06-03-2017, 11:44 AM | #1 |
94
Rep 349
Downpipe Install
Does anybody have a DIY for this that works? All links I found aren't working. Also, I read about some gaskets that are needed, what gaskets are all needed? I see turbo to downpipe connection is just a clamp. Any info would be great!
14 Space Grey CP M5 / CCB / Exec / etc
BMS Stage 1 / Charcoal Delete / K&Ns / Catless OEM DP & Borla S-Type Catback |
06-03-2017, 04:53 PM | #2 |
Rep 608
06-04-2017, 01:49 PM | #4 |
Rep 892
They're held on with rubber grommets like the engine cover; just pull them away from the metal brace running over the engine, then you can access the 4 bolts that hold down the same brace.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
06-04-2017, 02:44 PM | #5 |
Rep 1,799
What the above poster said. They are held in with rubber just pull them off the mounting plate and use a bungi cords to pull them back as far as possible while installing the dps.
06-04-2017, 03:28 PM | #6 |
94
Rep 349
Oh ok, so don't have to unplug the plugs from ECU? Just pop it away from the metal brace using a plastic pry tool maybe?
06-04-2017, 03:30 PM | #7 |
94
Rep 349
Also how important is costing the Downpipes? I see many running them uncoated but some say it's a must because of the heat to the back cylinders. I don't do any road racing or anything like that, so wondering if it's needed.
06-04-2017, 08:46 PM | #8 |
644
Rep 2,039
The walls are thinner on aftermarket pipes...youre better off with coating or header wrap. Some of the heat difference is offset by not having the friction of cats, so there's that small benefit. The main reason to do DP's is sound!
06-08-2017, 01:37 AM | #9 | |
17
Rep 63
Can DP's (catted or no cat) installed without a ECU tune? Would stock software deal with the more free flowing DP? It should boost power without a tune right? |
06-08-2017, 01:21 PM | #10 |
94
Rep 349
Yes, stock ECU will adjust after about a tank of gas..from my understanding at first it may feel sluggish but as it learns/adapts it will pick up a good bit of power/torque on the midrange. Obviously an ECU Tune/Flash will give the biggest benefit paired with Catless Downpipes. Mine will be going on this weekend! Get them back from ceramic coating tomorrow.
06-08-2017, 08:55 PM | #11 | |
17
Rep 63
06-14-2017, 06:03 PM | #12 |
94
Rep 349
Just finished the downpipe install yesterday.
Long story short, the downpipes I bought and had ceramic coated didn't end up fitting right so I am returning them. I kept seeing threads pop up about gutting the OEM downpipes, so I did the same. Super simple to do, used a 1" Spade Drill Bit that was 16" long and drilled a couple holes through the catalysts. Then used a giant flat head screwdriver and a hammer to chuck away at the material. Very simple to do! Before: After: So far I've started up the car, and it sounds absolutely AMAZING!! The cracks after revving it up are brutal, neighbors will definitely not be happy after this mod Will take some vids once I go for a drive (tire caught a nail pulling out of driveway for test drive).
06-14-2017, 09:20 PM | #14 |
Rep 523
06-14-2017, 11:39 PM | #15 |
94
Rep 349
06-16-2017, 11:04 PM | #17 |
Rep 523
06-17-2017, 06:52 AM | #18 |
30
Rep 232
Thanks for the post. You're car is now definitely louder with the decatted dp's than with the cats and exhaust, but is it obnoxiously loud? I'm tempted to do this, but don't want a drony obnoxious sounding car. I now have a Supersprint Race Exhaust, which sounds good, but I was hoping for slightly a little more bassiness of a V8 rumble.
06-17-2017, 10:32 AM | #19 | |
94
Rep 349
Mkai030.00 |
03-19-2020, 09:17 AM | #20 |
Rep 10
Full instructional Video (Including special tools, parts, torque specs and skill level) on how to replace the downpipes on an M6. Its the same procedure for an M5 and very similar to an N63. Feel free to comment opinions or questions. Special tools: Torque wrench, stubby 6 mm allen and multimeter, E-Torx sockets Parts: Downpipe to exhaust gasket ring- (2) 18307843213 Turbo charger to downpipe gasket ring- (2) Downpipe to exhaust nuts- (4)18307597650 Torque specs: Turbo to downpipe V-band-19mn Downpipe to exhaust nuts- 21nm. Skill level: (1 easiest, 5 hardest) 2 Fernando Osorio President Milestone Motors LLC Website: https://www.milestonemotorspb.com/ Instagram: https://www.instagram.com/milestonemotors/ Facebook: https://www.facebook.com/Milestonemotorspb Email: milestonemotorsllc@gmail.com Linktree: https://linktr.ee/milestonemotors Snapchat: Milestonemotors Fabworx downpipes can be found here: http://fabworxperformance.com/produc...ownpipes-2012/ |
