02-08-2022, 04:51 PM | #1 |
16
Rep 81
Drives: F30 328i 2012
Fault codes n20 328i
Hey,
Struggled to find anyone who has had this issue via google so thought I would ask here. Codes; - 420665 - 8044B0 What it could be? Everything works fine (paddle shifters, speed limiter, volume buttons, etc..). Tried to clear the fault codes and they appeared again after a few minutes. I have new agm (oem battery). What can I do next? |
02-08-2022, 05:59 PM | #2 |
Rep 1,069
8044B0 Shift paddles: Short circuit to B+
420665 Shift paddle: (shift paddle operation, 0x207) signal invalid 134249 yes Information
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
02-08-2022, 06:10 PM | #3 |
Rep 1,069
8044B0 Shift paddles: Short circuit to B+ 134249 yes
420665 Shift paddle: (shift paddle operation, 0x207) signal invalid 134249 yes Information I don't really know but I'm good with internet searches. Good luck !
03-16-2024, 12:23 PM | #4 |
Rep 15
Hey, I had the same problem and same error codes - which were a real mystery for me as shifters worked well. I've found out that it might be related to a clockspring wires or even FEM which are quite expensive in comparison to just puddles. Luckily after paddle shifters replacement codes are gone. I've cleared errors and tested it for a while everything works perfectly fine.
P.s. Airbag removal is a pain in the a** so if you've never did that and you want to try to change PSs prepare for a real battle. Good luck guys! |
