2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Stock/Stage 2/Stage 2+ E50/Big Turbo
      06-01-2023, 02:41 PM   #23
CatchF22DirtyF30
CatchF22DirtyF30's Avatar
Drives: BMW | B58 F22 || Audi B9 S4
2017 BMW M240i  [9.50]
2019 Audi S4  [10.00]
Hey All,
Interesting numbers to look at here, with some hypothetical opinions sprinkled in.
Hopped into configuration for the BM3 S2+ tune and adjusted a few goodies:
-Reduced burble length to refine the decel. And not sound ricey. (What a change, sounds more exotic)
-Added in the GTS roar (people have to know its starting…)
Then the topic of discussion… MAX COOLING ENABLED.
As a background the Max cooling mode keeps fans on as well as other adaptations I am unaware of at this point.
That said, under normal driving conditions Engine Oil temp would sit pretty stead at 223*F and engine temp very similar.
With max cooling mode engaged both temps sat around 172*F. Thats around a 20% decrease in both engine an oil temps. Which for summer driving, keeps things inside the engine happy!
Or not?
After debating this, and theorizing; it can also cause prolonged and unnecessary strain on the cooling systems.
Post your thoughts, or any data points for discussion!
      07-05-2023, 03:21 PM   #24
CatchF22DirtyF30
Did the sequential mirror signal install recently, as some have seen on the 2 series posts!
Here is the link for those following here ok the installation process.
https://youtu.be/ulLQT1Rgod8
      07-05-2023, 09:43 PM   #25
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
You want your oil to heat up enough to evaporate moisture in it, otherwise sludge forms quicker. 172F under constant driving is too cool.
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
      07-06-2023, 04:12 PM   #26
bigmoneywaster13
bigmoneywaster13's Avatar
Drives: 2020 BMW M240i RWD Auto
Thanks for all the updates man! Looking forward to seeing more of your car
      07-06-2023, 04:16 PM   #27
CatchF22DirtyF30
Thank you for the feedback, had turned that feature off pretty quickly there after due to this exact thought.
Only plausible for use on the track.
      07-06-2023, 04:19 PM   #28
CatchF22DirtyF30
Thank you for taking the time to follow!
Check out my Youtube page for more content, installation videos and reviews!
https://youtube.com/@BackyardMotorWerks
OR02130.00
      07-17-2023, 12:16 PM   #29
CatchF22DirtyF30
Not a performance Mod, but tossed on the Mcarkit, type C carbon fiber front lip this weekend.
Must say it fits like a glove, very impressive with Amazon on this one. Costs $200 less than the other site that showed the same product photos.
The shipping did take a month, that was a downside. They also did not capture the payment until the item shipped a few weeks after the initial purchase. That was frustrating as well, but a minor inconvenience.
      10-02-2023, 04:21 PM   #30
CatchF22DirtyF30
Finally getting back to the Dyno tomorrow to get E50 numbers on BM3 Stage 2+.
This will have a massive inlet and new intake on from the last time as well. However if you follow this post, low fuel inhibited a good read.
Also finally got a Front Lip on the car. This is the C-style by MCarKit from Amazon. Review and install link below.
https://youtu.be/rzJVCv-nA54?si=WHY2fXHmw-dSIrGO
OR02130.00
      10-03-2023, 11:28 AM   #31
CatchF22DirtyF30
NUMBERS ARE IN!
460WHP/530WTQ
This is on a perfect 50% Ethanol mix on the newest revision of BM3 Stage 2+
This is only using the TU pump
Power maxed out at ~5,500 RPM, showing the choke at the turbo… which you know what that means.
Most likely will close out this year with maintenance (plugs, coils, fluid flushes, ETC) then on to Hybrid and stage 2 HPFP next season.
Dom14790.50
      10-03-2023, 11:48 AM   #32
atek
I like biscuits
atek's Avatar
Drives: bmw m235i
Very nice numbers! Yea, stock turbo is definitely dying off up top.
      10-04-2023, 09:19 AM   #33
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Sweet! Those are great numbers. How does the car drive?
2024 M2
2019 M240i- Sold
      10-11-2023, 10:38 AM   #34
CatchF22DirtyF30
She drives like a dream, little turbo lag and feels rock solid. I was able to stay neck and next with a stage 2 FBO S55 on 93. Very happy with these results.
DS2 next, then thinking DAW 2.5+ next.
JMcLellan2066.00
      03-27-2024, 12:03 PM   #35
CatchF22DirtyF30
Been a long cold winter, but back at it again with the M240i build.
We recently installed the 6” downpipe! Here are some sound clips, and yes it really did help the note.
Next step is the full 3.5” mid and rear section. https://youtube.com/shorts/D55g95Xqt...q4HK_TFLipLTQF
2addicts
