BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
GetBMWParts
      08-22-2018, 09:00 PM   #23
Jagaer
430
Drives: 2011 E91 328xi 6MT
Shophopper If BMW changes the 2 x 2 byte pattern to identify each map year & geographical location, the FSC generation routine will need to change as well.
For advanced users (ones who have the byte sequence before the Lookup.xml file is updated), I'd recommend using the console version, which gives you that flexibility.
      08-23-2018, 04:34 PM   #24
reprobcn
Drives: x6 40d xdrive year 2012
when putting the pen it just tells me to update
but if I do it in windows I do not see the file for the keygen
      08-25-2018, 06:20 AM   #25
deneyer
Belgium
35
Drives: BMW
Does this work for nbt evo aswell or just nbt?
      08-25-2018, 06:26 AM   #26
Jagaer
430
deneyer This trial verson may work for EVO ID4: https://f30.bimmerpost.com/forums/sh....php?t=1529040
If you have an F0 file, it would be helpful for additional testing.
      08-31-2018, 11:05 PM   #27
seattleweather
Drives: 2014 X3
Jagaer,
How do we know the VIN Build Date? My car is 2014 model, and i bought end of 2013. Carfax shows 10/13 local dealer did pre-delivery inspection.
Thanks.
      09-01-2018, 01:59 AM   #28
Jagaer
430
seattleweather Put the last 7 of your vin into a decoder, such as: https://www.bmwvin.com
In the output, one of the lines will be something like: Prod. Date 2010-08-18 --
That is your build date.
      09-01-2018, 09:06 AM   #29
seattleweather
Drives: 2014 X3
thank you very much.
      09-15-2018, 06:11 AM   #30
reprobcn
is possible file read for vvdi2 ?
      09-16-2018, 10:33 AM   #31
wasimakbar
Drives: BMW M3 (F80)
The generator forces you to select each option, which is why it is greyed out.
Enter your VIN. If the VIN isn't valid, it will not let you select a date.
Select a Date, and the Map Type field will become active.
You need to select a map type. Even if "Premium" is displayed, it will not let you select a region until you click on "Premium"
You need to select a region. Even if you want "Arabian Gulf", it will not let you select a Map Year until you click on "Arabian Gulf". etc...
I hope this is a bit more clear.
Hi Jagaer
I've been following all of the above for the FSC code for my car; however, every code it's given seems invalid in my car.
I've selected the correct Map (NBT, Europe NEXT 2018-2), nearest production date (mine is 2014/10/31) and the one before and the one after.
None of the codes that are generated work on my car.
What am I doing wrong???
      09-16-2018, 04:58 PM   #32
NZgeek
New Zealand
Drives: 2013 BMW ActiveHybrid 3
@wasimakbar I don't think that the production date list is exhaustive. It's quite likely that you've got a key that isn't on that list.
I finally got around to hooking up E-SYS to my car in the weekend and pulled out the FSC info. I used the FSC file to generate a code, and then generated codes from around my production date (2012-10-12). None of the date-based codes matched.
If you can, use E-SYS to pull your FSC data and use that to generate a code. Adapters and cables are fairly cheap and easy to find on places like eBay.
      09-17-2018, 03:20 AM   #33
wasimakbar
I'm just a bit nervous doing anything other than copying data to USB and entering codes, as I usually mess things up and the last time I done something like this it didn't end well.
My car is under warranty so I also don't want to do anything that will get me on the wrong side of the dealers.
Any other way of getting the correct FSC codes for my car?
@Jagaer anything you know of?
      09-21-2018, 02:40 PM   #34
ir655
Sweden
Drives: F31 320d and F11 530d
Can someone please upload this somewhere where I can download it?
Link in post #1 is now only for premium users :/
      09-21-2018, 05:23 PM   #35
Jagaer
430
Links updated
      10-01-2018, 08:17 AM   #36
catello.catullo
Drives: bmw x1 e84
FSC code for X1 E84
hi
problem for x1 year 2015
FSC code please
vin: vw74173
ROAD MAP EUROPE WEST MOTION 2018-2 USB
Testing keygen invalid code
      10-03-2018, 04:44 AM   #37
reischi82
Drives: F31 LCI 320xD
Jagaer
I have downloaded v1.9 of your Generator and recently stored F0 from my F31 LCI from 2015 that should have NBT EVO ID4. I want to test if this does work but as I already do have 2018-2 installed into my car I do need 2018-3 but it is not possible to select using drop-down.
Can you please assist me so that I can test?
      10-03-2018, 05:32 AM   #38
atzebmw
Germany
590
Drives: Tesla Model 3
Originally Posted by reischi82 View Post
Jagaer
Can you describe how you saved the "F0"-file?
I also tried it but it did not work (also NBT Evo ID4).
      10-03-2018, 06:16 AM   #39
reischi82
I connected using e-sys and went into expert mode where I used below listed settings:
Diagnostic Adress (hex): 0x63
Application Number (hex/dec): 0xF0
Upgrade Index (hex/dec): 0x01
after selecting Identify I think I remember that there was "HU_NBT2" or similar
using this I was able to read "storeFSC" and save it to my local drive
atzebmw590.00
      10-03-2018, 06:33 AM   #40
atzebmw
Germany
590
Great.
Thank you very much.
Now i see my mistake.
I was using Application Number 0xDE instead of 0xF0.
      10-03-2018, 06:38 AM   #41
reischi82
Great.
what version of map do you have currently installed? do you have an older one so that you can test if the app does work for creating keys?
      10-03-2018, 06:42 AM   #42
atzebmw
Germany
590
I have the latest version 2018-3 Evo installed.
I was lucky enough to be able to install it without asking for a key.
      10-03-2018, 06:57 AM   #43
reischi82
I think I should also test if I can do so as my update has expired 2 month ago
      10-03-2018, 07:05 AM   #44
atzebmw
Germany
590
Yes, you can try it.
My car was built in 07/2015.
So I had the free updates until 07/2018.
The 2018-2 map was still in this time period.
But someday I still want to create the code myself.
