05-31-2018, 05:28 PM | #1 |
53
Rep 150
JB+ - Engine Lugging
I wouldn't necessarily say the engine is lugging, but that is the best way I can describe it, and it only happens when the JB+ is installed.
I've had the JB+ for probably a year now in my 2013 335i xDrive MT that has 36,000 miles. This started happening recently. When the engine is cold and usually between 2-3k RPMs it lugs. At first I thought to myself "did I forget how to drive a stick?" But I made sure the clutch was fully engaged and it still happened. I removed the JB+ to see if there was still an issue, and it hasn't happened since I removed it. Which was about two weeks ago. Has anyone encountered this and know what is the cause and fix? |
05-31-2018, 05:40 PM | #2 |
Masterchief
370
Rep 1,026
If you are referring to the engine having a rough idle and sort of jerkiness when the engine is cold. then yes i have encountered this issue before.
i've noticed that when i give adequate time for the engine to warm and do no step on the throttle aggressively when the engine is cold i do not have this problem.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
05-31-2018, 05:44 PM | #3 | |
53
Rep 150
And as I mentioned, I've had the JB+ for about a year, and this just started. Seems odd that it would start all the sudden. |
05-31-2018, 06:15 PM | #4 | |
Masterchief
370
Rep 1,026
05-31-2018, 06:37 PM | #5 |
53
Rep 150
05-31-2018, 06:40 PM | #6 |
Masterchief
370
Rep 1,026
isnt the answer like bms or burger
05-31-2018, 06:45 PM | #7 |
53
Rep 150
06-01-2018, 06:56 AM | #8 |
4924
Rep 116,006
You can use the dial on the JB+ to adjust boost up or down as needed. Beyond that there are no diagnostics and if something was wrong with it you'd get a sensor faulty code or similar.
Mike |
06-03-2018, 03:23 PM | #9 | |
14
Rep 19
Can someone offer words of wisdom here, please? |
06-04-2018, 08:29 AM | #10 | |
4924
Rep 116,006
Mike |
06-04-2018, 10:04 AM | #11 |
9
Rep 17
I have the same issue. I got back to the BMS guys they advised to gradually move the boost adjust dial from minimum up. Mine starts lugging from 3 o'clock position (I guess it's 1 bar above stock) The issue is that this way no noticeable power gain. BMS sad it's a petrol quality issue not much can be done...
...so I ditched the thing |
06-04-2018, 11:50 AM | #12 | |
14
Rep 19
Thanks, Tommy |
06-04-2018, 02:52 PM | #13 |
53
Rep 150
06-06-2018, 03:10 PM | #14 |
20
Rep 99
I have been plagued by an issue where the engine will start stumbling around 4k rpm usually in 3rd gear but sometimes in 2nd gear when I'm flooring it from a stop. I took the car in to the dealer last week (JB+ removed) and mentioned the stumbling thinking it was a plug or coil issue. Car has 36k miles and they couldn't recreate it and it showed no codes for a misfire.......and I can't recreate it myself with the JB+ off the car. I've thought that maybe I'm hitting a torque limit value such as has been discussed in the MHD thread to where the engine is programmed to cut boost/throttle in certain gears when certain torque values are reached.
burger, burgertuning, jb+, lug, lugging |
