04-03-2024, 11:32 AM | #1 |
Rep 6
Chassis Function Restricted Coilovers w EDC Delete
Hey,
I recently installed a set of coilovers on my 340i EDC, with them, I used Kw's EDC delete kit and now I keep getting this code stating "Chassis function restricted Drive moderately."Is there a problem with the EDC delete module? Has anyone else had this problem? Should I just clear the code and not worry about it? Thanks. |
04-03-2024, 02:02 PM | #2 |
Rep 787
You shouldn't be getting this code. I would check all your wiring and run through the installation steps again. The kit is supposed to have the car running error free, just without the edc function.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
04-04-2024, 03:10 AM | #3 |
Rep 8,514
They should be plug-n-play.
Either one (or more) of the EDC deleted hasn’t been connected proper, or is faulty. I’ve run deletes with my Ohlins R&T for years. One developed a fault after the first year(ish) and the chassis fault message disappeared as soon as I replaced it.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
