07-11-2018, 08:59 AM | #23 | |
1032
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-12-2018, 01:36 AM | #24 |
TH320i
23
Rep 41
At this moment in time i have no clue what exact part of the system is failing but all i kno, is i have been having the rough idle and no power bellow 3000 rpm symptom for quite sometime...
What is the usual practice? Just the solenoid and seals or replace the whole thing? https://www.realoem.com/bmw/enUS/sho...diagId=11_4773 https://www.realoem.com/bmw/enUS/sho...diagId=11_4765 Cheers guys !
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
07-15-2018, 03:16 PM | #26 | ||
Grand Poobah
174
Rep 305
2014 328i XDrive N26 (F30), bootmod3 Stage 2 AGG, VRSF Catless Downpipe, K&N Drop In Filter
07-15-2018, 03:18 PM | #27 | |
Grand Poobah
174
Rep 305
07-15-2018, 09:29 PM | #28 |
Rep 3,680
Jeez, I didn't know you motor blew When did this happen, recently?
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
07-15-2018, 11:37 PM | #29 |
14
Rep 137
N20 11:1 compression: Safety zone 17psi.
N20 10:1 compression: Safety zone 21.7psi. Anything above it, you are pushing it. Check your compression. There are cases when the sidewall of n20 which is using electric arc wire coating are damaged. |
07-16-2018, 04:16 AM | #31 |
Rep 3,680
07-16-2018, 04:17 AM | #32 |
Rep 3,680
What makes you say these numbers specifically are the safe zones? Even a little stage 1 tune puts you at 21. I think they're a bit higher than that.
07-16-2018, 04:20 AM | #33 |
14
Rep 137
on the 20i compression 11:1, stock boost is 0.8bar or 11.6psi.
for 28i compression 10:1, stock boost is 17psi. this is base on my experience of seeing n20 engine internal go kaboom. you can go higher, no one is stopping you. |
07-16-2018, 04:33 AM | #34 |
80
Rep 307
There’s way too many variables. Someone running e85 may be able to run more than someone running 93 or 91 octane. Someone in Utah, May be running more because of the elevation. Ie 24 psi in Utah may be like 17 psi at sea level.
07-16-2018, 07:42 AM | #35 | |
Grand Poobah
174
Rep 305
long story to say, IMO with our motors, datalog often. 22psi on stock internals is the highest I would want. anything above is flirting with danger. when I was running JB4, I was running 22psi with a downpipe and stage 1. Stage 2 flirted with 24 and then overboosted twice which most likely caused me a motor. take caution. I'm running BM3 stage 1 now in the safe zone. its smooth as silk compared to JB4 and I don't have to worry about excess boost.
07-16-2018, 08:53 AM | #36 | |
1032
Rep 2,382
Also, off-topic regarding the oil we talked about in another thread (which I may just post this same response lol), I changed the oil this weekend and surprisingly nothing in the filter this go around. Would like to get a second sample for the oil analysis with no Ceratec.
07-16-2018, 09:41 AM | #37 | ||
Rep 3,680
Aekdbrich174.00 |
07-16-2018, 11:30 AM | #38 | ||
14
Rep 137
07-16-2018, 01:38 PM | #39 | |
80
Rep 307
I’m curious to see what the oil analysis says though. |
07-21-2018, 09:02 PM | #40 | |||
Grand Poobah
174
Rep 305
09-21-2018, 04:08 PM | #41 |
Rep 13
I ran jb4 on my 320i with a Downpipe and full exhaust and drop in flatbed filter. I had a custom map running 26psi which sometimes peaked at 30psi and I used 30-40% ethanol mix. The car can handle it as I used to run this map almost every week for about 4 months. I had the car running this boost from 80000km till 95000km with no issues.
09-21-2018, 04:40 PM | #42 | |
1032
Rep 2,382
09-22-2018, 03:13 AM | #43 | |
Rep 13
Heres a few logs. i dont have logs for up to 30psi as these were once in a while over boosts. as you can see my boost limit was set to 32 (31.9) psi as at anything lower the jb4 kept switching to map4. The N20 is really strong and with my custom map, i beat a lot of fast cars even diesel cars with BT. On the TOP my car should hit limiter quick n fast lol My Map 7 on a dyno made 224wkw and 450nm. With my custom map 6 i never dyno it but am sure i made around 230wkw and around 490nm |
09-22-2018, 11:44 AM | #44 | |
1032
Rep 2,382
M2_MEDUSA668.50 |
320, boost, n20, peak, psi |
