12-18-2009, 01:46 PM | #46 |
517
Rep 3,612
12-18-2009, 01:50 PM | #47 |
517
Rep 3,612
Year/model BMW:
2008 M3 Coupe Wheels/offset: Front: BBS CH 19x8.5 et20 Rear: BBS CH 19x10 et20 Tire size: Front:Nitto Invo 255/35/19 Rear: Nitto Invo 275/35/19 Suspension: KWV3 Spacer size: Front: 12mm Rear: 10mm Last edited by brandon @ eas; 12-21-2009 at 03:04 PM.. |
12-18-2009, 09:27 PM | #48 |
33
Rep 322
Wow the pictures turned out great Brandon! thanks for taking the time to snap a couple for me. just to help with the details you listed i edited it for you.
should be: Year/model BMW: 2008 M3 Coupe Wheels/offset: Front: BBS CH 19x8.5 et20 Rear: BBS CH 19x10 et20 Tire size: Front:Nitto Invo 255/35/19 Rear: Nitto Invo 275/35/19 Suspension: KWV3 Spacer size: Front: 12mm Rear: 10mm
12-21-2009, 03:05 PM | #49 | |
517
Rep 3,612
Awesome! Thanks for the details, it's all updated now |
04-25-2010, 12:00 AM | #52 |
8224
Rep 18,823
Drives: BMW
Not at all, other than selecting the incorrect (or inferior) fasteners in which the Macht Schnell kits already have lugs included for a complete package.
Whi;e its best to get a wheel with the correct offsets to your vehicle, some think a bit "out of the box" and utilize spacers for "fine tune" final fitment allowing for wider wheels or tires to tuck underneath. Also. lots of OEM companies (including Porsche) use spacers as an OEM part.
04-25-2010, 09:47 PM | #54 |
8224
Rep 18,823
Drives: BMW
The RDs offer the lowest drop among all the springs - it would look awesome.
04-26-2010, 02:53 AM | #55 |
13
Rep 120
05-03-2010, 06:06 PM | #56 |
517
Rep 3,612
Year/model BMW:
2010 M3 Coupe Wheels/offset: Front: VMR V718 19x8.5 et20 Rear: VMR V718 19x9.5 et22 Tire size: Front:Hankook Ventus V12 245/35/19 Rear: Hankook Ventus V12 275/35/19 Suspension: H&R Sport springs Spacer size: Front: NA Rear: 10mm |
05-10-2010, 02:11 PM | #57 |
is probably out riding.
6058
Rep 2,292
Ok... a couple of questions....
My car is pretty darn low with at set of TC Klein coil overs. Seems that some of the lowered cars listed use 12 - 10mm spacers for stock 19s. Is that about the norm? On the pic of the AW car with the Ericsson kit, the felt covered air diflectors under the front end are missing. Can you simply eliminate those and still use the stock bumber cover? I've heard several people say that spacers are ok, even for heavy track use; but they also say that you should switch to a studs and lug nuts rather than extended lug bolts. Is that what MS's kit comes with or are they extended lug bolts? That's really the only thing holding me back from spacers is the fact that lots of load is placed on those extended lug bolts. i'm not an engineer but it seems that as the lug bolts are lengthened the leverage point of the wheel in also increased placing even more stress on the lug bolts. Thanks for this thread. Lots of good info... and pretty pictures too.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
05-10-2010, 02:52 PM | #58 | |
8224
Rep 18,823
Drives: BMW
The spacer thicknesses used are very minimal (for instance, Ferrari models use a 40mm with no ill effects) and not something to worry about when it comes to bearing life.
05-10-2010, 03:32 PM | #59 |
Rep 3,899
A few questions i hope the more knowledgeable members maybe able to help with, many thanks!
Picking up my new E90 M3 in July and love the looks of the 12/15 spacers with a eibach drop. My only concern is that while this looks great i will occasionally have a full load in the boot and back seats (when taking the family on holiday etc) - will this cause me an issue? Also if these spacers/drop combo's improve looks and handling then why does BMW not 1. make them like this from the factory 2. Offer this as an OEM upgrade kit? - There must be some drawbacks to the spacers I regularly travel at high speeds on the Autobahn, are these kits designed to repeatedly take that sort of punishment? |
05-10-2010, 04:49 PM | #60 | |
257
Rep 4,048
The 15/12mm sizes are close to what is the most you could put on the car, but even with a full load of passengers, there's no need to worry. Customers have left us with 15mm/12mm sizes as the best to go with as they don't rub w/ coilovers, springs, or stock suspension. |
05-10-2010, 05:45 PM | #62 | |
Rep 3,899
05-11-2010, 12:21 PM | #63 |
517
Rep 3,612
Im sure some dealers do. I used to work for Mercedes Benz, and noticed that when I would visit some dealers, almost all of the cars in the showroom (the more performance oriented cars) had spacers on. Mainly the AMG cars, Braubus etc
05-14-2010, 12:21 PM | #65 |
Formerly K335i
19
Rep 215
BMW is required to leave a certain amount of clearance for low profile snow chains, which is why cars don't come from the factory with the most aggressive stance possible.
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
05-19-2010, 03:57 PM | #66 |
Rep 55
For OEM 19's on stock suspension, I'm having trouble deciding between 18mm front/15mm rear, or 15F/12R. In some pics, the 18/15 looks flush, but in other pictures, it looks like it sticks out a bit past the top of the fender, especially on the back.
On the other hand, in some pics the 15/12 looks flush, but in other pics, it looks not quite flush. What do you recommend? Thanks in advance. |
