BMW M3 Forum (E90 E92)
Mporium BMW
      03-20-2009, 01:17 PM   #23
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
Originally Posted by Genro757 View Post
Thickness is just the same...and the alcantara feels great...
+1
      03-20-2009, 01:28 PM   #24
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
Aleks great write up.
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      03-20-2009, 01:35 PM   #25
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Originally Posted by urbo73 View Post
What?? I have to remove my clutch pedal?
LMAO!
      03-20-2009, 02:03 PM   #26
Speedtrap
57
Drives: A very fast car :)
This is fantastic and you have been very concise. Thanks for sharing.
      03-20-2009, 04:05 PM   #27
rav7ks
rav7ks's Avatar
38
Drives: e92 M3
08 M3  [0.00]
An excellent write up.
Now I think I can do this myself with the help you've posted on here.
Your step by step is the most detailed write up I've seen here. We all appreciate the time you've spent on this.
Thanks
      03-20-2009, 05:36 PM   #28
doba_s
doba_s's Avatar
Thanks
not a problem ... it just makes life easier when you are doing stuff yourself ...
      03-20-2009, 10:44 PM   #29
JIO
Drives: '09 Space Gray E92 M3 w/DCT
Excellent install....you need to charge more than $90 to do it for another person. BMW charges $100+/hr and that job takes 2-3 hrs.
Very impressive...thanks for sharing.
      03-21-2009, 04:12 AM   #30
michaeldorian
Drives: M2 CS
Thanks Doba for the write up. I'm going schedule sometime and try it next week.
      03-21-2009, 10:18 AM   #31
doba_s
doba_s's Avatar
VERY IMPORTANT guys ... BE VERY CAREFUL SWAPPING COIL SPRING CARTRIDGE
      03-21-2009, 01:59 PM   #32
michaeldorian
Drives: M2 CS
Careful in what sense? Can you provide a little more detail on exactly what we should look out for? Thanks man!
      03-21-2009, 07:25 PM   #33
doba_s
doba_s's Avatar
Please read DIY ... You need to remove only coil spring cartridge and not the whole assembly ... If you remove the whole thing, you would have to recalibrate your steering wheel angle sensor ... My dealer told me it is about 3h or so ...
      03-21-2009, 09:31 PM   #34
michaeldorian
Drives: M2 CS
Thanks.
      03-22-2009, 03:16 PM   #35
MMAJNKE
MMA Changed My Life!
MMAJNKE's Avatar
Japan
317
Drives: e92 m3 & f30 328i
great diy!
      04-05-2009, 11:59 PM   #36
michaeldorian
Drives: M2 CS
Hey Doba,
I just completed the install and it doesn't appear to be working. Quick question - does the "Performance BMW" lettering on the LCD show up when you have the ignition in on position or only when you actually start the car and the engine is running?
The car is not throwing any error codes. Just nothing lights up and "L" and "R" does nothing.
Thanks.
      04-06-2009, 12:26 AM   #37
michaeldorian
Drives: M2 CS
Originally Posted by ButterzM View Post
performance bmw shows up for a sec after you start the car. Then just hold the "L" and "R" button until you see the center gauge light up.
I don't see "bmw performance" light up at all. I'm hoping it's just a power issue.
Where did you end up tapping in for power? Cig lighter per Doba's instructions?
      04-07-2009, 11:50 PM   #38
Cab5er
Cab5er's Avatar
China
80
Drives: 09 E90 M3 (Sold) 13 A1
Sweet! Thanks for all the write ups man.
E90 ///M3/ AW/ Fox Red
      04-07-2009, 11:52 PM   #39
michaeldorian
Drives: M2 CS
Yup. After fixing my faulty wiring to the cig adapter, everything worked perfectly. Doba's instructions were dead on. Excellent DIY.
      04-09-2009, 07:04 AM   #40
gixxer_kidd
Drives: e92 m3
2008 m3  [10.00]
Nice writeup! Thanks for sharing.
      04-09-2009, 10:25 AM   #41
doba_s
doba_s's Avatar
I am glad it works ! ... Like I said, take your time and make sure all the connections are solid and nothing was damaged. If you have errors, it means you didn't connect wires right ... If you have nothing at all, it means you have no Power ...
      04-09-2009, 10:52 AM   #42
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Excellent write up, definately not as easy as I imagined it but I pretty sure I can do it now. Thanks, Doba!
      04-10-2009, 08:52 AM   #43
SOARISTO
SOARISTO's Avatar
Japan
29
Drives: New M3 Coupe M-DCT
Smile
I got it!!
Thank you very much for giving a lot of useful information.
See here for M3 M-DCT RHD model.
(Sorry, it is written in Japanese.)
      04-10-2009, 10:39 PM   #44
rav7ks
rav7ks's Avatar
38
Drives: e92 M3
08 M3  [0.00]
You have to be very careful removing the connectors as they are easy to break if they are forced off and not removed carefully. I managed to break one and this resulted in a wire disconnecting and multiple errors showing up. Once the wire was found to be disconnected , I fixed the faulty wire and broken connector and everything worked perfectly.
If you know how to take everything apart, this can be done in an hour.
I was afraid of removing the steering angle sensor, but this ended up to be the easiest as the steps outlined what exactly had to be done.
Again a good write up- just some clumsiness on my part during the installation which did not result in any harm other than the wife going ballistic that I was messing up the car..lol.
m3post
