01-24-2024, 05:33 PM | #23 |
Naval Aviator
605
Rep 680
Redd Concur on NRW inline fuel filter. Planned near-term PM/upgrade along with new Bosch injectors.
Actually, an early NRW products adapter; their valve covers with silicone grommets. So-far ~3K of spirited driving - - no issues, leaks, all clean and pristine.
e92 M3 - Interlagos Blue | Recaros w/Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK Last edited by smokinjoe64; 01-24-2024 at 05:39 PM.. |
04-16-2024, 04:58 PM | #24 |
50
Rep 171
So with something like this could I just install it along with new injectors and be all set? Or would I have to also change the fuel pump and fuel filter in the gas tank?..
I just got an e92 with under 50k miles but seeing the other user above blow his engine due to this issue at 60k miles is making me want to err on the side of caution. |
04-19-2024, 03:51 PM | #26 |
130
Rep 197
Bought & test installed NRW in line fuel filter, it’s high quality but the fitment is not OEM level given the tight space, filter bracket runs against the plastic ignition coil cover & the flexible fuel line to the rail needed to be relocated & twisted beyond my comfort level, also said rubber fuel line now sits closer/in the way of significant radiant heat from the driver side exhaust header.
I know some people have installed these & are happy, I personally wasn’t comfortable, so removed it. Another thing is, the NRW or similar fuel filter should not be considered an alternative to replacing fuel injectors at regular intervals as they may already be clogging up as most cars have 50,000 miles or greater.. I wish the NRW filter were smaller in size, it would fit so much better.. |
