Bmw e90
04-28-2024, 12:25 PM | #3 | |
Rep 4,080
I presume for most folks in Serbia, English is NOT the Primary Language? My understanding of your post & photos is that the Instrument Cluster has RANDOM Warning Lights when the engine (Diesel) is running, and when ALTERNATOR is Charging. If that is the case, be aware that the Instrument Cluster sends & receives ALL its signals, except Ambient/Outside Temp, via Bus System. While there are MANY things that can "Scramble" the Bus Signals, resulting in a "Light Show" on your dash, & perhaps OTHER faults, such as Wiper "Self-Activation", "Over-voltage", or Alternator Output > 16V is most frequent cause of that condition. A Scan Tool can display System Voltage (as Live Data) with engine running. A Multimeter can read system voltage at the Jumpstart Terminals under hood, or you can plug a $10 meter into the Lighter Socket. I would use ONE of those methods to monitor System Voltage with engine running, Particularly when/ if Cluster Warning Lights appear. Also, if you have a Scan Tool/ diagnostic Software such as INPA/ ISTA, you can view "Freeze Frame Data", which is a "Snapshot" of Inputs to a Module when Fault Code saved, such as Voltage, Temperature, RPM, etc. If you find PROOF of "Over-voltage", usually the ONLY thing needing replacement is the Voltage Regulator on rear of alternator. That is only ~ 15 to 20% of the cost of the entire Alternator. Please let us know what you find, George |
StradaRedlands4988.00 Bims328i270.50 |
04-28-2024, 09:39 PM | #4 |
Rep 3,894
Drives: 330i, 135i
