Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 Rough Idle / Performance Issues
      09-26-2016, 08:32 AM   #133
PhaseP
1009
Drives: 325XI
Dude you had 2D06 code right? That indicates either faulty Maf sensor or electrical connection to it is bad. My understanding this code means computer received a value from sensor that corresponds way too much air , like impossible amount. You in the past replaced your sensor and didn't cute it. So why don't you try the most obvious clean or replace your electrical connector?
      09-26-2016, 02:43 PM   #134
alx.
alx.'s Avatar
41
Drives: F30 320iA M Sport
2006 e90 325i  [0.00]
Hi Phase, the connector looks good, it doesn't look faulty and the old MAF throws no code, only when i plug in the new maf do i get 2D06. This points to a vacuum leak or perhaps a bad valve.
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold
Bmw 3-er e90 325i '06 - Sold
Bmw 3-er e92 325xi '08 - Sold
      09-26-2016, 04:01 PM   #135
PhaseP
1009
Drives: 325XI
The connector will look good, you cannot judge by its looks. I had similar problem if not same symptoms like you, didn't suspect the connection tried lots of other things and eventually found for good that it was the electrical connection. It has been 3 weeks I replaced my Maf connector housing and cleaned the pins real good in the process and I have had no issues since.
There are four things going on I believe: the internal springs of the pins get looser as this connection is undone and done due to it being on the way for many jobs to work on the car. The second the connector housing also gets s little sloppy in there again for same reason. Third by time some corrosion, dirt, oil later builds up on the connections, you cannot visually see these. Fourth the MAF connection side pins look too thin to me from production to give good contact.
A good cleaning with a good purpose contact cleaner cleans them up. Opening the connector housing allows full access to the pins for cleaning.
My two cents, easy to test , and I believe many of those complaining about idle issues may be easily fixing them with this.
Vacuum leak will cause lean codes.
      09-28-2016, 03:09 PM   #136
alx.
alx.'s Avatar
41
Took the intake off today and the valves looked extremely clean. Intake is crack/leak free. Also checked on the DISA valves and they are very stiff(they don't have any play or move at all). I was thinking about the ECC or perhaps the fuel pressure regulator / fuel filter as i doubt they have been changed.
      10-03-2016, 03:28 PM   #137
alx.
alx.'s Avatar
41
I'll go ahead and fix the maf connector. In the meantime, anyone know if the bosch spark plugs part # 0242236510 are any good for these cars? I did not gap them, mind you.
I understand that could be an issue, can anyone tell me if ngk code # ILZFR6D11 come pre-gapped?
      10-04-2016, 11:18 AM   #138
alx.
alx.'s Avatar
41
Apparently the spark plugs i installed have a 0.4 inch gap(1 mm) which would be the correct specification.
      10-04-2016, 01:42 PM   #139
Suhb
Suhb's Avatar
119
Drives: 2010 128i Coupe 6-Speed
Newest plug for our engine is lzfr6ap11gs
Gap is 0.044
They come pregapped and are not recommended to be altered with
      10-04-2016, 03:17 PM   #140
alx.
alx.'s Avatar
41
Gap is 0.044
These would 100% fit my 2007 n52 325i?
      10-30-2016, 09:30 AM   #141
alx.
alx.'s Avatar
41
To update everyone: this issue was finally fixed after changing the MAF sensor AND the fuel pump. Car now runs stronger than ever with no rough idle.
Cliffs on what was changed in the past year:
- Coils
- Spark plugs
- Both solenoids brand new
- MAF
- Fuel pump
- o2s pre cat
- PCV + hoses
Total price of the above parts was around $1000 including labour.
What i'll do next: Valve stem seals next week as the car smokes and eats a lot of oil. Around 500 ml/1500 KM.
In romania the price for the stem seals replacement will be around $207 usd with parts and labour.
All in all i'm pretty satisfied with the car.
      11-25-2016, 12:42 PM   #142
alx.
alx.'s Avatar
41
Valve seals are here
Will come back with reviews about the oil consumption.
      02-01-2017, 01:19 PM   #143
lwarren0074
Drives: 2007 328i E91 Sport Wagon
Rough Idle - Ideas needed
E91 – Sports Wagon / Engine = N52K
Feb 2017 – 144,000 miles; 95% Freeway daily driving; Always top-tier gas; Pulls strong so I don’t suspect a vacuum leak.
Symptoms
1st: Every once in a while the car would shut-off after driving freeway speeds and then coming to a stop. Either after exiting the freeway at a stop light, or stopping due to traffic on the freeway. A real PIA. No codes, no lights
2nd: One day the car was idling low and vibrating hard upon start-up. The check engine light came on and I was able to limp to a Firestone to get the code read. If I remember correctly it was P0012 ‘A’ Camshaft Position Timing Over-Retarded (Bank 1). They were able to change the Intake Camshaft Sensor and I was able to carry-on the next day.
Secondary Symptoms
After having the Intake Camshaft Sensor replaced, the car seemed to idle a bit lower, and shut-off twice. Once due to low idle and the second after coming to a stop on the freeway due to traffic. It then idled hard through traffic, but didn’t notice much once traffic was moving again.
But the car was harder to start. With a newly replaced (< 1year) starter, the car had a few “ka-ka-ka-ka-Vroom” upon start-up. Where before it would immediately start-up. No codes, no lights.
Possible remedy
After reading the posts about VANOS solenoids, rough idling, and the like, I cleaned and swapped the VANOS solenoids. This was my first thought because since the oil filter gasket was leaking, it had been throwing tiny specs of oil for some time and collecting dirt all over the VANOS connections and gaskets. I figured that over time those gaskets may have corroded some and that oily dirt may have found its way inside the VANOS causing my problems. I was able to blow out what looked like gunk from the solenoids, but maybe just specs of oil.
Results
After cleaning and swapping VANOS, the car immediately fired up like it used to before. The next morning it had a little slower start, but not like before. Solved? I guess only time will tell. Double checked the hose connections around the MAF and throttle body and it’s all tight.
Help from the Community
Without throwing money at random sensors and parts, does my experience mirror anyone else’s? I am considering changing the Exhaust Camshaft Sensor because changing pairs of sensors always seems to be better. Please, throw out some ideas.
2014 Repairs
Battery replaced
2015 Repairs
1 of 6 coils replaced
All new spark plugs
Starter replaced
K&N filter installed
Regular oil changes
      02-06-2017, 11:50 AM   #144
alx.
alx.'s Avatar
41
Symptoms
Secondary Symptoms
Possible remedy
Results
2014 Repairs
Battery replaced
2015 Repairs
All new spark plugs
Starter replaced
Regular oil changes
Sounds like a maf issue to me, specially if it turns off and you have a rough start. Try cleaning it with some maf cleaner, it's very easy. If not, i purchased new solenoids(i don't believe in cleaning them and swapping). How are the cylinder readings? Download INPA and check them at idle and during driving.
      02-07-2017, 11:27 PM   #145
BMW 420i
rollin rollin rollin
BMW 420i's Avatar
Drives: '08 328i
Symptoms
Secondary Symptoms
Possible remedy
Results
2014 Repairs
Battery replaced
2015 Repairs
All new spark plugs
Starter replaced
Regular oil changes
Sounds very familiar. After doing what you are doing, my problem turned out to be the plastic mesh filter holder in the oil filter housing cap. If that is missing or the little o-ring is pooched it doesn't seal to hold in crankcase pressure at low idle and starts throwing cps/vanos codes, causes stumbling idle, stalls while stopping. Check it, it's 2 minutes and can save you a lot of money.
      06-27-2018, 04:38 AM   #146
tpmmazo
tpmmazo's Avatar
26
Drives: E91 328i 6MT ZSP
What part exactly are you reffering to. I have high crankcase pressure and vanos codes and stalling coming to a stop after replacing the pcv valve.
      06-27-2018, 03:39 PM   #147
Saico
30
Drives: 330xi
@alx. Did you finally replace valve stems? Did it help with oil consumption?
      01-10-2019, 04:02 AM   #148
juld0zer
Australia
482
Drives: Prev 135i 7DCT, Now 130i 6sp
The middle part of the oil filter cap.
      01-10-2019, 04:47 PM   #149
Thebimmer57
Drives: BMW 325i e90
So whats the cost of an ecu upgrade from bmw outside warranty, anyone know?
      04-14-2024, 11:19 PM   #150
rizah
Drives: 2009 328i
(Doesn’t let me show vid pictures in order of vid)
Would this be camshaft position sensor?
Or is this cylinder missfire
