06-30-2015, 08:27 PM | #1 |
Rep 525
3 Series center console in a 1er!
Would anyone know if a 3 series centre console would fit in a 1 series? My first instinct is simply that it would be the wrong size, but i spend a whole lot of time looking at the 3 series interior last night and it seemed close...
Its just i need to replace my center console and cannot find one (used) that has the slot for the idrive controller Or does anyone know how much a brand new one costs? Last edited by reisf; 09-16-2015 at 03:01 AM.. |
06-30-2015, 10:06 PM | #2 |
1Addict
3239
Rep 7,904
Interesting thought. Could always try to find a beat to shit one at a scrapyard and see if it matches up at the attachments and the carpet liner.
07-01-2015, 06:24 AM | #3 | |
Rep 525
Try to return something and they look at you like you've committed a crime... |
07-01-2015, 06:52 AM | #4 |
Rep 89
Could the 3d scanned interiors help on this. Pendragn has posted some links to 1'er scans and there's a great scan of a new 3-series.
07-01-2015, 12:23 PM | #5 | |
Rep 4,040
Drives: 130i coupé ;)
VW world loves to use AudiTT consoles in everything
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
07-02-2015, 09:14 AM | #6 | |
Rep 525
Can you confirm that its the right size/fit?. Really like the look of the Z4 center console |
07-02-2015, 11:27 AM | #7 | |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
I would certainly look for one from a wrecked car though. I looked at an E92 335i with a huge cigar burn in the dash. A new dash was like 1200 for just the top portion. Not sure on cost for the consol but used will be way more cost effective for something that may not fit without a lot of modification
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
07-02-2015, 11:35 AM | #8 | |
Rep 4,040
The rest is tape measure and lookign up how TT consoles are cut up
08-25-2015, 03:28 AM | #9 |
Rep 525
GUYS!! IT FITS!! And looks pretty darn good.
andrey_gta299.50 |
08-25-2015, 10:25 AM | #10 |
1Addict
3239
Rep 7,904
This was the 3er center console?
08-25-2015, 12:55 PM | #12 |
Rep 48
Hey, was thinking about this for a while! Looks good.
Do you have a few more pictures? Especially the linking parts to the dashboard?
08-25-2015, 05:59 PM | #15 |
1Addict
3239
Rep 7,904
No kidding, the sliding arm rest is probably the best thing about the 3er.
08-26-2015, 03:36 AM | #16 |
Rep 525
Love the sliding arm rest and the whole feel of the center console. The trim around the gear stick and controller just feels like quality. The $6FL in the arm rest is the same connectors too (mine was complete with aux/usb/snap in adapter)
Of course the rear vents don't work :P but it lines up perfectly at the back with the old mounting screws. The front doesn't line up perfectly (thus the extremely biased photos) but I'll see what I can do with the old one to get it looking good |
08-26-2015, 03:37 AM | #17 |
Rep 525
08-26-2015, 05:56 AM | #18 | |
1Addict
3239
Rep 7,904
Did the boots fit as a straight swap as well, or are those shaped differently?
08-26-2015, 06:10 AM | #19 |
Rep 525
No both boots were different. I'll be adding some more photos in the next few minutes. I think this center console was from an lci e90 (you can tell by the split armrest) so the trim for the shifter was different (a bit smaller) but the hand brake boot is a completely different shape.
08-26-2015, 06:55 AM | #22 |
Rep 525
Some notes on the fit
Now some notes on how the console fits.
- Yes as stated above it is slightly wider than the 1er's console. However, it is literally less than half a cm wider on each side and unless you stick your hand under it, it is very hard to tell. - The back of the console lines up perfectly, the front however you will need to wedge under the dashboard with some force. Screw holes even match up with the old points that are about half way along (near the hand brake), you will just need some longer screws. - The hand brake and gear stick line up perfectly. You will however need new boots from any 3 series should fit. I got both of them for $25 each (AUD) the aluminium trim for $50 and the full console + armrest for $150 so $250AUD total. In my opinion, definitely worth it. - On this console, the cigarette lighter plugs didn't match (front and under the arm rest). However it is super simple to fix - just cut the wires, solder, heat shrink them and you're good to go. - As i mentioned above, the part where the console meets the dashboard doesn't line up. I'm planning on sort of cutting the front bit off the old console and letting it meet up with the new console somehow. Haven't planned it yet but i'm just thinking out loud here. - You will however have to remove the aircon duct from under the console, you just tug on it and it comes out (picture below) With all the above aside, i love it. - Install time: about 2 hours. Last edited by reisf; 08-26-2015 at 08:19 AM.. |
