2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Backup Camera Retrofit Question
      02-10-2017, 02:47 PM   #1
saad2605
66
Drives: 2016 Alpine White 528i
2021 BMW 540i  [0.00]
2016 BMW 528i  [10.00]
Hey guys. I had a question about retrofitting a backup camera to my LCI 528i. I stopped by to speak to the dealership but they have no idea if this will work or not and wanted to charge an arm and a leg for the parts only.
If I was to buy the backup camera, Wiring Harness, and the ECU, is there anything else I would need to get this project operational. I know I'm probably going to need some coding after the install so I'm going to have to learn that as well. But other than that anything else I should be looking at...?
Thanks so much for any help!
      02-10-2017, 05:28 PM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
If you just want ideas look at bimmertech. No matter how you do it, it won't be cheap.
      02-10-2017, 06:07 PM   #3
saad2605
66
A friend of mine can get me a used set from the auto salvage yard, but I'm not sure if I would need anything else. From the looks of it on the details page of bimmertech, in there OEM system it includes the Camera, Camera Module, and Wiring Harness. and then a coding interface. So I think I'm on the right track but wanted to get some additional feedback.
      02-10-2017, 07:24 PM   #4
claykin
Drives: various BMW
I highly recommend you contact Patryk at Bimmertech. He sells a complete OEM kit and also other retrofit options.
oem solution requires PDC (Bumper sensors). Parts needed are as follows
New trunk handle and camera
camera module and bracket
wire harness for camera module (includes power wires, canbus wires and video signal to headunit)
HSD cable for camera to module.
once this is installed, you need to do VO coding to activate the option.
2023 840GC | 2021 740i | 2019 X3
      06-20-2017, 10:40 PM   #5
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
I need some one to elaborate which is which in the 7 wires plug in TRSVC
I already knew KCAN H and L - GROUND - Shield
which is FBAS + and -
and which one goes to the fuse box, and which slot to put the wire in.
      04-15-2024, 09:57 AM   #6
Sopheaktra Garage
Drives: BMW
Hello I have a car BMW F10 2013 No rear camera option, so I need add rear camera TRSVC and coding.
I need help for coding
Thanks you
backup camera, backup camera retrofit, mods, retrofit
5post
