03-27-2018, 02:03 PM | #89 | |
70
Rep 359
Congrats!! hows the Pure Stage 2 DDs going?
Currently i'm running a custom MHD map from Treblia and it's not bad at all. I would recommend you to run a water/meth kit if you can. (i know it's a bit troublesome, but definitely good for your IATs) currently i'm not running on PI at all, as the stage 2 LPFP seem to be keeping up with the required fuel supply. i use the NGK 97506 spark plugs, which are 2 step colder than stock, gapped @ .022 (.55mm) Quote:
03-27-2018, 02:05 PM | #90 | |
70
Rep 359
well, you can use burger's tune for hybrid turbos. it's pretty good as well |
04-12-2018, 07:15 AM | #91 |
68
Rep 397
Thanks Lightning and car's at the shop still getting everything installed, should have it back this weekend and really looking forward to it.
Love to hear your fueling is working well with just the Stage 2 LPFP as thats all I'm upgrading on fueling at the moment, keep it simple and build from here. I'll let everyone know how it goes, I'll start w Brugers Hybrid Turbo tune and go from there.
BSM 1M, MCS Coilovers, Pure Stg 2 Turbos, Walbro LPFP, JB4, BMS E85 Flash, ECS CF sealed intake, N54 Tuning DP's, Evolve Race Exhaust, Wagner FMIC, Stett CP w/ Tial BOV, ST BBK, Big Tires.
M6 6MT Gran Coupe w JB4, 718 GTS, Lotus Esprit V8TT, Duc 998SBayliss |
07-16-2018, 11:09 PM | #92 | |
70
Rep 359
cool! how's the car so far Spencer? |
08-18-2018, 09:39 AM | #93 | ||
68
Rep 397
Issue was pure sent me a rear turbo for a 335 not a 1m/135. Little things like outlet piping and cooling lines are a bit different so I'm telling my mechanic direct bolt on and he kept saying well the coolant line doesn't line up? Had him talk to pure and they said "oh yea we don't sell that but you can get a longer line from this shop" instead of saying "oh shit, we sent you a 335 unit". I eventually got fed up with my mechanics requests to buy more little parts, and called pure where Charles instantly caught on to them having sent 335 turbos. From there it was fast to complete the install. I also installed a fuel it stage 2 lpfp at the same time(and 2"inlet piping) and a bunch of other little stuff, I can tell these turbos have much higher flow but my fuel system is failing at higher boost levels according to logs but I think just a faulty low pressure fuel sensor so replacing that this week and hopefully get to see the full potential. So far my impressions are that the turbos hold boost to redline which feels much stronger than stick with them trailing off as you get above 5500, and it's not bad but the turbo lag is certainly more noticeable below 4000 rpm's so for general all around driving I think bmw had the right turbo wheels but for those tracking these should be much better since you live between 4000-7000rpms. I can't wait to get them running right very soon!
08-28-2018, 10:31 PM | #94 | |
70
Rep 359
Hi Spencer! great to hear that your car is finally running! are you on Meth btw? i can take a look at your logs if you're on jb4. |
11-05-2018, 03:25 AM | #95 | |
25
Rep 93
How is that possible? Is that what the water/meth kit is doing for you? I've got a pair of RB Next Gen Plus's at 18-19 psi on Ron 98 and the tuners wont up the boost further than that unless you have PI or a Single/double barrel setup. I cant wait to turn mine up to 25psi. Its already fairly rapid but 100-200 in under 6 seconds is awesome. Last edited by schmick325; 11-05-2018 at 03:46 AM.. |
11-07-2018, 12:14 AM | #96 | |
70
Rep 359
Hi schmick325, great to hear that more folks here are running hybrid turbos! Maybe you'd like to list down your mods so we have a better understanding of your hardware? Are you running meth kit? Also, you can easily hit 18-19psi with stock turbos even without meth, so i'm quite intrigued as to your tuners decision not to up the boost further. Do you have logs to share? take a look to see if your fuel trims are maxed out. |
