08-04-2022, 08:32 AM | #221 | |
Rep 5,400
Note: Data below comes from the Eibach European catalog and my previous phone conversations with Eibach Tech Support. See photos. Your 328ix calls for the E10-20-031-04-22 spring kit with an estimated drop of F20mm/R15mm. It uses the Front F11-20-031-02-VA spring with a 13.0mm diameter, 247mm length, 4.5 coils The E10-20-031-05-22 spring kit for the heavier 6-cylinder 335ix has an estimated drop of F35mm/R15mm (F1.37"/R0.6") (according to Eibach Tech Support) with the heavier engine. It uses the Front spring F11-20-030-03-VA with a 13.2mm wire diameter, 235mm length, 4.5 coils. It's spring rate is 194 lbs/in. Note: Both kits use the same rear spring which has a 0.6mm drop and 542 lbs/in spring rate. This makes sense because the rears of the car are almost identical. The big difference is the engine weight in the front. So you are speculating on using a front spring that is 12mm shorter than the spring that is intended to drop your car 15mm. But you can't say that it will drop your front by 27mm, (1.06") because at the same time that the spring is shorter, it also uses a heavier 13.2mm wire diameter vs 13.0mm in the spring intended for your car. I suggest that you call Eibach Tech Support. (Phone# and hours in photos) They have been helpful to me. Phrase your questions this way below, to keep the conversation focused on achieving your answers: I have a BMW 328i XDrive with Adaptive/EDC dampers. The Eibach catalog calls for Front spring F11-20-031-02-VA with an estimated drop of 20mm. 1) What is the spring rate of that spring? (See how close it is to the 194 lbs/in spring rate that you are considering. This could effect the ride.) 2) If I install a different spring kit that has the Front spring F11-20-030-03-VA, then how would the drop differ than if I had installed the first spring? Make sure to point out that the second spring (-030-03-VA) is 12mm shorter (235mm vs 247mm) but it also uses a thicker wire (13.2mm vs 13.0mm) What is the drop difference between the two front springs? Note: I found that asking the questions this way will get to a useable answer, rather than saying "this is the car that I have, so what will my drop be if I use this spring on it". That just complicates the calculations for them and is more likely to get you an incorrect answer. Eibach has already done the engineering to specify a certain spring for your car and to estimate its drop. So all you want them to do is compare that spring to another spring, and tell you what the drop difference will be, assuming everything else is equal- no other variable changes. Please let us know what Eibach says. Hope this helps! |
alohasurftoad3125.50 sdbwisc66.00 |
08-04-2022, 10:53 AM | #222 | |
78
Rep 68
So... I guess my expectations are hopefully that I achieve the exact same stance, front and rear, with my 328i xdrive M Sport with Adaptive Suspension that "xpro" had with his -05 springs on his 335d xdrive. |
08-04-2022, 12:53 PM | #223 |
Rep 5,400
Blank
Okay, so you are trying to duplicate the drop that you see in the photo that he posted on page 5.
I read through page 5 and I'm not certain about what the suspension configuration is in that photo. It's not clear whether he has an F30 335ix or an F30 335dx. He also mentions swapping the dampers out at some point for Bilstein's. It's not clear if the car in the photo has stock dampers or Bilstein's. Note: Bilstein's themselves can raise the chassis height. See FaRKle! 's video. IF he definitely has an F30 335dx, then the Eibach -05 spring kit is actually the correct kit specified for his car. (See photo) And it is estimated by Eibach that his drop would be front 20mm/Rear 15mm. SO, if his car in the photo is a diesel on stock dampers, then if you install the Eibach -04 spring kit specified then according to Eibach then you should get the same F20mm/R15mm drop on your 328ix. It's a different story if his car in the photo is an F30 335ix because on stock dampers the -05 kit should drop him F35mm/R15mm. If that's the case then call Eibach and ask the questions that I posted earlier. Whether or not the car in the photo has Bilstein's installed is a wildcard. Watch the video to understand that. |
alohasurftoad3125.50 Kirby8677.50 |
08-05-2022, 12:11 PM | #224 | |
78
Rep 68
I also think you, FaRKle and alohasurftoad could probably open a custom suspension/tire shop for later model BMWs with all of your combined knowledge! |
alohasurftoad3125.50 johnung4541.00 |
08-05-2022, 02:34 PM | #225 | ||
Rep 5,400
01-05-2023, 12:30 PM | #226 | |
Rep 3
johnung4541.00 |
01-05-2023, 12:43 PM | #227 | |
78
Rep 68
All of this stuff is sitting in my storage for another 3 months or so. Until the snow melts. |
01-05-2023, 04:51 PM | #228 |
Rep 1,649
03-28-2023, 07:15 AM | #230 | |
65
Rep 68
I went ahead and ordered the VAC monoball control arms, upper and lower. Looking forward to trying them out. I absolutely love the Eibach / Koni setup. Could not be happier with the results. Cheers, Mo |
alohasurftoad3125.50 |
03-28-2023, 07:26 AM | #231 | |
Rep 5,400
John |
07-17-2023, 12:44 AM | #232 | |
65
Rep 68
These combined with the Eibach / Koni Special Active setup transformed the xdrive from floaty Buick to proper German sedan. Thanks for sharing your experience with both, much appreciated. |
07-17-2023, 07:28 AM | #233 | |
Rep 5,400
08-13-2023, 01:27 PM | #234 |
Rep 1,898
This thread has been a huge help when I was making decision on what to do with my daily. Both johnung and alohasurftoad had great input. Here are my specs:
- Car: 2018 340i xDrive M Performance Edition (Daily Driver) - Tire Sizes: 235/40/19 (F) 265/35/19 (R) - Suspension: Eibach Pro-Kit Euro Springs (Part #E10-20-031-05-22) w/ OEM F80 bump stops. I have only been on this setup for about 500 miles now. The car feels soooo much better from stock. I enjoy the car so much more compared to the stock configuration. I don't feel like I've given up anything in terms of performance whatever. I have had zero clearance issues on my daily drives. Admittedly, I do wish it was about 1/2" lower strictly from an appearance standpoint. Feels like there's still a bit of fender gap, even though the car still looks lowered compared to stock. I don't want slammed, but I suppose this could be considered OEM+. I didn't take before and after measurements but I feel like RWD springs probably would have been great, but in the end I simply didn't want to compromise too much as I do feel an extra 1/2" would start to give me some clearance issues on Ohio roads. Sorry for the crap photos, but here are some before and after shots: BEFORE: AFTER: |
08-13-2023, 02:33 PM | #235 | |
Rep 5,400
I recently switched from the Eibach -06 to the -05 kit. So the drops on my F30 335i XDrive are now F1.4”/R0.6”. The F/R chassis height measurements are almost identical, with the front being a little less. This means that the F/R tire/fender gaps are essentially equal. (Chassis height tape measurement from center point of wheel logo straight up to fender lip.) The square 255/40-18 MPS4S over APEX 18x8.5 ET40 VS-5RS looked great as is. But doing a fine tuning measurement and adding Front 3mm and Rear 5mm spacers, brought out the tire sidewalls to be perfectly flush with the fender lips. The effective offsets are now Front ET37, Rear ET35. It was such a tiny change but combined with the oval profile shape of the MPS4S, it appeared to visually reduce the tire/fender gap even more. See photos. |
alohasurftoad3125.50 Duck360198270.50 |
08-25-2023, 04:21 PM | #236 |
Rep 496
I'm seeing some conflicting information on RWD, wondering if anyone can chime in. For the E10-20-031-02-22 set the american website says 1.4" front / 1.6" rear drop. Unless I'm missing something, this is like 35-40 mm drop. However, if you look up the part number in the catalogue, it states 20-25 mm drop for front and rear. Can anyone with RWD advise? I'd love 20-25 mm, but 35-40mm would be far too much.
08-26-2023, 10:29 AM | #237 | |
Rep 5,400
When Eibach estimates a drop for a spring kit it is always when that kit is installed on a specific yr/model/engine/etc. I always use the German Eibach catalog because it contains additional information, but it’s important to understand which information applies to the vehicle in question. |
08-26-2023, 11:30 AM | #238 | |
Rep 496
Pro-Kit Parts state: Normal Observe service information, EG type approval number from: e1*2007/46*0314*05, Fitting Position: Front Axle, Lowering ca.: 20-25 mm, Fitting Position: Rear Axle, Lowering ca.: 20-25 mm with General Certification (ABE), Axle Load front axle to: 1020 kg, Axle Load rear axle to: 1255 kg, for vehicles without leveling control and the website listed a lot larger drop - https://eibach.com/product/E10-20-031-02-22?epsid=1940 |
08-26-2023, 11:43 AM | #239 | |
Rep 5,400
Eibach European catalog also says 20mm-25mm. See photo. Just call Eibach US tech support to verify. Ive found them very helpful. |
rlesko238.50 |
08-26-2023, 11:56 AM | #240 |
Rep 4,374
https://www.eibachshop.com/index.php...ibach-products
eibachshop comes up with two kits 1-22 or 2-22. 965kg front axle or 1020kg front axle respectively |
08-26-2023, 12:00 PM | #241 | |
Rep 496
