02-22-2021, 09:15 PM | #23 |
26
Rep 125
Thanks! Some interesting points there. When was this published? They cite a 2002 study. I'm curious how much of this would change, if anything, for modern cars, especially the stats on 3pt systems and prevalence of head to doorframe injury on rollover crashes.
02-23-2021, 08:42 AM | #24 |
///M Powered for Life
11495
Rep 10,331
If you want to read the whole study, PM your cellphone if you have whatsapp or signal and I'll transfer the file.
02-23-2021, 11:54 AM | #25 |
415
Rep 366
I had what turned out to be a pretty good solution in my GTS. I removed it because the left wing of the seat was rubbing on the door card, but otherwise it was perfect.
OMP WRC-R seat Brey Krause Sub Bar Brey Krause Side Mounts Brey Krause Lap Harness Mounting Kit Schroth Profi 2x2 FHR Harness OEM GTS Roll Cage OEM BMW manual seat sliders The sub bar prevents the seat from being mounted super low, which means it must be mounted midway up the side mounts. This (coincidentally) perfectly aligns the seat belt slot in the WRC-R with the 3 point belt receptacle. You cannot adjust the height of the pretensioner or receptacle, so it's more of a coincidence than a designed fit. I could run 3 points on street correctly/safely and 6 points with HANS on track correctly/safely. As mentioned before, the only reason I removed it was the rubbing on the leather of the door card + airbag warnings (which admittedly could be coded out with Euro M4 GTS settings). Photos: |
SYT_Shadow11494.50 |
02-23-2021, 02:20 PM | #26 | |
11495
Rep 10,331
02-23-2021, 04:26 PM | #27 | |
415
Rep 366
Hoping to do One Lap this year and glad to know that I have a solution that actually works for street/track drivability beforehand. |
02-25-2021, 12:33 AM | #28 | |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
One added feature with the Nogaro setup is that the Nogaro's have been tested and "certified" by Schroth to be used with the Schroth Quick Fit Pro belts. And to answer your earlier question about the Schroth Quick Fit's being certified in the F8x, Schroth never did this official certification - probably because BMW did not offer a viable seat solution in the M3/M4 (even though the non-M seats in the F3x probably could have worked). However, from a practical perspective (and IMHO) the F8x is very similar (if not better) than the E9x from a stock seatbelt engineering design/safety perspective - so the Schroth QFP's should be fine in the F80. So, IMHO, using the Nogaro's in the F80, with the Schroth QFP (the E90 version due to the similar dimensions between the F80 and E90), is a good setup for a street/track car - but of course not perfect. As what was mentioned above, there are A LOT of opinions about safety setups for street/track cars when it comes to seat and harness usage on the track and street - with some having an "all certified or nothing" safety approach to these types of setups. So you will need to determine your own level of safety comfort with your setup.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 02-25-2021 at 12:58 AM.. |
02-25-2021, 06:21 PM | #29 |
63
Rep 84
Got my driver seat to Sparco Evo L, paired with Schroth 16.5 Profi II. Sparco seat base underneath so a bit of tilt towards left side.
No cage or harness bar now; using eye bolts in the rear seats' buckles. No it's not the ideal setup, but let's go from there. Maybe a GTS half cage later? Not sure about its price and the drilling to the car frame. |
02-26-2021, 07:02 PM | #30 |
26
Rep 125
Thanks for the input! A lot to consider. You guys have some nice setups!
2016 F80 M3 ZCP DCT - BM3 Stage 1 (street) / BM3 CS+ (track)
2015 Golf R - COBB - AWE DP - CTS IC |
04-06-2021, 02:56 PM | #31 | |
Emperor
1614
Rep 2,753
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
04-06-2021, 04:32 PM | #32 | |
Rep 3,670
10-12-2023, 07:15 AM | #34 | |
65
Rep 141
Now considering a BK harness bar with a 5pt over Schroth QFP for a couple reasons - potential tech inspection issues at NJMP (though enforcement varies) and submarining (even though it's 'ASM', probably small chance it can still occur) I imagine another (indirect) rollover safety measure might be sway bars? Last edited by 4Y_stack_acceleration; 10-12-2023 at 07:42 AM.. |
10-12-2023, 08:05 AM | #35 | |
11495
Rep 10,331
10-12-2023, 09:26 AM | #36 | |
Rep 836
10-12-2023, 10:03 AM | #37 |
11495
Rep 10,331
I use the omp htr-r 400, fits fantastic
10-12-2023, 12:37 PM | #40 |
Rep 836
11-09-2023, 02:19 PM | #41 | |
65
Rep 141
Will be getting the BK seat sliders - thanks for the recco. |
01-01-2024, 06:25 PM | #42 |
Rep 416
SYT_Shadow
Happy New Year! Hey did Competition MotorSports set you up with the seat and mounting hardware? I’m thinking of going down this road and also geeking out and doing a cage. My M is quickly becoming a dedicated track machine.
Quietly Effective
01-02-2024, 07:03 AM | #43 | |
11495
Rep 10,331
I used all BK hardware, plus the oem sliders, to mount the seats. Still happy with the results after many years of running this setup in the E90, E92, M3 CS, GTS1 and GTS2 |
phefner369.00 |
01-07-2024, 08:36 AM | #44 |
Rep 5,554
Why did you remove the oem GTS roll bar? Was the GTS harness bar not at the correct height or concerned about running a roll bar on the street or a combo of both?
