03-18-2018, 07:55 PM | #1 |
18
Rep 54
Buying wheels this week, please peep my specs
I just wanted to confirm my final wheel and tire size before pulling the trigger. If you guys wouldn’t mind taking a look and making sure I won’t rub or poke out past the fenders. I do plan on lowering.
2013 335i XDrive - stock m sport wheels square setup now Wheels I want are 20x8.5 et 30 square Tires I want are 245/35/20 I live in the northeast so I don’t mind a little extra rubber. What do you guys think? Any pics? |
03-18-2018, 08:03 PM | #2 | |
Rep 3,680
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
03-19-2018, 08:49 AM | #3 |
18
Rep 54
Thank you! Nice wheels!
I am also now considering 255/30/20. This will keep almost the same diameter as stock. These should fit fine on the front... right? |
03-19-2018, 12:00 PM | #4 |
Rep 3,680
thank you! yes, 255/30/20 tires should fit fine front and rear.
03-19-2018, 12:03 PM | #5 | |
Rep 4,367
255/30/20(max width on 8.5") is 26"(oem) diameter however the tire shoulder will be poking more than the 245/35 and again, there may be a possibility or the outer shoulder rubbing the front fenderwell liner because of 255's width and +30 offset. i'm not sure which will be closer in rubbing at full lock but personally, i'd go with the 255/30. down sizing a notch to 245/30/20(25.8") will fit without any problem. adding negative camber will mitigate rubbing and can be added during alignment and also increases as you lower your car EDIT: Sorry, fixed the link Last edited by alohasurftoad; 03-19-2018 at 01:09 PM.. |
03-19-2018, 01:41 PM | #6 | |
18
Rep 54
Thank you! The wheels I am getting have a step lip, so the 20s end up looking more like 19s. 19s would just be too small for this car.
I guess at this point I'm just looking for anyone with a 8.5 wide front wheel and a +30 offset to let me know if they have ever ran a 255/30/20 Thanks again Quote:
20”, 335, bbs, wheels, xdrive |
