02-08-2021, 10:18 AM | #1 |
Rep 23
F30 N55 stuttering before shutting off in 'N'
Hi, I was driving my f30 335i xdrive and I parked the car to run into a store and left the car running, 2 minutes later I come out and there is light smoke coming from the kidney grilles, I open the hood and the smoke went away and I didn't smell anything. The car temp was at its optimal temp, not overheating or anything. Anyways, I go to another store shut the car off and it turned off no problem, everything was fine. I get home and decide to put the car in N and pull the parking brake thinking the car will automatically go in to Park. I turned the car off in N and the engine started to stutter at around 500 RPM for a second then shut off but never went into P, I had to manually press P. I turned the car on with the hood open and here a small ticking sound and I am not sure if that's normal or not as I recently got the car. If anything strange happens again I'll take it to BMW so they can take a look. Please let me know your thoughts. Thanks
02-08-2021, 10:29 AM | #2 |
Rep 10,306
Remote diagnostics are rarely helpful without additional data. Can you share more information?
- Current mileage - Did you have a chance to scan for any stored fault codes? - Any tunes present? - How often was the oil changed? - Maintenance history: spark plugs, ignition coils ... |
02-08-2021, 10:32 AM | #3 |
Rep 16,157
An OBD diagnostic tool is a must have item. When you take the car to the dealer it's the first thing they use, and they'll charge you $150 to do so. FWIW I never put the car in neutral. I turn off the engine while still in D or R, the car puts it in P.
02-08-2021, 11:40 AM | #4 | |
Rep 23
335, f30, n55, problem, smoke, stuttering |
