04-11-2024, 09:22 AM | #1 |
18
Rep 142
Night Vision 3 Lens on LCI 6 series part?
Hey guys,
Does anyone know the part number for the LCI night vision 3 lens for the f06? Realoem says its 66549261106 but that lens is too shallow and it works for the f10 and all other night vision 3 cameras but the f06 lci nivi 3 camera is different from all other 2014+ F series & G series cameras which all use part #66549261106 I thought it might use the nivi 2 lens which is part # 66549175668 but that has two mounting clips and the nivi 3 has 1. Any advice? See attached for the night vision nivi 3 lens from a m6 gran coupe and the lens part #66549261106 which clearly is too shallow |
04-11-2024, 03:22 PM | #2 |
Rep 7,554
See the diagram and part nbr index below for the M6 night vision cam part nbrs (pre & post 7/2013) from the Bimmercat.com online part database. You can verify with realoem.com to see if the M6 (with your build date) uses the same part nbrs:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-11-2024, 03:43 PM | #3 | |
18
Rep 142
But even with what you posted, it says: 66549261106 I checked realoem, see my original post also #1 is the whole camera, i need number #3 in that diagram |
04-12-2024, 08:41 AM | #4 |
92
Rep 127
04-12-2024, 10:03 AM | #5 |
Rep 7,554
Have you verified the camera? If the part nbr for the #3 you have doesn't fit...is #1 the correct camera for your model/model year?
We don't have a VIN to work with...just the part nbrs that you gave us. Here's the part nbr index for a generic F chassis M6...and again, we don't know your build date...you only mentioned a 2014...is your build date before or after 7/2013?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-12-2024 at 10:14 AM.. |
TinCanSailor633.00 |
04-13-2024, 01:51 AM | #6 | |
18
Rep 142
04-13-2024, 12:46 PM | #7 |
1207
Rep 2,919
When I got my front bumper painted about 4 years ago and got a new grill section I thought I might get a new night vision cover glass since mine has some tiny stone chips. Then I saw the price. There can't be another part anywhere where you pay so much for so little. It's a glass disc the size of a nickel. And it's anywhere from $650 to $1,000.
f06, lens, night vision 3, night vision lens, nivi 3 |
