04-28-2018, 09:18 AM | #67 | |
Rep 2,044
For your case, I can only think maybe an alignment issue. Sometimes shops have a hard time aligning modded cars, or even certain BMWs, which give them a choice of specs depending on car equipment. Do you have an alignment printout from your M3 LCA days? Murf |
04-28-2018, 09:43 AM | #68 |
Rep 1,296
Damn you're going to make me try again :-/
With F8x LCAs: Camber was -1°50' left / -1°23' right Caster was 7°49 left / 8°19' right (quite a lot - hence the rubbing) After changing back to stock LCAs : Camber -0°39 left / -0°43' right Caster 6°37' left / 7°01' right
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
04-28-2018, 10:30 AM | #70 |
Rep 1,296
For reference too on 2 addicts, talks about rubbing too:
https://www.2addicts.com/forums/show...1250352&page=9
04-28-2018, 12:48 PM | #71 |
Rep 2,044
From what I'm reading, it seems wise to get the TS links in addition to the LCA links, in order to get the caster closer to normal F30 values.
But correct me if I'm wrong, the TS arms will increase camber to ~ neg 2 degrees (with rear ~ -1.6 -2.1)? Is this too much for the F30 chassis? Lancelot, for the above alignment #s, did you have the M3 TS links in, or the normal F30 TS links, pls? Murf |
04-28-2018, 01:21 PM | #72 |
Rep 1,296
I had both, started with LCA only, added TS later on hoping to reduce caster, but that changes absolutely nothing, we compared both F8x and F3x TS side by side: no difference. And it was still rubbing after adding TS.
TS will not change camber at all, only caster, the BMW official repair manuals also mention alignment isn’t required when changing tension struts. What you can try if caster (and rubbing) was a issue is to fit the TS with caster adjustable bushings (powerflex, superpro...), this would allow to reduce caster a bit and try to get back within more normal values. |
04-29-2018, 06:01 AM | #73 |
Rep 2,044
Since this is a sway bar thread, I'm taking the LCA & TS talk to here:
http://f30.bimmerpost.com/forums/sho...6#post23124246 Murf Last edited by Littlebear; 05-07-2018 at 05:36 AM.. |
05-06-2018, 10:39 AM | #74 |
Rep 2,044
Hello BMW Experts!
We just got back from a 5-day trip to the ADK Mountains. All kinds of roads: truck rutted interstate, 4-lane parkway, fast 2-lane, slow 2-lane, & dirt! I even got stuck in mud up to the doors on a 'seasonal' dirt road. Had to dig myself out with hands & sticks (help was a loong walk away). But the car felt great! The addition of the M-sport rear bar got rid of lots of unwanted movement back there. With an empty trunk, the car is very fast, balanced, & well matched to these North East roads. To my mind, the rear is still a touch soft (Bilsteins, M-Sport springs & bars), but that's sort of an old BMW tradition? Murf |
12-16-2018, 07:48 PM | #75 | |
14
Rep 136
Most, in fact all used the spacer but you went 1 step with the bushing change? |
12-17-2018, 06:46 AM | #76 | ||
Rep 5,460
Drives: F30
12-29-2018, 03:17 AM | #78 |
Rep 1,247
M140i front arb question.
I managed to source M140i front and rear arb's from eBay.de before Christmas for a bargain allied to a 10% discount code. These are intended for my F36 435d x-drive along with Bilstein B14s. I've just realised when checking realoem that the front arb is listed under the F36 as fitting models with adaptive suspension only which my car isn't. Will this fit mine as the bar is listed as M140i 25.2/22.2mm? Realoem also doesn't list arb bushes for the front for some strange reason. Any idea where these can be sourced from? |
12-29-2018, 03:42 AM | #79 | |
Rep 1,296
I don't think there would be a problem fitting these, the only question is whether they're adapted to your chassis balance as they will affect understeer/oversteer behavior. Lack of bushings for front arbs: it's normal they come glued to the front bar and cannot be sourced separately contrary to aftermarket bushings.
12-29-2018, 04:37 AM | #80 | ||
Rep 1,247
I've done some more research on my X-Drive bar and the M140i bar and the designs look different which is leading me to believe the front won't fit. 19458 is the X-Drive bar. |
01-15-2019, 05:28 PM | #81 |
Humanist
272
Rep 398
Just picked up a new F31 330i xDrive M sport with adaptive dampers. RealOEM shows a 13mm rear bar. Planning on adding ACS Springs + Dinan Shockwave and looking for ARB suggestions. Also, any reason why F80 bars won't work/aren't listed? I know just adding an OEM E9X M3 rear bar to non ///M model wagons was a popular mod. Not sure if the F8X bars don't fit the F3X due to the different subframes or if it's just that no one has tried it yet. If I can get away with just changing the F3X rear bar out with an F8X rear bar that would be preferable to having to deal with the front bar. I do not want to sacrifice too much ride quality either as my wife drives this car quite frequently as well.
'19 F31 M Sport Estoril Blue : '16 F80 M3 ZCP Mineral Grey : '15 E84 X1 M Sport Le Mans Blue : '13 E92 M3 ZCP Alpine White '10 E82 135i M Sport Le Mans Blue : '99 E46 328i Sport Fern Green : '95 E36 M3 Cosmos Schwartz : '95 E36/5 318ti Clubsport Jet Black Last edited by mose121; 01-16-2019 at 08:01 AM.. |
01-19-2019, 02:10 AM | #82 |
Rep 1,296
Subframes are totally different so you really cannot fit F8x bars;
Fortunately we have 3rd party options too My conclusion regarding bars is upgrade the front, leave the rear as is, fits my need for sharp front end and roll control, without really compromising ride quality. Understeer isn't a concern for me as it wasn't really visible, and my LSD allows power oversteer when I need.
01-24-2019, 03:17 PM | #83 |
Big Turbo Boys N Girls
327
Rep 579
Just so everyone knows, you want some body roll. It pre-loads the tires and chassis to take corners faster. If you have no body roll you are going to slide and loose grip!. Chassis needs to move and settle in the corners and suspension will also need some movement to compress and work together. Going big and stiff to have NO roll is not the way to do suspension work.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
01-24-2019, 04:04 PM | #84 | |
Rep 1,597
02-06-2019, 04:51 AM | #86 |
Rep 1,296
Too stiff would result in lower suspension independence, i.e. the ability for each wheel to make contact independently of the others
My experience is it resulted in imbalance over bumps for instance, so fine for smooth track but not for road. Other aspect would be on hard cornering, your inside wheel(s) would lift more, reduce contact, and therefore result in understeer (front end contact surface reduced) or oversteer (rear end contact reduced); and then this affects FWD, RWD and AWD differently as it could impact power delivery; depends also if you have an LSD or not. Well not a simple answer to this in my view those who provide over-simple answers to that are mostly wrong. Just my view based on personal feel.
sspade2471.00 |
02-06-2019, 07:00 AM | #87 |
Rep 5,460
Drives: F30
Is it really a thousand dollar job to swap a rear bar on the F30 ?
Ive had an M240 rear bar in my garage for almost a year. Keep getting quoted stupid numbers to install so it keeps collecting dust. It will be going on soon enough, just cant justify that money right now... especially not when Im in dire need of a Flash Tune |
02-10-2019, 03:16 PM | #88 | |
48
Rep 164
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
