05-25-2018, 07:54 PM | #1 |
Rep 847
how to remove tar like black stuff
They are working in a local highway here, I got nailed with tar like stuff. It is all over my car. I have a detail on the 14th, do I just let them deal with it or should I try to remove it? If I try to remove it, how should I go about doing it? I have about 500 little black dots, here are some pics after a lazyish handwash.
05-26-2018, 03:31 PM | #2 |
998
Rep 2,214
WD-40 will dissolve tar, but you can be left with a smeary mess to clean afterward. Mequiars & Stoner make bug & tar removers that you should be able to find in your local big box parts stores or even Walmart. CarPro Tar X is good but you'll need to order it.
Good luck!
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
05-26-2018, 07:14 PM | #4 | |
Rep 847
maybe, but i have a full detail in a few weeks |
05-26-2018, 08:56 PM | #5 |
Rep 16,149
Acetone will remove just about anything. It tends to leave a haze, which you can get off with rubbing alcohol. It will also remove waxes and sealants, so use it before the detailing.
05-27-2018, 08:35 PM | #6 |
118
Rep 303
I’ve had tar on my car and clay bar with detail spray took it off with no issues. Be advised that claying will take your wax protectant off so you’ll need to replace that to ensure your paint is protected.
05-28-2018, 12:39 PM | #7 |
998
Rep 2,214
Including paint so go easy with it! Gasoline or kerosene also might take it off, but please consider all safety issues.
05-28-2018, 02:27 PM | #8 |
Rep 16,149
I've used acetone to get rid of stubborn stains and it didn't bother the paint. Of course I tested it first in a spot that you can't normally see. I wouldn't pour it on, just put some on a rag and then wipe. I use lacquer thinner too, same technique. If you were to pour it on and leave it there just about any solvent will damage paint, but a quick swipe won't bother it. I just did so today with lacquer thinner to prep some scratches before applying touch up paint. If you don't then any wax or sealant will keep the paint from adhering.
05-29-2018, 10:56 PM | #9 |
96
Rep 153
Drives: 2014 428xi Sport Line
Let the detailer take care of it...that’s what you are paying him/her for anyway. And they will have all the proper chemicals to remove the tar. Because as you said it’s everywhere.
If not then Gunk Tar and Bug Remover or WD-40 and a few micro fiber towels. You will have a smeary mess but that will wash off with a good wash or two. |
05-30-2018, 11:12 PM | #11 |
Rep 7,484
You risk grabbing the tar and scratching your paint so no clay is not a good idea at this stage. However, it could be used once the tar is removed to deal with microscopic tar and contamination. Agree with recommendations for Meguiar's or Stone.
05-31-2018, 01:43 PM | #12 |
52
Rep 88
Drives: 2008 335xi coupe
Citrol 266 is another excellent choice.
PPK | Mishimoto FMIC | ER CP | Forge DVs | RB Inlets | RB PCV | BMW PE | Dinan springs/Koni Yellows
06-01-2018, 01:47 AM | #13 |
Rep 1,063
CarPro Tar X.
1QuikWS61621.50 Blubaron791434.50 |
06-06-2018, 04:52 AM | #14 |
No 55mph
1622
Rep 8,477
^^^^^^ THIS ^^^^^
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-11-2018, 06:03 PM | #15 |
Rep 1,487
Drives: 2108 X3 xDrive30i
I've used paint thinner on a soft cloth to soaked the spots. It lifts off when wet. Rub gently though. Don't be rough with them...keep blotting with paint thinner.
06-17-2018, 12:12 PM | #16 |
Rep 4,724
I just had this happen to me! Use Tar X by car Pro. It is amazing and melted away. It was even safe enough to use on my clear bra.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
