05-03-2024, 12:58 PM | #1 |
Rep 467
8.8 screen replacement?
Folks, can someone confirm if there is a specific model screen I need as a replacement? I see some screens listed as non-touch screen vs touch screen. To be honest I have no idea if mine is a touch screen, as I just realized that I always used the controller. Is the touch screen LCI (post 2015) only? I assume I can just acquire a replacement screen and not have any issues?
I am assuming any "L7 CID High" screen will drop in, but wanted to confirm. My car is a 2014 F30 (non-LCI), has the Nav, HUD, standard (non-HK) audio. My OEM screen has over the past month bit the dust. Untitled by theezv, on Flickr Last edited by theEZV; 05-03-2024 at 01:33 PM.. |
05-03-2024, 03:47 PM | #2 |
Rep 817
just get the same screen. either realoem.com or take the screen off and you can get the p/n off it.
it’ll be pnp since you are replacing it with the same one. and no, you cant just order any 8.8 screen. it has to be compatible with your HU. and you don’t know if yours is touch? seriously? touch the screen - does it work? no, then it’s not touch and touch did not come out until 2018, so yours is not touch but it was super easy for you to even know that yourself by simply touching the screen |
05-03-2024, 06:26 PM | #4 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Get this: https://roadtop.com/products/for-bmw-3-hdscreen
It’s dirt cheap, bigger and gives you android auto and Apple CarPlay. I bought it a month ago and it’s fabulous.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
05-03-2024, 09:17 PM | #5 |
671
Rep 1,985
Drives: 2020 G20 320i M Sport
If you're looking for OEM, you'll need a screen from another 2014-2015 3 or 4 series. The touchscreen will only work on 2017-2019 F30, F32, F36 vehicle equipped with the NBT EVO head unit.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
