12-01-2023, 07:04 PM | #1 |
Rep 419
Valve cover leak -- repair estimate
Dealer found a very minor valve cover leak in my M4. SA (who is a good guy and always looking to save me money) said it was not an immediate problem, and recommended that I deal with it if/when I can smell burning oil. Quote for the work was about $3,400, which struck me as absurd. Questions:
1. Is that quote absurdly high? 2. Could a competent indy do this work, or should I have a dealer do it? Thanks in advance.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
12-01-2023, 07:11 PM | #2 | |
Rep 803
2. That’s a simple job for an Indy to do I suggest you post a question (unless you already did) in the Regional Forums for your area looking for a recommendation for a good Indy mechanic. Good luck
tgb1974154.00 |
12-01-2023, 07:29 PM | #3 |
Rep 25
Holy moly, just for the valve cover gasket, that's nuts. At first I was thinking you were replacing the valve cover which runs about $600 and commonly done when the PCV valve is borked. It's not a terribly involved job, it is a decent amount of work, but $3,400 is ridiculous.
tgb1974154.00 |
12-02-2023, 02:50 AM | #6 | |
Racecar Driver
1309
Rep 1,984
Drives: BMW M4
You can buy one off FCPEURO and have your Indy shop install it. Now you’ll just have to pay labor for it in the future. This is a part that goes bad more often than it should. I’ve already seen a few posts for this part and I experienced the replacement this year as well. Seems like old car problems.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
tgb1974154.00 |
12-02-2023, 05:03 PM | #7 |
Rep 1,366
Is that Canadian dollars or Chicagoland dollars?
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
12-02-2023, 10:51 PM | #8 |
32
Rep 146
Any competent mechanic can do this repair, it’s not at all difficult, but it is somewhat time consuming. I was quoted 2,300 from indy including spark plugs and oem valve cover. I ended up getting parts from FCP and DIY. I would suggest fixing this sooner than later. It’s not fun when oil drips on the exhaust and creates smoke.
12-03-2023, 12:29 AM | #9 |
Rep 1,695
Just to give some context to that estimate, the dealership is likely including the spark plugs and well as the coils. I’ve been down this road before, and their rationale is that some oil may have leaked down so it is their procedure to replace it all
DSC, you say? Never heard of it
https://youtube.com/@tractioncontroldelete |
12-03-2023, 09:05 PM | #10 |
60
Rep 134
I just did this myself (and the spark plugs and air filters while I was there). I got quotes from 4 different places. 2 BMW dealers each quoted about $3000 for parts and labor for valve cover and spark plugs. Two indy shops quoted about $2500 and $2900 for the same. All in central-ish Iowa. I did it with $800 of parts and several hours. (I did run into a couple issues that extended the labor time quite a bit.)
tgb1974154.00 |
03-05-2024, 03:35 PM | #11 |
Rep 54
I had just about the same quoted to me in west palm beach. $3200 to replace the value cover gasket. I am not sure what these guys are thinking, but that's insane!
03-05-2024, 03:55 PM | #12 |
Rep 419
Thanks for this. To my surprise, a small but very capable service station quoted me almost the same amount as the dealer to do this work. Couldn't believe it.
saint807.50 |
03-05-2024, 05:23 PM | #13 |
47
Rep 111
I’ll do it for $900. J/k.
Anything over 3 hours of labor is insane. Took me less than 3 hours to remove and install the valve cover in my garage. That’s with repeatedly stopping following ISTA |
03-05-2024, 06:57 PM | #14 |
Rep 876
I had mine done last month at Delray BMW. Fortunately my 3rd party service contract covered it for $3200.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
03-15-2024, 03:40 PM | #15 |
Rep 54
in west palm, I was just quoted $2300 for the replacement. Still seems high, especially when they want to charge me an additional $700 to drop the new plugs and coils in, which were coming out anyway and which I already purchased new from FCP. Wish I could find a good indy somewhere around here who actually knows more about the M3. I'm not sure how much these guys do on M cars.
tgb1974154.00 |
03-15-2024, 03:55 PM | #16 | |
Rep 803
Back Jan of 2021 I had the Indy I go to replace the valve cover gasket on my 435 AWD as well as front & rear differential fluid changed. I just supplied the plugs to him. I payed $1000 cash for the labor and misc parts needed. He supplied everything else.
saint807.50 |
