04-13-2015, 09:47 AM | #309 |
General
10487
Rep 40,969
1) If you read SVT, it assumes you physically have the ECU's stored in your SVT in VCM.
2) Mixed Red / Blue is because it had no CAFD and when you injected one it became a Target (Red). After VO Coding, reread SVT, and it won't be Mixed Red / Blue anymore.
04-13-2015, 11:44 AM | #310 |
Rep 1,035
04-13-2015, 11:49 AM | #311 |
General
10487
Rep 40,969
Why does it have to do that? It simply makes an assumption you have same one.
04-13-2015, 03:54 PM | #312 | |
Rep 1,035
If it doesn't detect there's new hardware, and if the CAFD file is the exact same as for my original REM (so the coding is the same), then why did the error go away? Or put another way, why did the trunk error even come up in the first place after swapping out the REM? Shouldn't the coding for the original REM work for the new REM as well? Btw... i had done no coding to the original REM prior to the swap. It was still at the factory default settings. |
04-13-2015, 04:08 PM | #313 | |
General
10487
Rep 40,969
04-13-2015, 08:17 PM | #315 |
General
10487
Rep 40,969
PM sent.
04-14-2015, 11:39 AM | #316 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
Hey Shawn,
I have a 2014 f32 435xi, build jan/2014 if it matters, I'm new to coding, do I need anything besides the cable, e-sys(I'm guessing 3.26.1), and PSdZData Also, could u send me the files? Thanks in advance |
04-14-2015, 04:21 PM | #317 |
Rep 1
Programming and coding used ACC (FRR) unit
Hi,
Can you please help me with flashing used (from eBay) ACC (FRR) unit? After installed in the car it reports "interface error" (invalid signal). I would like to flash it with E-Sys. I clicked "HW-IDs from SVTactual" after SVT calculation because I don’t know the existing I-Step. I get this error while flashing: [FRR - 21] - [Exception - FRR - 21] job failed with negative response error: code: repeat job description: Service RD returned a negative response with response code requestOutOfRange; ECU: FRR_21_ETHERNET severity: ERROR What can I do? |
04-14-2015, 05:17 PM | #318 |
General
10487
Rep 40,969
PM sent.
04-15-2015, 01:53 PM | #319 |
124
Rep 264
04-15-2015, 02:06 PM | #320 | |
General
10487
Rep 40,969
You must now Inject new CAFD into ECU and VO COde it.
04-15-2015, 05:54 PM | #321 | |
124
Rep 264
How do I go about fixing this? Is the problem with my laptop or the car? Everything seems to be functioning fine with the car thank god. No cels or funny business. |
04-15-2015, 05:56 PM | #322 | |
General
10487
Rep 40,969
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level Shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
04-15-2015, 06:00 PM | #323 | |
124
Rep 264
Out of curiosity, what's your day job? |
04-15-2015, 06:09 PM | #324 |
General
10487
Rep 40,969
An Engineer in Oil & Gas.
04-15-2015, 09:44 PM | #326 |
General
10487
Rep 40,969
04-15-2015, 09:50 PM | #328 |
General
10487
Rep 40,969
No. I'm involved in Rig Equipment manufacturing.
04-17-2015, 02:25 PM | #330 |
General
10487
Rep 40,969
PM sent.
