BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Diy sport electric seats retrofit guide
Extreme Powerhouse
      07-01-2023, 03:38 AM   #1
Loctite
Drives: BMW 4 F36
I actually wrote this tutorial/schematic for myself to gain insight into how everything should be connected. I just made a DIY out of it to help others. I have to do this myself tomorrow, if my theory is correct it should be like this to come out.
If there are any errors, please let me know and I will correct them in the schematic
pic upload
regards, Edwin (loctite)
fe7565556.50
rlesko238.50
      07-01-2023, 04:11 AM   #2
mig2830
41
Drives: F30 340I
Very nice writeup. Remember the coding.
Add 459 to VO for the electric adjustment with memory and 494 for seat heating driver/passenger if it is not already in the car. If no seat heating you will have to change the climate switch unit to one that have the two buttons.
      07-01-2023, 06:28 AM   #3
Loctite
Drives: BMW 4 F36
Thanks for the input!
Can we code with Bimmercode?
      07-02-2023, 07:59 AM   #4
mig2830
41
Drives: F30 340I
I am not so sure. I think you need E-Sys
      07-04-2023, 10:28 AM   #5
Loctite
Drives: BMW 4 F36
Plugged everything in, everything works right away. Only haven't been able to check the heated seats yet because I don't have the module yet. 2 error codes for the airbags/belt of both seats. Have this reset at my garage and all errors are gone.
Strange that the error codes came, because I transferred the belt modules from my old seats. luckily everything was reset and everything works properly
      07-04-2023, 11:16 AM   #6
dv8ed
9
Drives: 2013 F30 328i N26
Does lumbar need it’s own wire or just coding?
2013 F30 328i N26
      07-09-2023, 01:39 AM   #7
Loctite
Drives: BMW 4 F36
I haven't coded anything, everything works perfectly, also the memory! if you stick to my schedule everything will work right away. I would swap the old seatbelt modules from your old seats to the new ones. You may not get a malfunction afterwards, in my case I did get a malfunction of both seat modules and had it coded away at my garage
      07-17-2023, 08:00 AM   #8
mig2830
41
Drives: F30 340I
Yes lumbar needs it's own wire and no codind needed as the lumbar system has no ECU.
dv8ed9.00
      07-17-2023, 02:43 PM   #9
dv8ed
9
Can I tap from nearby wire or run to fuse box?
2013 F30 328i N26
      02-23-2024, 02:53 PM   #10
jurek_purek
Drives: F30 325d
hi, left amd right have a big module. is wiring the same?
      02-23-2024, 03:30 PM   #11
david51
david51's Avatar
France
538
Drives: bmw M3 F80
No
there is no (line) in the large module
it's like the driver's side
      02-24-2024, 01:10 AM   #12
jurek_purek
Drives: F30 325d
What should i do?
      02-28-2024, 07:38 AM   #13
rlesko
Drives: F30 335i
2012 335i  [0.00]
Do you know what they did to 'reset' it? The airbag restraint warning is the only thing thats really holding me up from venturing into upgrading my seats.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      02-28-2024, 03:12 PM   #14
david51
david51's Avatar
France
538
Drives: bmw M3 F80
What should i do?
look at the diagram that I posted to you, it is indicated
      02-28-2024, 03:13 PM   #15
david51
david51's Avatar
France
538
Drives: bmw M3 F80
to avoid airbag errors install your original airbags on the new seats
      02-28-2024, 03:41 PM   #16
rlesko
Drives: F30 335i
2012 335i  [0.00]
I've heard of that, but seems super annoying to do. I've heard that the airbag restraint light can be caused by busted tensioners.
      02-28-2024, 03:48 PM   #17
david51
david51's Avatar
France
538
Drives: bmw M3 F80
yes possible you have to put back the original ones.
it's not difficult to change the airbag
      04-21-2024, 06:56 AM   #18
lindauto@gmail.com
Drives: BMW 320i F30 2015 Sport GP
Size:  627.1 KBDear Loctite
Initially, congratulations on the retrofit guide for the electrical connection of the seats.
I recently bought a set of BMW F12 M6 650I seats to connect them to a vehicle from another brand.
I need to make the connections so that the electrical controls work normally.
Based on your experience, could you help me make the correct connections so that the electrical controls work?
I transcribe below the information contained in the electronic unit:
BMW 61.35 9 313 997.9 01
SM MF/M - HKLA
BMW AG D - 80788 Munich
A2 - C731 - 2900 - 6 - 00
SN - No. 00275070
I need to know the pin connections for the basic bench movements to work.
I attach photos of the banks.
I thank you in advance for any contribution.
Yours sincerely
Lindauto
      04-26-2024, 02:33 AM   #19
mrpingu
Norway
191
Drives: 2018 F48 X1 xDrive 18D
Does someone know here if Comfort seats from higher series would physically fit the F30? are the mounting points the same?
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
