03-07-2021, 02:49 PM | #1 |
117
Rep 140
H&R VTF lowering suspension
What do you all think about H&R adjustable lowering springs? What I'm looking for is stock like ride while eliminating wheel gap mainly in the front. I have a F80 Comp with 666 style wheels. Any thoughts on these springs?
I'm possibly considering these springs or maybe M performance adjustable lowering springs. Any thoughts and experiences with either? |
03-09-2021, 09:49 PM | #2 |
86
Rep 52
H&R VTF
My car is running H&R VTF springs set at about mid height. 15mm spacers in front and 12mm spacers in rear. Front spacers are necessary to clear the springs with ZCP 666. Ride is slightly firmer than stock and still have use of EDC. I am taking them off this week to install MCS 1WNR for the track. They will be for sale, less than 2500 miles on them. PM me if interested.
papasmurf_m3454.50 |
03-11-2021, 04:12 AM | #3 |
Rep 646
The H&R VTF-kit has 28% stiffer front springs and 13% softer rear springs compared to the stock Competiion springs. That might give you an indication of how the car will behave. A bit stiffer up front which is good when the car is lowered but slightly softer at the rear for Comfort. This gives the car a slightly more built in understeer.
03-12-2021, 12:40 PM | #5 |
Rep 646
02-17-2023, 08:32 PM | #6 | |
Rep 844
Do you know what the minimum amount is to clear the ZCP 666m wheels? I have 12mm front / 10mm rear right now.
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
01-22-2024, 08:20 PM | #7 | |
Rep 502
01-22-2024, 09:20 PM | #8 |
Rep 5,792
You want to go lower than that on oem dampers? You do realize the f8x front suspension travel is limited at stock ride height so lowering the front by >> 25 mm means you値l be constantly riding on the front bump stops? Just because a specific HAS design may allow you to run lower than another HAS design doesn稚 mean you should actually run lower.
01-22-2024, 09:46 PM | #9 | |
Rep 502
01-22-2024, 10:22 PM | #10 | |
Rep 5,792
01-22-2024, 11:10 PM | #11 | |
Rep 502
01-29-2024, 09:54 AM | #12 |
Rep 646
02-03-2024, 11:52 AM | #14 |
24353
Rep 191,163
I have been using it on my M4 for years and I'm thrilled with it.
The VTF will be my first suspension choice with any future car i get.
