous post .
(Although I recently stumbled across an old post (2016) here in a BE bearings thread by Rajmun claiming in the late 2000s that some S2000s were suffering some RB failures without other mechanical faults. But when I looked for cases a few years ago they were very rare, and all caused by other issues, e.g oil pump failures (ironically). Re S54 oil pumps, fair enough.
Robocop30512.00 |
