04-13-2019, 05:35 PM | #1 |
Rep 757
Noticed some clunking when driving at certain angles up a driveway so I decided to tighten up the strut tower bolts, this one in particular just wouldn't tighten and would spin freely. Took off the nut and all these shavings came out everywhere, now when I look at the stud the threads are clearly stripped out.
Does anyone have any recommendations to how to go about fixing this? Is it possible to hammer out the old stud and run a new bolt/nut through there? Thanks!
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
04-13-2019, 05:44 PM | #2 |
Rep 485
Depending on what the backside looks like, you might be able to take a cutoff wheel and cut the stud flush and then drill it out and replace it with a bolt.
WeekendWarriorz674.00 |
04-13-2019, 06:06 PM | #3 |
Rep 757
Backside is a flat piece which appears to be tack-welded on by a few points. So it appears that I should try to take this stud out and put my own bolt in?
04-13-2019, 07:51 PM | #4 |
Rep 485
I'm not saying it's the best option, but should work. The backside is flat and should function like a washer. I would dab some JB Weld on it so it stays in place when you take off the strut bars.
04-13-2019, 08:13 PM | #5 | |
Rep 757
My idea is to drill it out and then remove the tack welded piece and place a washer down, use a nut and bolt to attach it and if things work I'll have a shop tack weld it in place
04-14-2019, 02:37 AM | #6 |
My other car is on Mars
636
Rep 3,124
Just put a bolt through it and you should be fine.
If you can get a wrench on it, Bob's your Uncle. If not, I would try a star washer to keep it from spinning. I would try and Dremel off the weld(s) to get the original bolt out. My problem's at the other end. One of the mounts to the shock tower snapped off.
Warning: May contain traces of nuts.
04-14-2019, 02:41 AM | #7 |
Rep 882
The threads at the top of the stud looks fine, get a thick enough shim and a new nut. For both sides if you want it to look OEM like.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
3002 tii2303.50 |
04-14-2019, 08:01 AM | #8 |
2430
Rep 2,706
Drives: Built not Bought 04 Z4 VF
The stud is spot welded not tack welded.
The fusion is hidden under the mushroomed head. What you are seeing is the molten metal that ran out during the process. I suggest: 1. Cut off the stud flush to the bracket. 2. Drill a pilot hole as close to centre of the left over stud. 3. Finish drilling through with a bit 2mm larger than the original stud. 4. Insert a metric bolt to replicate original stud. Good luck with your repair.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
04-14-2019, 09:22 AM | #9 | |
Rep 485
Removing the welded stud will be very difficult as will welding in a new one due to the poor access. |
04-14-2019, 12:40 PM | #11 | ||
Rep 757
Thank you to everyone for the great input!
