Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > how to remove accelerator pedal
      01-02-2011, 06:20 AM   #1
badsha
badsha's Avatar
35
Drives: BMW E90 318d 2006
is there anyone who knows how i can remove my BMW E 90 accelerator pedal?
i have seen many videos on youtube for E46 etc, but it looks liek its diffrent on E90??
i have a link here but it dosent tell me how to remove!
http://www.e90post.com/forums/showthread.php?t=165637
      01-03-2011, 09:37 AM   #2
badsha
badsha's Avatar
35
Dont anyone know??
      02-08-2013, 01:14 AM   #3
Cal Naughton Jr
Drives: 2011 328i Touring (E91)
How to remove E9x throttle pedal
Easy 5 min DIY job.
You will need:
-Flat head screwdriver with a thin tip
-Torx T30 screwdriver
-Vacuum (optional)
1.) Use the flat head screwdriver to pop out the small round screw cover on the base of the throttle assembly. Put it somewhere safe - it's easy to lose especially if you have black carpet.
2.) Unscrew the Torx T30 screw.
3.) Pull the base of the assembly slightly up and forwards, (towards the steering wheel) just enough to free the base. The base is held in place by a positioning pin that is next to the Torx screw and enters the floor at the same angle as the screw.
4.) Slide the assembly forward and up along the floorboard (towards the engine). The back of the assembly is held in place by a hook.
5.) The throttle is connected with a wiring harness. Pinch the sides and it pulls right off.
6.) At this point, if you're as neurotic as I am, you'll want to get out the vacuum to clean up before you put everything back together. Amazing how much crud builds up in the crevices where the vacuum attachments can't normally reach.
Good Luck!
      07-09-2014, 06:20 PM   #4
matreyia
36
Drives: 335i Convertible Montego Blue
Originally Posted by Cal Naughton Jr View Post
Easy 5 min DIY job.
You will need:
-Vacuum (optional)
Attachment 817006
Attachment 817007
Attachment 817050
Attachment 817005
Good Luck!
Looks easy until you try it yourself. That clip ain't coming off. I even broke the tabs and it still stuck. Trying to install a Sprint Booster now... dang, don't know what else to do. Wish there was a photos of the wire harness disconnected so I can see which parts are separated or welded to the plastic harness.
      03-12-2016, 10:54 PM   #5
delmarco
delmarco's Avatar
Drives: 2011 335xi Deep Sea Blue
nice! going to need this for my steel pedal install
VISIT MY GARAGE TO SEE MY BMW E90 MODS:
http://directory.e46fanatics.com/use...Mod&UcId=20832
      03-13-2016, 03:48 AM   #6
Socket
Socket's Avatar
4546
Drives: 335i
2008 BMW E92  [0.00]
http://www.e90post.com/forums/showthread.php?t=1223462
Try this
      02-02-2019, 11:31 AM   #7
Kipyatortito
Drives: BMW 328xi
Easy 5 min DIY job.
You will need:
-Vacuum (optional)
Attachment 817006
Attachment 817007
Attachment 817050
Attachment 817005
Good Luck!
Worked like a charm, Thank you so much Cal.
      03-15-2019, 04:30 PM   #8
6ixSpd
Save the manuals!
6ixSpd's Avatar
6028
Drives: '16 M3, '23 718 Spyder
I had no idea it was so easy and quick to remove the pedal assembly! Thanks to this I was finally able to clean up the decade of grime and salt in this area which was previously not possible to reach.
      03-30-2019, 12:07 PM   #9
leif20
leif20's Avatar
30
Drives: 2006 330i Auto, Sport
Is there no issue with unplugging the accelerator pedal? Any pedal relearn procedure that must be done, or is it just unplug and plug back in?
BMW Owner since 04/2018
      02-14-2024, 12:50 PM   #10
lordnikon
lordnikon's Avatar
382
Drives: Break My Wallet
Wondering the same.
      03-28-2024, 04:36 PM   #11
germa_n
germa_n's Avatar
Drives: BMW X4 M40i
Oh, I can totally relate! I even stumbled upon a coin tucked away in that crevice. It was quite a surprising discovery for me.
