11-01-2015, 05:23 AM | #89 | |
Rep 629
11-01-2015, 05:52 AM | #91 | |
Rep 629
11-01-2015, 04:43 PM | #92 |
Rep 629
traffic sucks. managed a 2:13 held up by a couple mustangs. the car has sub 2:10 in it I'm sure. My 2 best unobstructed laps I had all day weren't picked up on harrys laptimer. I'm sure they were faster then 2:13 but no way to ever know.
11-02-2015, 07:57 AM | #94 | |
Rep 629
11-02-2015, 08:50 AM | #95 |
FAST
371
Rep 574
Sebring is a very safe track. Tons of space for runoff everywhere.
I have over 100 track/race days logged at Sebring. You probably hear more incidents at Sebring just because it hosts (probably) 10x the track days compared to say Daytona. I consider Daytona the most dangerous track in the south. Barber and Roebling Road are very safe as long as the grass is dry. I also consider Road ATL 2nd most dangerous. I've seen more serious carnage at Road ATL than anywhere else. (Mainly because everyone seems extra careful at Daytona because it has a reputation for high speed tire failures) Robling and ATL can be really really really cold in Dec + Jan. I've had ice conditions at both tracks in November. I pretty much write off everything not in FL from early DEC until March. Then write off FL from June until October (due to rain) |
11-03-2015, 06:51 AM | #96 |
*_*
810
Rep 3,160
*Car: F82 (see mods below)
*Track: NJMP Lightning *Best Lap: 1:15.1 *Notes: Timed with M Laptimer link to car's ecu. Last edited by S65V8; 07-25-2016 at 09:05 PM.. |
11-03-2015, 08:28 AM | #98 | |
FAST
371
Rep 574
For a full weight car, you really rocked the bustop good in that one! Q: Are you off the gas some on the banks? It sounds like it. Why? Was it feeling unstable or something? Normally you would be wide open from 6->9 and 10->1. Feels like a sling shot! Q: Where you bumping off the speed limiter much? Q: How did the continentals hold up the 2nd day? Q: What group was this? Q: What were your camber settings? (Hopefully pretty flat) |
11-03-2015, 08:45 AM | #99 | |
Rep 629
-I never found the limiter. I believe i remember reading someone hit it at 167 but I'm not 100%. -I was wide open most of the time on the banking. Sometimes fear took over lol. If I did lift, it was to maybe 90% throttle, no less. -I'm really a fan of the contis. I'll post some pics of how they look when I get a chance, but they felt really good over the whole run. The middle rib is showing some edge wear on both fronts and the outside is getting a little feathered, but not how the michelins look after 1 weekend. Overall I think they are really good. -Nasa DE2 -3* front and -2* rear. OEM toe settings. The right front was rolling over a little too much due to the banking. I was coming off at 38 psi all around. The r/f definitely needed a few more lbs though.
11-03-2015, 08:47 AM | #100 |
Rep 629
Also, the car kind of just stopped accelerating on the banking even at wot. It would hit 140-145 and just hang out there until it straightened up again. I was running euro mdm, so maybe the car was freaking out and that was trying to slow it down. The light was blinking all through the banking.
11-03-2015, 11:35 AM | #101 |
FAST
371
Rep 574
Hmmm. I would really like an explanation about that behavior. Totally not right. I've never seen a car freak out on any banking.
If it was my car I would be PO. With that behavior. FYI -2 rear camber may even be a bit aggressive at Daytona. I run -2.5 and it absolutely destroys my rear tires. FYI I can't run any flatter than -2.5. Check your inner side walls for damage. Good to hear you like the cont tires. As far as the computer flipping out, You should open a separate thread asking about this issue. I'd be curious to know what is up with that. |
11-03-2015, 12:49 PM | #102 |
Rep 629
I'm not too worried about it. I don't drive daytona enough for it to matter to me. I assumed the car just didn't know what was going on given all the inputs it was receiving. I doubt it was designed with daytona in mind. I'm sure traction control full off would fix it anyway.
11-04-2015, 02:53 PM | #103 | |
*_*
810
Rep 3,160
I am toying with the idea of getting AD08s after these contis wear out, and use those for both daily driving + track. I just wonder how harsh the AD08s are on normal roads, and if they're super noisy... Note, posted more thoughts in the track section as well... http://f80.bimmerpost.com/forums/sho....php?t=1186751 |
11-04-2015, 03:07 PM | #104 | |
Rep 629
I'm kind of in the same boat. I was tired of hauling an extra set of wheels/tires to the track in my back seat so I want something that will do both. I'm between those and re71r's. I've never been a bridgestone fan but they seem to have a lot of good reviews. Anyone else run them?
11-04-2015, 03:11 PM | #105 | |
*_*
810
Rep 3,160
I've heard a lot of good press on AD08 Rs. Almost a done deal in my mind, but they max out at 275/35/19 (R), after that you have to go 295/30/19 (R). In any case, still got some time to make a decision. |
11-04-2015, 03:14 PM | #106 |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Streets of Willow Springs CW: 1:35.594
M4 6MT, stock suspension, Carbotechs, R888s First time on this track. Fun, technical track. Never really found the proper lines in many portions, but had fun anyway. R888s are getting a little long in the tooth (5 track days and been driving around on them on the street for 6+ months), but good for car control practice which was the purpose of the weekend anyway. The day before I did a drift clinic which was a total blast! http://f80.bimmerpost.com/forums/sho....php?t=1191553
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
11-05-2015, 11:09 PM | #107 |
Rep 3,305
Updated time: 11/1/15 w/ Speed District -- 1:35.010 nlakind M3 (AD08, KW CS)
11-06-2015, 05:56 AM | #108 | |
General
21121
Rep 20,741
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-06-2015, 07:43 AM | #110 |
Rep 1,789
Drives: wife crazy
No, didn't see her. They disallowed ride alongs after the first sessions anyway because of a roll over.
