BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Eric's HPF Single Turbo N54 Is ALIVE - VIDEO
      10-25-2012, 02:27 PM   #1277
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
Originally Posted by HPF Kirk View Post
The position of the turbocharger had to be slightly changed which means we are in the process of relocating a hard coolant line that also supplies cooling for the stock turbos. We are having to make new intercooler piping and adjust/remake a few other things as well. Progress is definitely not as fast as I was hoping but we do have customers cars to finish as well so More updates to come in the next week or two...
Cool, thanks.
2008 E90 335
      10-31-2012, 05:45 PM   #1278
HPF Chris
Drives: 2006 330i & 530i
Originally Posted by RimasRS View Post
What additional options will we have with the HPF intakes?
You will be able to run nearly any engine management system you want if you run our new HPF 135/335 intake manifold and a set of injectors. AEM Gen 1, Gen 2, Motec, Hydra Nemesis, Halltech, even the AEM FIC and others. Many of these systems can't control the direct injection but they can control fuel injectors that can be used with our intake manifold. You also won't overheat the direct injection or the fuel pump. The car drives around just like it does factory, but as more fuel is needed the secondary set of injectors comes on. We are designing the piping on our new big single turbo kit and will start tuning very soon.
If you still want to run our big single turbo kit and only want to use the direct injection you can continue to use a flash or piggyback type tuning system. Our intake manifold comes with plugs in the fuel injector ports so you can run it to eliminate the factory plastic one and remove the fuel injectors plugged when you overpower the direct injection and want to run some FIC or IDE injectors.
Chris.
      11-01-2012, 12:21 AM   #1279
jb's335
Big Boost Addict
Drives: AW e92 335
Isn't proper exhaust manifold design supposed to give priority to the wastegate, not make the exhaust gas have to make a complete 90 degree turn before exiting the gate(s)? If you gave the wastegate priority you would not need 2 44mm's to control boost. I have seen plenty of properly designed manifolds make upwards of 800+whp on a single 44mm TiAl, something similar to this:
I know you seem to have time constraints in getting this kit finished finally, but this would save your customers time and money in the long run. Installation and pulling the gates off off this setup will be a royal pain in the butt. I feel bad for the mechanic who has to install this thing.
      11-01-2012, 06:46 AM   #1280
Eracer76
Eracer76's Avatar
Drives: 2009 E89 Z4 35i
I believe they are using two wastegates because the manifold is for a twin scroll turbo, that way the two banks stay separate until they hit the turbo.
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
      11-01-2012, 11:14 AM   #1281
HPF Chris
Thank you.
Chris.
      01-16-2013, 09:40 AM   #1282
N111CUK
G force Junkie
N111CUK's Avatar
36
Drives: 335i M Sport black edition
So whats the verdict is this dev turbo in production and is there real data to show performance
      08-22-2013, 08:13 PM   #1283
SilentAttack
SilentAttack's Avatar
165
Drives: 08 E90 Jerez Black 6MT
Did Eric get his car back from HPF before they shut the doors?
      08-22-2013, 08:55 PM   #1284
cwarren
cwarren's Avatar
82
Drives: 08 e92
search .........car ended up at fftech sad thing I don't know what happen after words
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      08-23-2013, 04:48 PM   #1285
AYF80
Drives: 2015 AY F80
Got my car back from FFTEC two weeks ago. The car is running very strong at a conservative 16 PSI with the 700 kit.
Break down of the car and review of FFTEC service is to come shortly.
      08-23-2013, 05:32 PM   #1286
135Pats
135Pats's Avatar
Drives: A few BMWs
Oh hell yea, i didn't know you were able to get a ST setup done while at FFTEC.
Happy ending to a shitty story
F30 N55 XDrive EBII
      08-23-2013, 05:58 PM   #1287
Robert@vishnu
Drives: Corvette C6 Z06
Would love to see the review and story of the whole process. Should be good.
      08-24-2013, 09:34 AM   #1288
cwarren
cwarren's Avatar
82
Drives: 08 e92
yeah me too lol
      08-24-2013, 10:54 AM   #1289
iBoost
Retired e90post Member
iBoost's Avatar
135
Drives: real slow
Me 3!
      08-24-2013, 02:17 PM   #1290
Rob@RBTurbo
Rob@RBTurbo's Avatar
Drives: '08 335I AT, '14 M6 DCT
me 4!
      08-24-2013, 04:23 PM   #1291
dfjaws
dfjaws's Avatar
Drives: E90 M3 / E86 M Coupe
Me 5.
mr. 5?
      08-24-2013, 05:48 PM   #1292
pwr hungry
Drives: 335
Me 6
      08-24-2013, 05:56 PM   #1293
Wedge1967
Drives: '07 e92 AT Sport Montego Blue
How's the Alpina flash working out?
      08-24-2013, 06:28 PM   #1294
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
me 7, oh hii.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      08-30-2013, 01:47 PM   #1295
AYF80
Drives: 2015 AY F80
Amazing,
It was a bit rough for about 100 miles, but after a few drives it was incredibly smooth.
Thanks again for hooking me up Ken.
      08-30-2013, 01:54 PM   #1296
TT3 iN NyC
TT3 iN NyC's Avatar
Drives: F80 M3CS
Amazing,
glad things worked out in your favor and that you got a nice single turbo running.
did you dyno the car yet? Would love to hear your impressions about how the tranny is holding up with the single turbo kit. I too have 6AT and would love to go this route sometime in the future.
07 e92 335i - Retired
18 F80 M3CS - Retired
21 G20 330i M-Sport - Current
      08-30-2013, 02:42 PM   #1297
Dmacc
200
Drives: 2011 BMW 1M
Me 8 on that write up.
thanks to MGallop
hpf single turbo, single turbo n54
