BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > No Electric and huge loss of power after pothole
      06-10-2014, 07:35 PM   #1
alex492
Drives: 2008 BMW 335xi
So I was driving home today and hit a pretty bad pothole. Afterwards all the electric inside the car besides the radio went out. Gauges were stuck, no A/c, no blickers, can't even lock the car. But windows still did work. Then as I slowed down I realized I had barely any power at all. The engine was revving up slowly but no power to the wheels. Once I got home I disconnected the battery for 20 mins, then plugged it back in and still no change. I tried to start the car and it took a bunch of turnovers and it barely started, almost conking out.
Anyone know what this is? I do have a JB4 in the car so Im hoping that didn't do anything.
      06-10-2014, 07:38 PM   #2
e92_enthusiast_1
e92_enthusiast_1's Avatar
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
Wow this symptoms been popping up a lot recently. Check your serpentine belt, sounds like it busted The older e9x models have a known issue where the belt can rub/hit the subframe esp if you hit a huge pot hole
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      06-10-2014, 07:45 PM   #3
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Drives: '18 x1/'13 X3/'06 330i
2006 BMW 330i   [0.00]
+1
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada
18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec
      06-10-2014, 07:47 PM   #4
Wires
1646
Drives: 2016 340i xDrive
I'd suspect that a plate broken in the battery.
      06-10-2014, 07:48 PM   #5
e92_enthusiast_1
Interesting theory, that doesn't get mentioned around here a lot. What say you OP!?!?!
      06-10-2014, 07:54 PM   #6
alex492
would the belt affect the electrical power in the car?
      06-10-2014, 07:56 PM   #7
e92_enthusiast_1
The belt runs all your electrical accessories (alternator) plus your power steering.
      06-10-2014, 07:56 PM   #8
Miller335
291
Drives: 2007 E92
Yes your alt.
Check your belt man, don't start your car again until you inspect the belt and lower pulley (power steering).
      06-10-2014, 08:04 PM   #9
alex492
just checked the belt and it looks fine. someone told me it could be the fuse on the positive terminal of the battery that blows when the car is in an accident? Has anyone heard of this before?
      06-10-2014, 08:05 PM   #10
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
Drives: Slow..
2007 E92  [5.00]
yikes..
      06-10-2014, 08:05 PM   #11
e92_enthusiast_1
Hmmm, that's true. I've read about that happening. Some kind of fail safe. Can't hurt to look.
      06-10-2014, 08:12 PM   #12
alex492
do you know how to check that? i looked around the battery and couldn't find anything
      06-10-2014, 08:45 PM   #13
PhaseP
1007
Drives: 325XI
It is called a Battery Safety Terminal (BST), a whole lot of information on that here:
Another one that shows some sort of repair, I am not vouching for it. It shows the internals:
      06-11-2014, 10:33 AM   #14
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
So called IBS sensor. I believe you would have a dash code (ccid-391 if I am not mistaken) if that was the case.
      06-11-2014, 06:00 PM   #15
alex492
Yeah im not sure because I have no electric whatsoever in the dash, the gages are still stuck the speed and rpm i was at. But the weird thing is that the car starts
      06-11-2014, 06:45 PM   #16
AcesUp
Drives: 335i
Sorry to hear that and hope you find a solution soon. These potholes have been beating on me this spring. 2 blowouts in 2 weeks. Have they fixed a single pothole in NYC yet? I haven't seen a road crew out working on anything, anywhere, so far this year. Usually it's non-stop roadwork all over the place.
The city ain't broke so I figure de Blasio is waiting for the greasing from the road repair companies to reach acceptable levels.
      06-12-2014, 05:32 AM   #17
PhaseP
1007
Drives: 325XI
IBS (Intelligent Battery Sensor or something like that) is on the negative battery terminal. Battery Safety Terminal, BST, is on the positive battery terminal. IBS is basically a precise low value resistor, which allows the computer to measure the current drawn from the battery by the voltage drop on this resistor. IBS is mentioned to be somewhat fragile and needs to be handled by care.
BST as described in depth in the youtube links I posted above, contains a small explosive device, that computer explodes it by some current applied to it in case of an accident. The force of that small explosion pushes the main positive battery cable away from its connection internally. Meant to prevent fires what not in case of accident. There is still another positive battery cable connected to the battery post that bypasses the BST to power up certain things in the car even in case of accident I think. I don't know if this other positive cable good enough to start the car. Those videos tell how to check for the BST.
There was a recall for 2007 and older I believe for a battery terminal issue, you can look up and try to find if it applies to you and whether or not recall was done on your car.
      06-12-2014, 05:45 AM   #18
PhaseP
1007
Drives: 325XI
This is the recall news I had seen:
http://www.bmwblog.com/2013/02/17/bm...le-connectors/
      06-12-2014, 10:48 AM   #19
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
All correct, but in any case, with a BST failure, the car would not start at all. With an IBS failure, some electric remain operative, but not all, however, there should be a code, but since your dash is dead, maybe there -is- a code, you just can't see it.
You checked that all fuses are well engaged, first, right ? Could be that simple and matches symptoms.
The battery cable recall is also a very good candidate for the root cause of your problem.
      06-12-2014, 11:53 AM   #20
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Was it a pothole, or a sinkhole? Jesus.
      06-12-2014, 12:00 PM   #21
PhaseP
1007
Drives: 325XI
RFT plus XI makes pothole hits explosive.
      06-12-2014, 12:30 PM   #22
PhaseP
1007
Drives: 325XI
I am afraid you have this inaccurate. There are two thick red positive cables that come to the battery. One goes to BST that is right beside the positive terminal of the battery. This one is a bit thicker than the other positive cable. The other thick positive cable comes on top of the battery and gets connected there to a bolt, which underneath gets directly connected to the battery post by a plate. This one therefor bypasses the BST. Like I said, I don't know what each of these cables power, but even after BST blows up, there is a second thick wire attached to the battery positive terminal. I don't know if this would power the starter or not. But this is what I see when I look at my battery. (I see a third positive cable that comes there, but this is thinner, probably for some accessory)
And also on the negative battery terminal, there is only one black thick wire attached to it, via the IBS, the rectangle metal thingy. If IBS is broken or something like that, there is no other cable to by pass it to provide negative battery connection. Now, it may be not connecting well raising the resistance or having intermittent issues, or the sender wires got broken or detached (the two small wires that come to the IBS) those are different story.
335xi, no electric, no power, pothole
