BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Oil change -- what oil to use?
      05-07-2022, 01:44 PM   #419
Sandro95
Sandro95's Avatar
Germany
Drives: BMW 335is, BMW 328i Coupe E36
I use the Motul Ester Sport 5W50 in my 335is and it works great. I change the oil all 8-10k kilometers(5-6k Miles). No problems since 3years with this oil.
      05-07-2022, 05:16 PM   #420
edycol
Drives: 2011 328i xDrive
You don't need such oil. Actually you are being counterproductive here
1. It is high HTHS oil with some 4.4cp. N54 needs 3.5-4cp. What you doing is creating unnecessary heat and drag. Your turbos need bit more time to spool. Basic rule if lubrication: as thin as possible, as thick as necessary.
2. Sport is only API certified, which mean Noack limit is 15%. N54 has issues with CBU and you might be contributing more than necessary.
3. BMW engines are oxidation monsters. Sport is ester based which means it has higher oxidation than street oil.
Sport is good oil if you spend a lot if time at the track and when I mean a lot, I mean every weekend.
Get Castrol Edge 0W40!
POBEP367.00
      05-08-2022, 02:46 AM   #421
Sandro95
Sandro95's Avatar
Germany
Thanks for your answer, I didn't know that! By the next oil change I will try the Castrol Edge 0W40.
      05-08-2022, 09:35 AM   #422
edycol
This made me think; which country are you in?
If EU country, go LL04 oil. N engines were always LL04 in Europe. If you want thicker oil go Motul X-Clean 5W40 GEN2. It has HTHS of 3.9cp. LL04 is Low-SAPS oil and it will reduce amount of CBU on your intake valves. Not prevent it, but reduce it.
POBEP367.00
      05-12-2022, 10:15 PM   #423
HB E90
HB E90's Avatar
60
Drives: 2010 E90 335i Space Gray
What do you think of the Castrol Edge 5w-40 Euro that is LL01 sold at walmart and others?
2019 F150 S Crew 4x4 3.5 Twin Turbo - newest $$$ pit
2010 E90 SG 335i Sport, Premium, Nav. MHD, VRSF CP, 5" HD FMIC, DCI's, 1 step colder NGK's, Apex EC-7's and Michelin PS4S, Cree 6000k H8 LED Angel eyes SOLD
2011 Toyota Tacoma DC TRDOR 4x4 lifted and armored SOLD
2014 Acura MDX SHAWD wifes
      05-13-2022, 12:03 AM   #424
edycol
Mediocre.
Pennzoil Platinum Euro 5W40, Motul X-Cess 5W40 GEN2, Quaker State Euro 5W40 (repackaged Pennzoil) and Valvoline European Vehicle 5W40 are all better.
QS Euro goes $18 for 5qt on Wal Mart web site.
      05-18-2022, 12:54 AM   #425
Sandro95
Sandro95's Avatar
Germany
Thanks for the information. I'm from Germany. Next time I will try the Motul X-Clean 5W40
      01-20-2023, 09:04 AM   #426
FimbulWinter
FimbulWinter's Avatar
27
Drives: BMW E90 325i 2012 B25
  [0.00]
2011 E90 N52B25  [0.00]
  [0.00]
Which oil weight should I use for N52B25 in 30 to 40 celsius tropical climate, 5W-40 enough or should i go 10W-40?
      06-06-2023, 07:51 AM   #427
w23drw
England
Drives: bmw 318 e90
e90 318 performance diesel
hi all i have a 318 2.0 diesel has now done 114k looking to do a oil change and been told by a mechanic to use 10w/30 as will help due to the mileage
specs are as below
SAE: 10W-30
Classifications Met: API CJ-4, CI-4 PLUS/CI-4, API SM
help be appreciated
